Hey, thanks for that ST ..Silvertiger wrote:Here you go Fletcher: https://www.youtube.com/watch?v=4NkKb0w ... tu.be&hd=1
So the Sys CoM does drop a bit though only a very small amount. That does represent a loss of Sys GPE at the nadir of its travel path. BUT that only holds true for when gravity is turned ON.
As you've said earlier and multiple times it works equally well with gravity OFF and so this insight from you throws the weight force unbalanced oscillator prime mover clear out the door even though the mass distribution about the axle is not entirely evenly spread it appears, else the Sys CoM wouldn't move from the axle position the slightest.
And if this 'works with gravity OFF' is indeed the case as you've said, then metering and knowing the GPE loss (when gravity is present) to compare to the Sys KE is of no forward value me thinks.
So that takes us back to your original description of "Motion from Motion', or as you labeled one of your demonstrator sims "Motion Engine With Load" as the prime mover.
The fact that the various models rapidly accelerate (as per the previous velocity profile shows), and the Sys KE very rapidly builds, is another clue to its inertial operation and root cause.
I just for the life of me don't know how you managed to automate the actions required in your sims from their own inherent motion and actions, so that no further inputs or fake force interventions were required at critical times within the closed loop, to get your sim performances you demonstrate.
I guess that is why you rate your creativity at savant level (not being facetious) because it appears that you by critically thinking thru the problem have found a way to not cheat in sim world and in the process discover a new class of lever to achieve spectacular System KE gains, specific mechanics to close the loop unknown to others.
BTW watching the Sys KE build on the Lever and launched Loads would be something to watch.
Looking forward to your real world build updates and testing of your 'Motion From Motion' Prime Mover Lever etc.
