Blood From Stone
Re: re: Blood From Stone
justsomeone wrote:You certainly don't like your intellect questioned , do you Mr. V. ?
I don't like distracting BS much, but who doesn't love being called thick?
If you're on about bleedin' Marchello, he was accusing me of not measuring input energy, in replies to an experiment designed for that sole purpose, fully metered up with completely independent and fully-consistent measures of input energy with 6 sixfig Riemann solutions for the integrals. He wasn't simply calling me stupid, he was lying and misrepresenting my work. Trolling. If there was an 'ignore' list, he'd be on mine.
silent
Post by silent »
MrVibrating wrote:If there was an 'ignore' list, he'd be on mine.
The forum offers a feature that allows you to ignore members. At the top of the page click the menu item Contact Lists then select the ignore feature and enter the member username/s you wish to put on your ignore list. I don't think there's a 'select all usernames' button, so it's not perfect.
LOL what would be the point of that?
Just realised, in principle the axial and orbital MoI's could be equal...
The orbital MoI could even be lower than the axial one..
Thus a given distribution of momentum transferred from the latter to the former could replicate the "three cycles to 150%" result i mentioned on the last page..
..could it be done even quicker, if the orbital MoI is lower than the axial MoI? OU in one hit, perhaps?
MrVibrating wrote:LOL what would be the point of that?
Wow that actually works really well!
I can now no longer see messages from everyone on my "stupid idiot" list! Bliss! Love this place..
silent
Post by silent »
MrVibrating wrote:
Fletcher wrote:Hi Mr V .. I thought I might as well weigh in somewhat, on the back of ME's and sleepy's comments. Not meant to derail or discourage you but perhaps widen all our perspectives in our search. IMO exploitation of MOI for momentum and energy gain as you are attempting to demonstrate seems a plausible possibility if we have the right mechanics.
I just want to lay out some thoughts then ask some questions that we should all think about.
FWIW B. said that his PM secret was very simple, but deeply hidden. So simple in fact that he was concerned a buyer could ask for his money back.
Now I'm going to apply Ockhma's Razor and suggest that B's wheel internal mechanics looked like almost any OOB system, with a Prime Mover system and a secondary OOB system that were connected (or coupled if you prefer). MT seems to suggest that many designs could be made to work.
But we almost all believe that gravity is a conservative force and in a closed wheel environment that gravity can not be a source of energy vis a vis a Gravity Only wheel is extremely unlikely both then and now.
But most OOB designs involve shifting weights or lever weights (lws) for example. They periodically change radius as they swing in and out etc.
Whilst standard physics says that in a closed system there will not be asymmetric torque from OOB systems, we also inherently know that these swinging lever-weights etc change system MOI so that system MOI is in a state of flux thru rotation.
So my question to you (and us) is what does greater or lesser wheel MOI really mean ?
It's my understanding that a greater MOI rotating structure takes more energy input to achieve a certain speed in a standard time interval (rpm). A lesser MOI rotating structure can be accelerated for less energy input to the same rpm.
So once again applying Ockham's Razor, it seems plausible to me that B's wheels simply looked like OOB systems but actually exploited a change in MOI from transitioning lws etc. And this was potentially the deep dive secret he was protecting and took him so long to find and harness mechanically.
My conclusion being that any MOI exploit fell out of his hunt for an OOB wheel, and hence why there is 99% common DNA to an ordinary OOB system. And why he suddenly realized why all the other attempts had failed; because he had discovered the deeply buried secret to accumulating momentum thru fluxing of system MOI that had energy advantages rather than asymmetric torque advantages.
JMO's. Something to think about as we look for our own deep dive PM secret that is extremely simple.
You're quite possibly right, it's something i'm often thinking about - did he really delineate the two vis viva's and work out the dependence of CoE upon CoM from first principles.. or was it just a 'happy accident' he was smart enough to follow up on?
I think he's given sufficient indication's he's aware of the importance of counter-momentum, and that it's possible he was thinking in terms of trapping and entraining the vis viva - motion itself - for some years after "learning the hard way" about the futility of chasing a GPE exploit. He mentions being unimpressed with others' thoughts on the issue - as would anyone who has progressed beyond OOB designs listening to more of the same - and given the latest findings that the design has to be optimised to minimise orbital inertia before the banked momentum has sufficient KE to exceed input energy, the first tentative runner he describes seems unlikely to have been an OOB design-gone-wrong, and really could only have been inspired along similar lines as here - the search for a way to reduce the CF costs of generating momentum from gravity. It's a very particular design criteria that would serve no obvious advantage in an OOB scheme..
Arguably, with regards to weight levers, an "MoI" has to be in some way confined to the axis in question - if it's just floating or swinging around then it's own axis of rotation is the only MoI that really matters, since its orbital MoI isn't really a function of the net orbital momentum or RKE - and that's what validates a given measure of MoI - it's the base field for mV and ½mV².. so if an acceleration of the net system isn't likewise accelerating some internal mass in the same plane because it's swinging or rotating or changing radius on a pivoting axis, then it's not really meaningfully part of it's MoI, nor thus a function of the instantaneous net system AM or RKE.
We know CoM and CoAM. We know he (correctly) stated that mechanical OU depends upon statorless operation. We know that driving a load with an OU wheel necessarily involves offloading some momentum with that donated KE, so more momentum must be sourced. We know his wheels were vertical, and we now know that momentum can be sourced from gravity without using a stator. We know he used internal masses changing radius, and attributed the causative principle to them and these transitions. We know these transitions produce reactionless 'inertial torque' . We know they cannot cumulatively add KE or momentum over successive cycles. But we know that the accelerations and decelerations they cause produce the opportunity to grab momentum from gravity.
We know that accumulating reactionless angular momentum is an inherently non-conservative process. We know that inelastic collisions can consolidate momentum gains. We know that axial CF is independent of orbital CF. It seems to me, he could've figured out most of this stuff the same way we have.. like he said, if it's there, then it's just a matter of searching diligently enough. Methodically, and persistently enough. As ever, the implicit instructions for generating 'free' energy are written between the lines of its terms of conservation - don't do the things you need to do to conserve energy, and you won't.. and that's where the methodology, and thus inevitability, comes in.
You've got mass - inertia, angular and linear - force, accel, vel, plus 'what goes up must come down' - there's not really that many permutations is there?
Compared to the dozen or so different inter-reacting effects and properties that make EM interactions so non-linear, mechanics presents a much narrower range of interactions to try out..
..and what you quickly find is that both inertial interactions, and gravitational ones, are pretty firmly conservative within their own terms. Hence the only remaining option is combining them - investigating their inter-reactions..
And with angular inertias, you can't not end up playing with MoI variations and their effects..
Dunno, all text-walled out. TL;DR, i think he'd've had to get here by the same route we did.
Well, I'm going to take a punt and say he would've understood about circular (orbital) MOI relationships. For starters he would have observed a rolling hoop being tapped along, or maybe had seen the disk, ring, and sphere experiments race down a slope when all the same mass, and noted the winner. So he would understand the importance of mass displacement in a wheel design to energy input and GPE release.
Where I probably diverge from you is how he might have got to seriously investigating mechanical MOI changes (assuming this is what he did). I think he would have noticed an aberration in an OOB design or concept he was testing. Something that could be of use to cause accumulated wheel momentum, but not caused by sought-after asymmetric torque. And that was the uh-huh moment.
I say this because many of us have played around with forcibly changing radius of equidistant weights and also using CF's etc. No one successfully AFAIK.
And he would have recognized the importance of a semi-open system rather than the bog standard closed system.
All-said-and-done he attributed his insight to a dream from God, but he would wouldn't he. As-an-aside the number 72 (internal angle of the 5 sided pentagon) is important in the Kabbalah, representing the 72 names for God.
MrVibrating wrote:I can now no longer see messages from everyone on my "stupid idiot" list!
Careful with the antiseptic, today's idiot might be the trigger for tomorrow's revelation.
Hi MrVibration,
yes, exactly, the first hit or soft impact or call it elastic collision already will produce OU. I had described this function as an indirect impact.
It is a combination of a move, a hit, a fast lift up and a shift sidewards in one go.
All of this moves are made parallel with 8 weights.
It is a simple construction now.
The weights itself will swing, can freely run,
Behalten ihre Freye Jagt
der sind nun immer zwey und zwey.
two weights are acting always in the same way.
both are lifted and shifted.
A parallell shift sidewards will create the torque on the main wheel.
The weights are from
Bley
Bley=blei=lead=plumb
it is a concentrated mass, allowed to swing a far distance, to produce torque.
You described the looking of the mass already.
Hi ovyyus,
if we all had the same opinion, we were not on this board.
We will not try anything, because we know it will not work.
So be happy that someone has a different opinion than you.
All on this board, I assume, will try to solve this riddle.
You can try to go the conventional way, then you get then conventional solution.
The wheel will not run.
As I said many times again and again, the loss is your profit.
Everything is already discovered, mathematics, physics. The rules are there, no law violated.
it is the change of your view, that is required.
Look in the other direction and you will see the solution immediately.
Georg, my point to MrVibrating (if that's his real name) was that placing anyone in this particular field of research on ignore is probably anti-productive. Unless, of course, the ignorer is suckling a dearly held belief.
silent wrote:Do you think it's worth attempting a build? If so, do you have in mind the mechanism that causes the red weights to move in and out as the wheel spins?
silent
Much too early to waste a moment on any of my BS mate.
These are just minimalist experiments for now, for initially working out what the gain trajectories are. Real builds obviously won't need six-figure accuracy.
As i've mentioned, the optimal config might not use a pair of balanced masses for the MoI variation - maybe it can be optimised to 1 MoI-varying mass plus 1 weight, with just two masses alternating in those two roles every cycle, or every other cycle..
As for powering these radial translations - and converting the KE gains back into sprung PE or whatever to cycle them - i currently have no clue; these are engineering issues, but vital as they are to a practical embodiment, they're not the hard problem we're all here for...
...on that count, just look at all the crazy things we can engineer already! If it's even remotely possible, we can engineer it. We're great engineers (as a species, i mean, not me personally, i suck at it).
But out of the 110 billion or so people that have so far lived, only 1 of us has ever solved this particular hard problem. And he buried it in impenetrable codes..
Best way to get involved now would just be comprehending the gain process - so, getting your head around the dependence of conservation of kinetic energy upon conservation of momentum.
The first person here who starts to really grasp how Newton's 3rd, and thus 1st, laws, enforce the symmetry of PE to KE, is going to have the biggest head start on anyone else, not least in considering design applications..
Ovyyus,
sometimes it is good to ignore the advice of experts.
I will repeat a sentence from Victor Schauberger, don´t ask me where it is written, but the meaning is the following.
so Mr. Schauberger said.
if i am wrong, than it doesn't depends on a fool more or less
but if I am right, then grace god of humanity
So in this case, I am with MrVibrating, the actual experts are wrong.
They try to discredit his work.
Gravity can easily transferred in torque, in many ways.
https://www.youtube.com/watch?v=CsKKDLKYsVU
Make use of this energy !! not destroying the structure.
We can artificially create such vibrations, an interaction with gravity.
Georg Künstler wrote:Hi ovyyus,
Thank you sir. Saner minds must prevail here.
I've gratefully applied Ovyyus's good suggestion to his good self already, so cannot see the response you're replying to, though i presume i'm missing little of importance.
I don't like 'blacklisting' but i ain't got time for dickheads right now.. so if i'm not responding to someone, maybe their prior input has been less than helpful..
