Sure.Silvertiger wrote:You're referring to the "redesign overhaul" I did on page 5 of this thread. I went back to the original lever design, so the 38 resistance inputs does not apply.ME wrote:I have no idea what this lever is all about... so eeh good luck I guess. So is it "solved" or not? When it failed to work, perhaps reveal the intended idea behind your "38 inputs, more than half of which were friction scripts".
We don't blame the program, we just blame you.Silvertiger wrote:And as for not being convinced, you are not the first, and you will not be the last. People always blame the program...even if it is two completely different ones.
The situation is similar with Jim_mich's simulation and his motion wheel.
Because there's no proof, it could be anything... perhaps you made the mathematical mistake twice...
You may know, we don't.. Your visuals do not proof you succeeded: you have hidden components (or scripts), it may well swap the 1 and 4 pounds... I don't know.
You know, "Burden of proof" etc...
For now: 4-pounds can't be lifted by 1 pound.
No hard feelings, but that's the perspective from this side of the discussion board.
