And what is that?from them is received the universal movement
I consider it oscillation.
I understand what you're saying, but when he says that they are arranged in a way that they can never reach equillibrium, how do you explain that? Do you think he was referring to that the weights arranged will never reach equillibrium (as long as I have my power supply). If this was the case, there would be no need for an overbalanced wheel, he could simply strap his device onto a wheel and watch it turn. Why would he go through all of the trouble?ovyyus wrote:If I built one of the MT designs, say MT9, and added a power supply which is timed and coordinated by the movement of the weights, and then restricted my description of it to only that of the function and purpose of the weights, then I think I would end up with something along the lines of what Bessler describes.Deven wrote:He states that the reason they continue on their paths is because they can never reach equilibrium because of the way they are aranged. Doesn't this point to gravity?
ovyyusHe states that the reason they continue on their paths is because they can never reach equilibrium because of the way they are aranged. Doesn't this point to gravity?
the only way Bessler's statement is full and correct for most is if their pet theory of the moment agrees with his statementIf I built one of the MT designs, say MT9, and added a power supply which is timed and coordinated by the movement of the weights, and then restricted my description of it to only that of the function and purpose of the weights, then I think I would end up with something along the lines of what Bessler describes.
websterI consider it oscillation.
From Deven's postjim_mich wrote:think Bessler is describing his secret here. He says quite plainly that the weights are the essential parts and constitute perpetual motion itself. I really don't see how anyone can think otherwise. He goes on to give more details as he says from them is received the universal movement.
Guys, listen to what Bessler is saying! It is the movement of the weights that is the secret. The weights are the essential part. The weights constitute perpetual motion. As long as they remain out of the center of gravity they receive the universal movement that keeps them moving. Bessler is not talking specifically about the wheel remaining out of the center of gravity; he's talking about the weights themselves remaining out of the center of gravity.
Of course this is just my opinion. Everyone if free to reject what I say. But do you guys reject what Bessler says?
I do not reject it Jim .. I just don't think it goes far enough !'Inward structure of the wheel is of a nature according to the laws of perpetual motion, so arranged that certain disposed weights once in rotation, gain force from their own swinging, and must continue their movement as long as their structure does not lose its position and arrangement. Unlike all other automata, such as clocks or springs or other hanging weights which require winding up or whose duration depends on the chain which attaches them, on the contrary these weights are the essential parts and constitute perpetual motion itself; as from them is received the universal movement which they must exercise so long as they remain out of the centre of gravity; and when they come to be placed together, so arranged that they can never obtain equilibrium, or the punctum quietus which they unceasingly seek in their wonderfully speedy flight, one or another of them must apply its weight vertically to the axis, which in its turn must also move.' - Das Triumphirende Perpetuum Mobile, Bessler, 1719.
IMO, Bessler simply states the obvious - that a wheel designed to create an overbalance must use weights that are never allowed to find equilibrium.Deven wrote:I understand what you're saying, but when he says that they are arranged in a way that they can never reach equillibrium, how do you explain that?
Yes.Deven wrote:Do you think he was referring to that the weights arranged will never reach equillibrium (as long as I have my power supply).
When Bessler first encountered the long established pursuit of the overbalanced wheel he was told that anyone who could produce such a thing would be richly rewarded. Bessler's intent was to satisfy the accepted definition of "true perpetual motion" in the form of the classic overbalanced wheel and collect his reward.Bessler wrote:If this was the case, there would be no need for an overbalanced wheel, he could simply strap his device onto a wheel and watch it turn. Why would he go through all of the trouble?
He did find it where everyone had looked - in the pursuit of the overbalanced wheel.Deven wrote:When he says "he found it where everyone else had looked" does this not imply that it was gravity that was the answer?
Not yet :)Deven wrote:I don't know, maybe we'll have to agree to disagree!
