>>I do not build facsimiles of Bessler designs as drawn, I know they will not work. Your above sketches only reinforce this point.<<rlortie wrote:Hello, not_me or is it really Bessler_Supporter? Do you have any other pseudonyms?To let all of you know, I am banned from this forum. I believe this is because I support Bessler. You see, a certain private build group posts in another forum that they do not do Bessler builds because they expect to be compensated for their efforts. The posts can be shown if anyone wants proof.
Please explain why you are banned from this forum, I do not believe it is for supporting Bessler.
What other forum does Bessler wheel designs only if compensated for? Please post proof or at least the address for the forum.
Therefore If I am asked to build something that is of no value except to the individual who wants it for a sculpture or trivia mobile , compensation would be expected.
An Mt 24 modern day cross section I built. I believe Bessler's cross section is based on the cross, 4 sections or weights.
I think it helps to build Bessler's drawings if a person actually wants to understand his engineering. This would be like letting the Master be the teacher. Of course, there might be little compensation in it as Bessler is German and this is German history. Not sure how favorable a response would be in America. Besides, it's not supposed to be possible.
But with the modularbuilding technique I used, I could do multiple builds from the same wheel limiting my expenses.
With the pic where it looks rotated, it shows tht the lever can be perpendicular to the force of gravity allowing it to have maximmum force for pumping.
The pic where it looks level I show the math for the lever moving 45 degrees inward. It performs more work than the imbalnce it creates with solid weights. This allows the water to be the primary over balance. Also, when the weeights fall inward on the way up, they would make a knocking sound.
