Ectropy and Maxwell's Demon.
Trevor Lyn Whatford
re: Ectropy and Maxwell's Demon.
Post by Trevor Lyn Whatford »
Hi Jim_mich,
Jim wrote,
My device simply uses CF in a manner that increases the usable (not the total) motion energy of the device. That is the first step.
No Jim! step one is, provide a energy input to create the Centrifugal Force, the CF energy in not in the system at the start, and will have to be put into the system, if your system is closed where do you get this input! Creating the CF is step one!
I am also working on CF system, and fully understand CF has to be created before you can tap its force, and if you do tap its force you will need a renewable energy source. If you do have a working CF system? Then you should find where the renewable energy is coming from! IMHO, CF can be used to create a greater force, but there are limitations with CF, and requires other mechanical advantages in the system!
With respect Trevor
I have been wrong before!
I have been right before!
Hindsight will tell us!
Trevor,
Please understand that I am not defending or assisting Jim with his Cf statement, he is a big boy and can take care of his own problems. But I would like to point out the following.
Not unlike Bessler's bi-directional wheels an outside "impetus" was said to be required to set the wheel in motion, this is your initial outside force. I have reason to believe that my own design (not based on Cf) will require the same method to start rotation.
Now, maybe Jim is relying on capturing enough Cf exponential force to more than supply the primary, with usable force left over for outside usage. Once again I can relate with my design.
If my first proto shows a hint of promise, my second build (already on the drawing board) will be designed in a manner that the augmentation of Cf will be utilized, increasing efficiency in power and increasing RPM.
Trevor wrote:No Jim! step one is, provide a energy input to create the Centrifugal Force, the CF energy in not in the system at the start, and will have to be put into the system, if your system is closed where do you get this input! Creating the CF is step one!
Communication. With words we try to convey meaning. If you think one thought as you read my words, but I was thinking of a different thought, then we fail to communicate. Learn to look at what was trying to be communicated, rather than being picky about the words that were used.
Obviously a wheel that uses CF must be first started rotating. Only idiots would think different. But once rotation has begun, then there is a continuing cyclical process. And I was simply describing that continuing process.
So don't tell me I'm wrong. It is not my fault that you failed to understand my words. I tried to word it in as simple a manner as possible.
It irritates me when people talk down to me, and assume I don't understand things, and then they attempt to 'educate' me as to how things work.
I'm very intelligent. I was once accused of cheating on a simple aptitude test, because I finished in less than the allotted time and scored 100%. My list of accomplishments is very long and varied. I'm sure there are other members who have experienced equal or better achievements. I assure you I'm not a dumb bumpkin just off the turnip truck. I discovered my PM method by writing computer programs where the computer calculated and graphically displayed the motions of moving weights on a wheel. That is a very complex task. The math calculations told me it should work.
But I was still skeptical. I kept asking myself, where does the energy come from? If you don't understand the Maxwell's Demon principle, then you will never understand where the energy comes from. Also, if you fail to understand the non-conservative concept of kinetic energy, then you also will never understand where the energy comes from.
Now some might flame me for using the words, "non-conservative kinetic energy", but it is a fact. There is no Law if Conservation of Kinetic Energy. Look it up! Kinetic heat energy is conservative. Kinetic heat energy is conservative with kinetic motion energy. But all kinetic motion energy is relative and is only conservative in a relative manner. Your body contains enough kinetic energy to smash you to pulp, if your body were to meet some object that is stationary relative to the universe. So, in such a case of pulverizing, does the energy come from your body or from the celestial object sitting stationary relative the universe? The answer is that the pulverizing energy is a function of the universe, and does not reside within either object. Kinetic energy is not of a fixed amount within a weight. It is only a relative amount. KE is a value relative to the motion difference of two weights. It magically appears only when the motion of one weight mass is directed against the motion of another weight mass.
The Conservation of Energy Law is a Thermodynamic Law concerned with conversion of heat to motion and motion to heat. It has been wrongly assumed to cover all situations.
Trevor Lyn Whatford
Hi Ralph,
there has to be step one! First create the CF! this was my point!
I made this mistake with a patent. I had a piston system, and did not mention it needed priming first, I just though it was not worth mentioning, everybody knows piston systems needs priming, just like the combustion engine, no not the patent office, they did not see it as common knowledge. hope you see my point!
With respect, Trevor
Patent claims must be worded very carefully, and must FULLY disclose the concept. So a patent MUST explain that there needs to be initial rotation. Here on the forum, we know that initial rotation is needed.
Trevor Lyn Whatford
Hi Jim_Mich,
Why is it my fault, you was not clear and precise, and that you jumped to step one before you mentioned step one and in fact your step one was actually step two, and your step two was step three! So you was wrong!
I think it is lucky you passed your Aptitude test, because you sure as hell would not of passed a attitude test.
I hope you do have a runner, as it may go some way to explain your total arrogance.
I think most people find it irritating, and suggest you stop doing it!
It is sad that you have taught me more about psychology than mechanics!
Jim, I have to snicker and grin every-time I read this. How many times over the years have you complained about my wording and the way I attempt to get a point across.
NO I am not upset or going on the war-path, I feel your above statement should be on the "Joke" thread. I shall bookmark it for future reference, the next time you complain about my wording structure, :-)
Ed
Post by Ed »
Agreed. Plus opening with "Learn to..." Sounds like "an attempt to 'educate'" to me.
Jim, you must have a piece of "The Plan" stuck to your shoe, you know...the piece that says "First get something that works!!!" and "It is much harder to put the greenie back into the bottle after everyone has seen it."
Trevor Lyn Whatford
Re: re: Ectropy and Maxwell's Demon.
Trevor Lyn Whatford wrote:Hi Jim_ Mich,
Could you please be clear and precise as to what is driving your device as it is a bit confusing to the reader, I do not need any detail of the device, but I would like to know its energy sources, this would stop all the confusion on this thread!
Hi Jim_Mich,
I did ask!
With respect Trevor
Trevor Lyn Whatford
Hi Jim_Mich,
Reading between the lines, you have used a unproven computer program! To prove a unproven theory!
cloud camper
Post by cloud camper »
Did you miss the forum rules change Trev?
Four greenies and you now get to claim a runner with just a theory.
Five and you get to ignore that "idiotic" CP!
rasselasss
Post by rasselasss »
Yes J.S.O.,reading some of the stuff here and the characters is surreal,my comparison would be "Under Milk wood"by Dylan Thomas,we are all there.....On the subject of Copyright/Patents etc.which is written enormously about here and many have differing viewpoints,i'm curious have any of you guys actually sold something you have invented "copyright/patented"or otherwise,i'm not talking about grants etc.for failed projects ,backers funding etc.but actually "sold "something for lets say £20k or over or is it all "hot air"wannabe type talk.?...Good Luck.
Trevor Lyn Whatford
Hi rasselasss,
yes, I was building and selling my folding wind surf trolleys, and open and lock the box on folding fishing trolleys, here is the stupid part a lot of my inventions I did not patent, because I was hell bent on PM (this time next year and the every year after that, lol), I have a list of things that could have made me well off, I invented a dental floss bow with cleats on each side so you could keep running the floss through the bow, a few years later they brought out the disposable bows, if I had patent it, one of my claims would have been "a bow for the application of dental floss", that one could have made me some money not a lot but enough! it is very hard selling one product, I would recommend that people licence out a one off invention to a company that can get it to the masses, so they can spend their time inventing more stuff!
Edit x 2, spelling, + 2 x year.
Last edited by Trevor Lyn Whatford on Mon Apr 08, 2013 12:15 pm, edited 2 times in total.
rasselasss
Only about 1 in 10 patents ever earn a penny.
And about 1 in 100 patents ever earn enough money to pay for the cost of getting the patent.
But once in a while a patent helps an inventor by keeping others from ripping off his invention.
For most people, getting a patent is like playing the lottery.
My dad had two patents. He got his first about the time I was born. He might have sold it to the company he was working for, but I was too young at the time to know. His second patent was never sold.
I belong to an email server list that helps each other with information about inventing. Some have been successful. Others not.
To be successful, an inventor needs to learn to become an entrepreneur.
Ed Zimmer has excellent information on his website: www.enonline.org
But there I go again, trying to tell people what they need to learn. But I've always thought that life was all about learning! That has always been my goal, to learn as much as I can, about as many things as I can.
cloud camper
Since you are so intent on learning new things, I believe a couple hours spent studying a Physics 101 book might teach you that this magical world where CP does not exist is not shared by the rest of us!
