But as i've meticulously laboured already, what is it that these ordinary machines might contribute?eccentrically1 wrote:Assuming the translation is right, he did not say what you said.MrVibrating wrote:DT p.204/5:eccentrically1 wrote: Where did he say the load increased the mechanical advantage?
"Everything which up until now has been achieved via the
agency of water, wind, weights or animal power by
means of various machines, (page 53), be they water,
wind, tread, or hand-mills, cranes, winches, jacks,
pulleys or whatever, could equally be achieved using my
P.M. machine – indeed, often with much greater
advantage, especially since the motive force of the
device, which at the moment is only that of a small
working model, can be multiplied to an almost infinite
degree through combination. Further advantage can be
obtained by working the device in conjunction with
ordinary machines, and altogether there is no load or
burden too great for the machine to face if the working
arrangements are properly set up."
In conjunction with ordinary machines isn't the same as in conjunction with applied loads.
If it's input energy, then that kinda muddies if not invalidates the purported efficiency, and worse, might instil doubt about the efficacy of the invention - and in this passage he's trying to do the opposite of admitting weaknesses, and rather, selling up the potential advantages to prospective buyers.
So an external machine could contribute input energy, which seems an unlikely intention, or else output energy - ie. a load.. or else, assuming that the external machine in question was itself perfectly efficient, then the input and output laods would be equal, and all it is contributing is inertia and periodicity.
have i missed anything else?
