Here it is Fletcher.
- WM2D air resistance.wm2d
- (10.97 KiB) Downloaded 1 time
Here it is with a few mods - all I did was add some vectors ( acceleration and air force ) on the green top weight 23 gms - n.b. the red force vectors sometimes work and sometimes don't show on screen in my program .. have a play ..
Bottom line - metering the Acceleration and adding some other metrics it went from OU with air resistance ON to behaving how the physics says it should i.e. stops before going over tdc .. so looks like a bug which wakes up when you start some metrics .. cheers ..
- WM2D air resistance1a.wm2d
- (14.47 KiB) Downloaded 1 time
Ok cheers Fletcher it just goes to show that simulators can be tricky.
