Zeroing in on Bessler's wheel
by Sam Peppiatt » Wed Dec 22, 2021 1:15 pm
The weighted lever drives the wheel continuously, and since the effort point is always changing position, it never becomes bottom heavy, like it would normally------------------------Sam
I also using a weighted lever, but during the motion I do both, I increase the weight on one side and decrease the weight on the other side.
This is being done by simultaneous motion of the weights during the rotation.
Is it safe to say, no one has figured it out yet?
I would not bet, Sam.
Maybe my version is different to yours, but the motion is simular to yours, as you described it.
You don't need to put the motion into a wheel to show the ground element of the motion.
To put the motion in a circular motion was a challenging task, because everything is on motion.
Hi George!!
Yes it's a SOB! The problem I have; I get an idea, that I think is good. So, I cobble something up to see if it is worth building it, or not.
Usually it looks like it will work; great, I say! But when I build it, it never does.
Sounds like you are going to get it Georg; I hope so. I long to be rid of it-----------------------------------Sam
FWEIW,
I see now what I was doing wrong. The big pendulum that I had near the center, becomes another weighted lever, a horizontally weighted, lever. It is similar to the pair of levers shown in MT-143, which are connected to gether by gears. This should keep the out board arm constantly horizontal, as the wheel turns. If so, the wheel will be constantly OOB.
That should do it; but as always have to try it and see------------------------Sam
Return to page 9, Tareier79, for MT-143
Gravity is a harsh mistress. She has specific rules we have been unable to break. Nearly everyone here started their journey trying to move weights horizontally on a wheel, like the Baskara wheel.
Fact: Gravity doesn't care about horizontal movement. It takes the same energy to lift a weight vertically 10cm as it does pushing it up a 5 degree ramp till it reaches the same 10cm height. The same happens in reverse when harvesting gravity. Potential energy is a mathematical measurement soley based on how high the weight is.
Moving a weight horizontal, or keeping a lever horizontal cancels out any advantage the lever has. It hasn't gained or lost any height compared to the pivot/start point. If you keep the lever horizontal through rotation it drops the same amount as the pivot point.
Every time you lift a weight it takes energy, usually from wheel rotation. Whenever a weight drops you can harvest that and put it back into rotation. No matter how you lift or transverse a weight on a wheel, the weight ultimately moves up as much as it moves down. With a pure gravity OOB wheel our game is over before it begins.
The theoretical way to overcome the confinements of gravity on a "wheel" is to either lift a weight lightly, or drop a weight heavily....
Robinhood46
Post by Robinhood46 »
Tarsier79 wrote: Thu Dec 30, 2021 8:41 pm
I think you need a bit of both.
I'm having difficulty creating a sim, but it's looking good.
If you number the 3 sections of apologia 1 2 3 clockwise.The small weights swing between 1-2, 2-3 and 3-1, back and forth. The larger sections of apologia, are 90°, which is a small weight falling a quarter. the heavy weight shoots up in a flash because of the falling small weight. The heavy weight moves from section 1 to section 3, then 3 to 2 and and then 2 to 1, and so on. There are only two 4 pound weights for the three 1 pound weights. The 4 pound weights never leave the descending side of the wheel. The force of them being raised is pushing the wheel clockwise and their descending mass is also pushing the wheel clockwise.
Algodoo is not being nice, so you will have to be patient for a sim. The general picture is the three weights near the rim swinging back from 7.30 ish to 6, because of the rotational progression of the wheel. Then they fall from 11.30-12 to 4 ish, which shoot the heavy weight from about 4.30 to 1.30 passing very close to the centre of the wheel at 3. The heavy weights take the path of a diamond placed vertically next to the central axle.
Edit; there is only one weight for the three small ones, not two.
Fletcher and @,
What can I say; I've tried very hard to explain it; I get the feeling no one is listing----------------Sam
I think most enthusiasts are like me Sam .. we listen and read everybody's posts (not always in real time given time differences etc), with a few exceptions.
Like me they are probably not always able to offer constructive comment, on every post, so don't say anything that might dissuade someone from doing experiments etc. Sometimes something just doesn't pop out at me and say this is how that problem can be fixed. Sometimes it does and I usually contribute then, if someone hasn't got there first.
FWIW I'm always listing after a few beers ;7)
Happy NY to you Sam, and everyone.
Right,
N' Zed, you get there first, right-----------------------------sam
LOL .. it's a myth probably spread and perpetuated by NZer's. In fact Gisborne people (an east coast small city) where I grew up still claims today to "see" the light of a new day first in the world, to make it worse. It'll be spreading like a virus tonight, being NY's eve here.
So I had to go one better and I moved to a new country, and larger city for a while - Suva in the Fiji Islands. Check their longitude and the international date line coming down thru the country if interested. At one stage not too long ago an Island Taveuni was on one side, and Savusavu on Vanua Levu the other, tho the land was just 20 mins by apart by fishing boat (10 miles as the crow fly's thereabouts). Somebody had the eventual wisdom to change the date line and bring all the main Islands onto the same date by making the date line bend around Taveuni.
And if you goes smaller than city's or islands well ...
by Tarsier79 » Thu Dec 30, 2021 8:41 pm
It is being done simultaniously.
The impact/hit will make a wheel on one side heavier
and on the other side lighter,
A pendulum will variate the force on the suspension point.
So some times the suspension point has to carry the full weight, and sometimes not.
When now the suspension point is wandering upwards you can lift the pendulum easier.
Robinhood 46,
The 4 pound weight never leaves the descending side; how is that possible------------------------------Sam
Robinhood46
Something like this.
Well sort of, something like this that actually functions.
https://youtu.be/gW7_mp4FjH4
Tarsier79 wrote:Gravity is a harsh mistress. She has specific rules we have been unable to break. Nearly everyone here started their journey trying to move weights horizontally on a wheel, like the Baskara wheel.
I think it is encouraging that more and more of us are looking beyond the "pure" gravity OOB wheel. We might look backwards now and again but in our hearts we know it is not the full story and we must turn again and face forward .. aka there is more to it to find. Defining what is missing is the hard bit.
I also think the first step in that process is what you describe Tarsier .. it seems logical - lift a weight lightly (or with less effort/cost) or drop a weight heavily (or with more force and velocity i.e. speed and KE). Assuming there is no external energy input that needs replenishment, or a harnessed environmental force (a nod to ECC1), we are left with scant "internal and in-situ' candidates to finally generate a surplus of wheel momentum (the gain). Interestingly Wolff was of a similar persuasion to your suggestion, which I in part quote below ..
Letter from Christian Wolff to Johann Daniel Schumacher, 3rd July, 1722
... But the force which drives the weights, does not come from the machine itself, rather it comes from some fluid, invisible matter by which the movement of the falling weights becomes faster and faster. Orffyreus' whole invention consists of an artful arrangement of weights, in such a way that they are lifted when at rest and acquire force during their fall, and in my opinion it is this that he keeps secret. This is also consistent with what Orffyreus says, that anyone could easily understand his invention, as soon as he is allowed to look into the wheel.
3. It is possible therefore, that when the internal structure of the wheel has been revealed, some mathematicians may decide that it is not a perpetual motion machine as there is an additional force involved, namely the unknown substance which applies continuous pressure to heavy bodies when they fall, and which adds to the force of their impact...'
I bring you to what B. actually said about his wheels in one of his most famous and well-known quotes ..
John Collins DT pg 190 hardcopy :
Johann E. E. Bessler, 1717 - "Unlike all other automata, such as clocks or springs, or other hanging weights which require winding up, or whose duration depends on the chain which attaches them, these weights, on the contrary, are the essential parts, and constitute the perpetual motion itself; since from them is received the universal movement which they must exercise so long as they remain out of the centre of gravity; and when they come to be placed together, and so arranged one against another that they can never obtain equilibrium, or the punctum quietus which they unceasingly seek in their wonderfully speedy flight, one or other of them must apply its weight at right angles to the axis, which in its turn must also move."
Imo the key difference to 'light up - heavy down' philosophy is imo .. 1. that B. is saying that equilibrium (of forces) can NEVER be achieved (he never says directly the how), generated from the weights movement (undefined) .. 2. He seems to be saying that the weight-force (of a weight - and invariable) is applied on the down-going side of the wheel causing the axle rotation as a result. We tend to associate these two things together. 2. is self explanatory, 1. is far from it, and the crux of the matter imo.
Of course his words are difficult to fathom, they were intended that way. Some may interpret them as (as did Wolff) that the weights fall on the down-going side with greater speed and energy, transforming into a gain in wheel momentum. Wolff attributes this to an unknown internal pervading force adding to impact force. Smart guy Wolff, as just about no-one else offered any coherent theory but him.
I tend to dial it back a notch with a more cautious hypothesis. That reading B's. quote above in the clear light of day that his mechanical arrangement of weights etc 'in motion' were the cause of wheel momentum gain. And that the weights and wheel was continuously out of CoG (i.e. OOB). Meaning that the weights in motion could not achieve an equilibrium of forces (torques) which kept them swinging on by bdc and replenishing their GPE, imo !
Doesn't seem too different from 'light up - heavy down', both requiring a 'mysterious' force. And which Wolff arrived at.
I suggest that that excess force was an asymmetric torque (no surprise there) that was generated on the down-going side of the wheel. But importantly it was not a 'normal' torque from periodic weight displacements usually associated with a 'pure' gravity wheel where these torques balance out i.e. are symmetrical in nature. I would could call it more akin to the idea of in-situ 'force double-dipping' rather than Wolff's strict addition of a mysterious force, imo. Food for thought !
cloud camper
Post by cloud camper »
Hey Fletch - great post.
Just wondering how you feel this "mysterious" force could be anything but CF?
B showed the effects of CF in MT142, in the document that was only going to be shown to students and never published.
So it's hard to imagine you are alluding to anything but CF!
Trust me, gravity is a lot easier to harness, than CF. I tried it for 40 years. Thank god for John Collins!! He, or at least, his book, got me off of it. I don't think it can be done, but what do I know-----------------------------Sam
