Another Clue!?
sleepy
Another Clue!?
Post by sleepy »
I'm nobodies mathemetician,but it seems to me that for Bessler's wheels to attain posted speeds at their respective posted sizes,free falling weights would have been useless,as gravity would not accelerate them faster than the wheel was turning.Those clunks against the side would therefore logically be caused by centrifugal force moving weights around,or by some type of spring aided acceleration.It will help if you hold a weighted piece of string and spin your arm in a circle(roughly 6 ft in diameter,as JB's first wheel)and using a second handed clock,make one revolution per second(as JB's first wheel).In my experience,the weight just flies around without falling.
Jonathan
re: Another Clue!?
Post by Jonathan »
For the Gera wheel, you are right, the centrifgual force is 2.77 times the gravitational force. however, whether this matters or not depends on the mechanism inside. If two weights are connected such that one moving out causes the other to move in, then the centrifugal force can be partially or entirely canceled.
Michael
re: Another Clue!?
Post by Michael »
Hey hey hey Jonathan, ( My fat albyy imitation)
Two weights, one pulling the other in along the same arm wont have the same centrifugal force, it will become less for the one moving inward, so they wont cancel.
Reg.
Mike
meChANical Man.
Re: re: Another Clue!?
Michael wrote:Two weights, one pulling the other in along the same arm wont have the same centrifugal force, it will become less for the one moving inward, so they wont cancel.
If the inter-connection between the two moving weights were non-linear then the centrifical forces could quit easily be canceled. But with a linear inter-connection you are right.
Jonathan
re: Another Clue!?
Post by Jonathan »
Exactly Jim.
Michael
re: Another Clue!?
Post by Michael »
Thats why I was specific and mentioned the same arm. I should have wrote not if, on the same arm.
Reg.
Mike
meChANical Man.
