Very interesting post Jim. I came across this hiatus between Momentum and Kinetic Energy many years ago and it led me on to see that mass was a measure of motion and had nothing to do with matter as such.jim_mich wrote:The hardest thing to learn is that gravity alone can not cause a wheel to perpetually turn. Bessler tells us that the weights within the wheel must gain force by simple moving. This hints at inertial momentum as being the source of the wheel's energy. But it is well known that momentum is conservative. We are also taught that energy is conservative. but if you look at kinetic energy it soon is very apparent that kinetic energy is NOT ALWAYS conservative. If all the momentum of one moving weight is transferred to a second moving weight causing the first to cease moving and the second to double its speed then when the speed doubles the KE increases by 4 times. Thus the KE of the two moving weights doubles when one weight transfers it KE to the other weight. If the force of this increased KE is used to rotate the wheel in such a way that the two weights resume their original speeds then the cycle can be repeated perpetually. None of this violates any laws of physics, though some might say that it violates conservation of energy. [/url]Animal wrote:And now to the crux, how many "learning experiences" do we have to go through to get "close" to getting one running? Anyone got one running? and whats the consensus on the goal here, unidirectional or bidirectional?
After all, if you think about it we measure mass (linear inertia) by measuring motion. Obviously I am talking about denominator mass and not numerator mass. Two objects will have twice as much mass as one because they have twice as much of the internal motion that constitutes mass. Likewise, they will have twice as much heat, twice as much weight but heat and weight are not mass. In terms of substance/accident philosophy mass is accident not substance.
