Theorising Bessler's `Excess Weight`
Re: Theorising Bessler's `Excess Weight`
Tarsier 79 That surprises me. I would have expected that the one farther out would have a lot more torque--------------------Sam
PS To carry the idea one step farther, Bessler mentioned a grind stone. A grind stone would be like a heavy roller, right, but maybe I'm reading to much into it.
Follow up.
Follow up. Didn't Bessler say that the devil himself couldn't lift it, the wheel. The devil could lift a lot, couldn't he? Maybe Gill Simo is on to something here, with this idea of "Excess Weight"-----------------------------Sam
So it all comes down to finding a way to get the roller to climb the hamster wheel.Sam Peppiatt wrote: ↑Mon Sep 05, 2022 6:57 pm Yes, Yes, argo, that's it, a little bit like the hamster effect. My notion is; the wheels had constant torque. A heavy roller would do that. It would drive the wheel continuously. The question is; how to drive the roller, how to replace the hamster----------------------------------------Sam
I have put two idea so far. Not the best but better than nothing.
The Bessler's slip-gear is still a possibility.
agor, A better picture is the one you posted on July 3rd. See topic, by Bill Mothershead, WM2D Simulations, not to say the hamster isn't great. So how would you drive the roller---------------------------Sam
Just having a laugh. power to the hamsters ;)Sam Peppiatt wrote: ↑Mon Sep 05, 2022 10:37 pm agor, A better picture is the one you posted on July 3rd. See topic, by Bill Mothershead, WM2D Simulations, not to say the hamster is great--Sam
The image with I and H for hamster of cause.
The teeth on the H component need to be on the outside.
Then designed to fit into the hamster cage.
Very fine design work is required to implement the concept.
P.S. This is nothing like Gills thread. It's more like the T. Turbine thread - really.
agor, Yes that's it--------------------------Bessler's wheel? Maybe--springs; I don't know. How about a pendulum? Yes, a pendulum to drive the roller and the roller would drive the wheel. How's that for a bull sh*t theory--------------------------Sam
Last edited by Sam Peppiatt on Mon Sep 05, 2022 11:08 pm, edited 5 times in total.
I have been trying to get my head around the slip-gear geometry for some years.Sam Peppiatt wrote: ↑Mon Sep 05, 2022 10:50 pm agor, Yes that's it--------------------------Bessler's wheel? Maybe ----------------------------------------Sam
Maybe there is someone more skilled than I can progress the implementation.
The concept is simple the inner wheel is the 'H' component and the 'I' is the outer hoop.
When the 'H' drops down the teeth slip to the right causing the outer hoop to rotates clockwise.
Hopefully to the point the next part of the slip-gear slides and on.
agor, it must be the other way around, the i is the inner wheel------------------------------Sam
PS Don't you see? i the inner wheel / gear would slip in one direction. When the inner gear turned the other way, teeth on H would engage the slots in the outer i ring and, lock up so to speak. Then both would turn together. In other words as i turns it would "slip" one way , but grab the other way. Like a one way clutch.
Agor,
Pour ce que vaut Algodoo.
La roue tourne en sens antihoraire
For what Algodoo’s worth.
The wheel rotates counter-clockwise
- AGOR1.zip
- (28.93 KiB) Downloaded 180 times
It would be a good clutch or latch like device.Sam Peppiatt wrote: ↑Mon Sep 05, 2022 11:18 pm It must be the other way around, the i is the inner wheel. Like a one way clutch.
When you think about one rolling inside the other. You may see why I reversed their interaction.
Thank you
SHADOW, The roller and or wheel, could turn either way, couldn't it? Which would make the wheel easily reversible, if that means anything----Sam
Last edited by Sam Peppiatt on Tue Sep 06, 2022 12:57 pm, edited 2 times in total.
SAM,
tel que réalisé ca tourne mieux en sens antihoraire, il se peut qu'avec un arangement intermédiaire cela tourne dans les deux sens.
mais c'est une réalisation Algodoo donc pas fiable.
As realized it turns better in counterclockwise direction, it is possible that with an intermediate arangement it turns in both directions.
but it is an Algodoo achievement so not reliable.
