Possible "it"?!
PLMKRN
re: Possible "it"?!
Post by PLMKRN »
History is odd ...
Exactly three years ago today, and about same time as I write those rows here, I got my first runner to work. Finally some progress, after about four hundred attempts. But this runner was not ideal one ... jet, as it rotates slowly.... very slowly.
It was taking almost hundred build more to get final setup, which has now very good speed and "shape". This was trial and error experimenting, why this works and this is not. From those errors, I have learned that a lot of those "modified" wheel versions, was not working at all. So there was a lot of possibilities for errors, to build a working model. Even you have put "almost" ALL together correctly and set up the right way, as it should be.
I still wonder it till today, that how I found this - "rare, almost working one" on the first try. From "between" most others - "almost right, but not working solutions". If I had built firstly this "almost right, not working one". I had dumped this idea and start to search a new one. So there was no any runner until today. And I may still think that this "almost right setup" is "non-workable".
Now, afterward. Strange in this story is not only how I was lucky to find "it" on the first try. But also I wonder, why it was happening exactly in this, I may say, "special" day? Why this exact day was (and still is) so special to me, you may ask here?
Well ...
Because I can say exactly today at 24 Febr. after three years later from my discovery - Happy 100th Anniversary Estonia!
https://www.ev100.ee/
Continues ...
PLMKRN
re: Possible "it"?!
Post by PLMKRN »
There is a lot of more "odd things" in my story, then I can write at the moment here and all this seems more than unbelievable also to me, but let's face one of it ...
PLMKRN
re: Possible "it"?!
Post by PLMKRN »
There has been a long time up a question: from which country and who will reveal the solution to this mystery?! I will extend this question here to:
Can it be, that similar to Bessler codes and clues, there are visible similar clues in somewhere else, non-Bessler related "things"?
Example, in some place or country related "things"!?
If look this little wider and look it by the country. I think here, that this country could be Estonia?
Why Estonia?
My main idea at the moment here is to show weird connections between Bessler clues and Estonia, as a country.
Firstly. There is a lot of talking about how wheel inner mechanism could work. Everybody here knows that a lot of talks have been about, that the secret behind of "kiiking" hides all the answers. Also, John Collins has made right remarks about this "sport", in one of his websites: http://www.besslerswheel.com/html/gravi ... ciple.html
Kiiking was invented in Estonia.
https://en.wikipedia.org/wiki/Kiiking
Secondly, Estonian national symbols:
https://en.wikipedia.org/wiki/National_ ... of_Estonia
"KAHEKSAKAND" - directly translated "eightheel", is a MAIN national pattern, meaning - "lucky star". You see it everywhere when you travel in Estonia. But it also represents "sun", "snowflake", "centaurea cyanus" ... and it has built up with two, five-pointed stars ( http://www.vippa.ee/2016/01/rahvuslikud-ornamendid/). This figure has a lot of similarities to some last drawings in MT. Example, in toy page, there needs little imagination, to combine drawing C and D (cutted version) and multiply them with each other and there can see ...
https://www.google.ee/search?q=kaheksak ... 59&bih=987
Estonian national flower "Centaurea cyanus", has many similarities to some MT drawings (like MT 60,61,114,137), but not only ...
It seems that this flower, or very similar one, have represented also in the header of AP, but not only ...!
https://en.wikipedia.org/wiki/Centaurea_cyanus
Estonian national bird "Hirundo rustica", have a V-shaped tail. Witch "can" represent roman number 5, but not only ... (he is also quick and nimble:)
https://en.wikipedia.org/wiki/Barn_swallow
All those are "visually" very similar things, which are represented inside my working wheel! But also have a lot of similarities to Bessler clues.
Thirdly, In original native Estonian language, who do not know, Estonia is called or named "EESTI" (Estonians are Eestlased)
https://en.wikipedia.org/wiki/Estonia
It is already like hidden language, witch only some small group of people can talk and understand. (So they can hold some secrets in it :)
When compare this name here with Bessler add names, Ernst and Elias. Name Eesti, have some similarities here. Name EESTI also starts with letter E, which can or may represent also number 5. As E is 5-the letter of the alphabet. Actually, there are two E-s in name Eesti. so it is like most talked number 55 here?!
But there are also five letters in word "EESTI". So there is three-time five. 5, 55 and 555. As John C. have found them in different places.
Also "EV" which means Eesti Vabariik - Estonian Republic, here is like "Greek and Roman" nr. 5, side by side ... There is too many different fives in one place.
Fourthly. Strangely I found the solution exactly at Estonian anniversary day 24 Febr. Is there any hidden message in that?!
I know that this all looks and sounds crazy and unbelievable?! But it is also crazy to hunt here "a thing" which are said to be impossible.
As I have said a lot of times before: All this will be visible only after you have seen inside the working wheel. Is here some connections or not, time will tell! I just wanted to bring out this information here.
Anyway, Estonia is a very good inspirational place to hunt exactly this secret.
By the way, here in one topic. If combine there posted different replayed information. There are visible almost all main visuals, that needed to build the wheel.
PLMKRN
sleepy
re: Possible "it"?!
Post by sleepy »
Congratulations.
But we already have a few members with working wheels. So if you are not willing to prove it by showing your working wheel, you are just one of the many to make a claim.
re: Possible "it"?!
Well that it then, we are all migrating to Estonia.
Bessler was from that country, we have been duped :-)
Mind you Romania looks interesting.
