Peaucellier's linkage
You've probably seen this before and I'm not sure why I'm throwing it in here but could be useful.
http://en.wikipedia.org/wiki/Peaucellie ... in_linkage
re: Peaucellier's linkage
Damian
To use this device that I have also played with has the 2 different mounts. The shifting is cool but it also has a friction not unlike the v wheels close on one side and wide on the other for expansion and compression. This does not mean it is not useful but it may be of use in another form of chain reaction to over take the friction effect.
Re: Peaucellier's linkage
If only you guys had a clue :-)DrWhat wrote:You've probably seen this before and I'm not sure why I'm throwing it in here but could be useful.
What I'm really looking for is linkage to use in place of bevel gears. The rotation needed is about 1/3 of a revolution, so that when one axis rotates then the other axis also rotates. If a mirror mechanism were added to the right side of the Peaucellier linkage animation then it would act like two meshing gears. Then if you tilt the mirror mechanism around the vertical dotted line in the animation picture you have the equivalent of meshing bevel gears.
It seems rather complicated but it might be cheaper in some cases than buying bevel gears.
JimR
I'm sure you thought of it already but just in case, If your not supporting huge loads and its just for POP then you can make a poor mans bevel set by having discs at 90 with rubber for traction on one riding on the surface of the other. Many an old crafstman tractor or snowblower uses this exact same drive system. What some laymen think is they have a fancy standard or auto trans when really all they are doing in moving the driven shaft/pulley closer to the axis or further away for more speed.
Its always funny when i hear someone tell me the trans blew on their lawn tractor. LMAO I ask if it was the spring or the rubber disc? they look at me like i don't know whats going on.
Or you could just buy some fancy bevel gears, cmon, drop in the bucket of on this journey.
gravitati aequalem.
gravitati aequalem.
Hi Jim
Perhaps pairs of small hydraulic cylinders(push/pull) linked to the respective "radius arms"?
Should keep angular movement constant.
Mick
Mick
- path_finder
Dear Jim_Mich,
Let's rotate your picture within 90 grades clockwise, you get an excellent parametric pendulum.
edited:
There are two kinds of Peaucellier linkage, depending from the position of the first lozenge summit (outside or between the two pivots).
The picture below shows the second configuration (the lozenge summit between the two pivots):
edited:
I hope you find this informative.
Peaucellier's linkage mechanism becomes a walking wheel.
Peaucellier's Linkage Wheel (with 4 legs) ---- One application apparatus.
( The red bullet is an axis of wheel. )
(Picture is international.)
URL = http://www5d.biglobe.ne.jp/~the_imai/et ... tm#P_wheel
(in Janapese)
(in Janapese)
Welcome asifsound!
Thanks for the msg!
I'll take a look later, without rush.
Best to you in already started 2012! 8)
M
Edition: this link about walking machine geometry is great and will be appreciated by others of the forum!
Thanks again.
Thanks for the msg!
M
Thanks again.
Doesnt Path Finders avatar do the same thing ?
Attempt only the impossible.
Yep...
When I told 'by others in the forum', I had him in mind...
Best!
M
Best!
M
