Zeroing in on Bessler's wheel
Some things are working.
The rollers are working, the cross-bar is working, and the crank shaft is working. All working nicely. I tried a weighted lever hooked directly to the crank shaft,(on the center line). It try's to go but, produces a reverse torque and every thing stalls out.
I think the problem is; it can't be on the axes of the wheel. Maybe, if it was away from the center of rotation it would do better. I'll try three spur gears, one on the crank-shaft, an idler gear,(to reverse rotation), and a weighted lever / pendulum on the other gear.
Not sure if it will work, nothing ever does,(the wheel that is)---------------------Sam
ETA, If the wheel turns CCW, the crank-shaft, rotates CW,(with respect to the wheel), but remains stationary with respect to ground.
A follow up,
The pendulum or weighted lever, is like a small gravity motor. The 'Idea' is to use it to rotate the crank-shaft, which moves the cross-bar; then it shifts the rollers to one side. The rollers of coarse, turn the wheel. The gears are needed to get it, the pend., away from the center of rotation.
Maybe that will make a difference----------------------Sam
Fletcher has just given me an idea!
Put a long roller chain around both rollers,(with sprockets), and drive them with a sprocket / pendulum in the center. At least it would be very thin and, would be easily reversible. If the rollers were thin, that is--------------Sam
The new wheel.
There will be two drums, each drum will have it's own crank-shaft to rotate the rollers. Each C-S has a sprocket. The cross-bar is no longer needed, it can go away. A big pendulum in the center with a sprocket, drives the crank-shafts with roller chain. If the wheel and rollers turn CCW, the pendulum turns CW with respect to the wheel. So; to get the rotation right, the roller chain has to loop up over the top of the center sprocket. To say it with different words, it, the sprocket, has to drive the back side of the chain, to reverse the rotation.
Hope fully this will eliminate the problem of equal and opposite torque------------Sam
I screwed up the rotation.
For the wheel to turn CCW, the rollers have to shift / roll to the left. To do that the crank has to rotate CW; (the same as the pendulum). The chain can hook up in the normal way.
I claim to be only half assed right half the time---------------Sam
An "Idea",
All day long I've been thinking about a double pendulum. The drive pendulum, (for driving the crank-shafts), would mount onto a 2nd pendulum to counter balance the weight of the first one, or drive pendulum. It seams like the best and, probably the only chance for success.
The roller chain would have to lengthen and shorten by some amount as the wheel rotates, (some how)----------Sam
Last edited by Sam Peppiatt on Wed Jun 05, 2024 11:09 pm, edited 2 times in total.
Looks like the two pendulums can't be together. That was a bad idea. However, two pends. may still be a way out of the problem. But, they do have to be separate from one another. One would shift the rollers in the usual way,(for rotation).
Then the idea is; the other pendulum would shift a weight continuously,(somehow), to up set the balance of every thing, maybe-------------Sam
It's a real SOB to resolve.
I think I've figured it out, then again maybe not--------------Sam
Last edited by Sam Peppiatt on Sun Jun 16, 2024 10:47 am, edited 2 times in total.
I'll take another stab at this.
My idea is to raise the cross-bar up to the center line of the wheel, to provide a simple way to displace the rollers. Normally the cross-bar is below the axle. There would be a big pendulum at the center, similar to MT-13, with a pin say to the left of it's pivot point.
The center of the cross-bar would rotate on this pin and would shift the rollers to the left for CCW rotation, when they are horizontal. The ends of the cross-bar would need a slot,(90 degrees with the bar), so the rollers could shift back and forth when it is in a vertical positions. At which point they would return to there balanced position.
For every 90 degrees of rotation the wheel would go from balanced to OOB and then
back to balanced. OOB when the bar is horizontal and balanced when it is vertical. But, I'm still looking for the hook----------------Sam
ETA The slot might have to be curved.
Hi Sam. I applaud you for your continued efforts. Nice work.
Hi Tarsier!!
Well, we'll see. If the 'slot' will work, the rest of it should be OK. There are some good things about it, great simplicity for one. However, it does sacrifice torque for about half the time. Maybe that's what you have to give up in order for it to work---------------Sam
I'm getting a better picture of how it will work. Like so:
The cross-bar simply reciprocates back and forth. The nose of it, (there won't be any slots), will just push the rollers out to the down side. On the up side they roll back in to the center, to there balanced position.
OOB going down and balanced going up; how much simpler can you get than that--------------------Sam
The Ring & Rollers,
The most novel feature of the invention is it's ability to restore GPE automatically and continuously. A here to for unknown species of machinery, thought to be impossible.
Still have to try it out but, that's the way it's shaping up-----------Sam
Bonjour Sam,
nous attendons avec impatience vos résultats, j'admire votre obstination!
Hi Sam,
we look forward to your results, I admire your stubbornness!
Hi Sam,
Hi SHADOW!!
As usual I'm getting ahead of myself. But, have to pump it up, for the work ahead. The worst part has been trying to find an easy way to displace the rollers. So simple once known.
Thanks SHADOW for humoring me and my BS------------------Sam
