Norman,nebollinger wrote:I am new to this forum but not the Bessler wheel so I am focusing on the clues to the wheel. The one that stands out is the early wheel that turned only one way had to be tied or it would just start turning. This means that it was unbalanced right off. In all of my wheel attempts I define the real problem as the reset - we can embody something to turn but then how do we reset that piece so it can repeat the motion? I suspect the clued that ties to the reset is the weights were in pairs. The other problem with my attempts was bottom heavy Center of Gravity CG. When a weight shifts to cause motion it usually causes a lower CG and thus the inevitable run-down and stop. So how can one cause motion and not get bottom heavy? I thought inertia might do that. So picture the rollers in a roller bearing such that
only one end is dropped and thus causing inertia and then it is reset by
going back to its origin for another drop. It seems to me this might not
create the bottom heavy problem.
I am enjoying the many enlightening discussions. My claim to fame is my pendulum that swings higher than its dropped point from magnets that are placed along the way. I have a magnet addiction and we will have overunity when we can use a small force to release a larger force.
Norman
welcome to our forum!
When possible, pls share your mag pendulum.
Best!
M.
