Richard,Richard wrote:jim_mich notes
I'm not sure what you mean by 'fictitious forces' as it relates to just the wheel shell? I assume you mean inertial forces. I'm sure a 300 to 500 pound wheel would have enough inertial momentum to mask and smooth any pulsing of the weights.
Just my opinions. I could be wrong.
Richard..
..yes jim..this is exactly right...
it is possible that the many weights Bessler was seen, to have unloaded into a box...could have given mass to a wheel...
..often I am reminded...that Bessler claimed...(paraphrased) " oh that one..that was an entirely different principle of operation...
..Can we agree on this...we borrow from Bessler what suits are concept,...much the same way a zealot might build a whole theology around a single verse or chapter..?
..if this is the case...then I can see my error...in supposing a " very light shell?
richard
While gasoline, diesel and hydrogen fueled cars all rely on internal combustion, electric motros do not. This is one reason why using an electric motor with an internal conbustion engine is called a hybrid. It uses a different principle.
Rather than relying on the expansion caused by igniting gasses in a cylinder and converting it into angular momentum (torque), it relies on opposing dielectric feilds using Ohm's law to convert a static electrical charge into a repulsive force causing a stator to rotate.
Do you consider it possible that when Bessler stated >> " oh that one..that was an entirely different principle of operation... << he was literal in his meaning ?
[/code]
edited to add my t is sticking
