Sam Peppiatt wrote: ↑Tue Jun 20, 2023 1:16 pm
johannesbender,
jb, the rollers / discs are the "Short Cut" you need to lift the weights back up. With the aid of the toggles of coarse--Sam
Sam , up next is an example and explanation of the next problem i had to solve , this one took me most of a year to come up with a solution i thought fits the requirements.
While the principle to skip the distance lifts from the the outer to the inner radius and from the inner to the outer radius was solved for me , another problem presented itself.
If the arm at 12 o'clock were to follow along the outer radius as the weight's torque drove it towards 6 o'clock in a CCW direction , and if i drew the arm at angled intervals , as drawn in the image , the arm along with the weight would end up at the bottom of the outer radius , so this problem as can be seen is obvious.
If this was to be a solution of how to lift the masses in to position , then suddenly while it seemed brilliantly solved in the previous instance , it actually turned out to have been unsolved and stupid 180 degrees further in this instance lol.
I thought and thought for month after month how to solve it , i cant rotate the arm that would take a massive amount of energy to torque them around , i cant cancel their torque that seems impossible because i cant juggle around with another weight added to cancel and then disappear from the system , i could only find one free solution for how to lift the mass now back to the top of the arms problem.
Which is this example i have drawn out , instead of trying to use energy i came to the solution that the mass must drop/fall from the bottom of a top arm like at A , to the top of a bottom arm like at B, and presto the lift would be accomplished by another free gravity solution , which again is like saying the mass climbed by falling.
But....its not the end of problems ...again haha.
