The forum is back!
scott
Site Admin
Site Admin
Re: The forum is back!
Post by scott »
Thanks everyone for the offers of support!
There is now a "Donate" button on the main menu bar that hopefully works and will help make it easy.
Thanks again to everyone who helps make BesslerWheel.com a special place!
-Scott
- Pierre Proudhon, 1881
- Michel de Montaigne, 1559
- John Milton, 1667
The donate button works Scott. Thanks again for your efforts !
Thanks Scott. The forum looks great.
With the new forum one can edit any post.
Try it. Edit your first post.
WaltzCee wrote: Sun Oct 03, 2021 10:03 pm With the new forum one can edit any post.
When I found out it gave me the opportunity to correct spelling and grammatical mistakes. Only 2,400 post to go.
P.S. It would be interesting if you can edit other members posts.
If you sit at the system console you can.
This is twice and you fail to get the point. It is futile to discuss someone's ideas if they can come back later and alter their past comments.
scott
Site Admin
Site Admin
Post by scott »
You can only edit your own posts.
You could edit your own posts on the old forum too, but only for a limited amount of time. Should I add that restriction here too?
Thanks,
Scott
- John Milton, 1667
I think you should, Scott. Otherwise you give duplicitous bad actors the ability to alter context with stealth edits.
Yeah .. we've seen that before Scott. They change the context and then try to make the other guy look the idiot. Pathetic as it is.
scott
Site Admin
Site Admin
Post by scott »
Ok, for how long? An hour? A day? Something else? I honestly don't remember what it was before.
I could also look into adding this extension: https://www.phpbb.com/customise/db/exte ... dit_log_2/
It was 24 hours Scott. If you are like me I write what I'm going to say on the fly in one hit, thinking as I write. I don't write it in "MS Word" for example as jim_mich sometimes did for involved detailed posts, and then edit, clean it up, and paste it. Often this is in the morning for me, with time constraints, and then I have a coffee or two and do some other work. And coming back a little later I sometimes read what I wrote and decide it could do with some cleaning up to be more readable and on-point. So I would say a 3 or 4 hours of grace would be ample, but 24 hours was ok, imo.
scott
Site Admin
Site Admin
Post by scott »
Ok thanks for the feedback, Fletcher and Walter. I'll make it 3 hours.
I also made it so you only have 5 minutes to delete a post entirely.
-Scott
TEST EDIT
Thank you & you're welcome.
I've seen some forums where a new account had to make several posts before they could post a link.
A feature like that might run off the drug pushers.
Great idea Walt !
scott
Site Admin
Site Admin
Post by scott »
Fletcher wrote: Mon Oct 04, 2021 9:53 pm Great idea Walt !
I've already tried to solve this problem with this extension but it did not work as advertised.
https://besslerwheel.com/forum/viewtopi ... 97#p183397
TESTING EDIT
