Polymath
re: Polymath
If I was you I would go with I lied, there is secret parts not on the table at this point. As you are already a known deceiver, manipulator and liar, no use in looking as you aren’t a big headed polymath.
re: Polymath
Being ignorant of the details never stopped your trolling statements about gravity wheel belief being wrong. Such is the nature of a wrong belief to hold double standards.jim_mich wrote:But you trolls say my principle is fantasy and a wrong belief, while you are ignorant of the details of the principle.
re: Polymath
Jim: This is a picture of my latest wheel. This is the whole wheel. Nothing more. Nothing less.
Jim: Obviously I need to cut the pipe, glue everything together, and then fill the assembled piping with water.
Jim: Adding salt is not required if the wheel is protected from freezing.
Jim:The rotation of the assembly and the flow of the water within are the only moving parts.
Jim: once the wheel is filed with fluid, it is sealed tight.
Come on Jim we are not fucking retarded; an incompressible fluid is not going to CF and race around a balanced wheel. You can’t get CF movement unless the fluid compresses. You can’t cause a vacuum unless it the fluid compresses. You can cause CF pressure but that’s all and pressure in water is like stress in a solid. Just admit your wheel failed and be on your big headed way.Jim: The pipes are as close to 100% full of water as possible.
Daxwc, it is obvious that you are indeed fucking retarded.daxwc wrote:Come on Jim we are not fucking retarded, just admit your wheel failed and be on your big headed way.
http://www.besslerwheel.com/forum/viewt ... 174#120174
At the time this wheel was tested, I went on to speculate why this wheel did not work as expected.Jim_Mich wrote:This particular configuration of my wheel does not work.
About a month later, the thought suddenly came to me as to actually why this fluid wheel did not work. It was not excess friction. And on a number of occasions I've explained that the wheel was missing a specific feature. Without the specific feature, such a fluid wheel will never work. And such a feature is NOT an electric pump, as some trolls have speculated.
Daxwc, you don't know what you don't know. In other words you are ignorant of specific facts. Ignorant means you lack knowledge of certain facts. Saying so is not derogatory. I'm ignorant concerning brain surgery. Everyone is ignorant to some extent about something.
But you, daxwc, seem to be retarded concerning your own ignorance.
re: Polymath
I am smart enough to know you are as frantic as five legged dysentery trench cat burying shit.
That specific feature whatever it is isn't going to help your locked up fluid wheel. It may as well be solid brass flywheel. You already said it was because of angles anyway, but go ahead and deny. The concept is fatally flawed, not just the design.
re: Polymath
I do know you don’t have a running wheel. Jim, you were convinced you had the solution before you built the last one and you were wrong. You will be most likely wrong with the fix too. “Before finally finding the solution to perpetual motion� in your polymath list should be changed to “Before finally finding the solution to perpetual motion wheel fantasy concept� because that in truth is really what you have. Unless of course one wishes to be known as deceiver, manipulator and liar.
I can just about imagine what else in that list is stretch of the truth.
I still can't believe you thought that fluid wheel would rotate in the first place. When all else fails there is always delusion.
Re: re: Polymath
Yes. And the monkies have been flying excrement and DNA all over the place. Monkies are as monkies do.ovyyus wrote:Every monkey thinks he's special.
I think some monkies need to be spanked. I'd step up to the plate but I think they have a spank wish. They need it but then they want it two! Well, I'll be damned if I'll give them what they want. Even though they need it.
I'm sure I'm going to fail, yet I'd like to focus this thread on the blue within that quote. I think this is where we need to be looking. You Sampsons and Einsteins can do as you please, yet this is where I'm looking.And Bill once again raises his concept of "something that works". He fails to understand that before one can build a working PM wheel, one must find a concept, a method, a principle, a something that works. In other words, step [A]. The designing a simple cheap working POP (proof of principle) sample model is step [D]. But Bill is too ignorant to understand such things. And he keeps harping about "something that works".
As if you monkies aren't doing similarly?Once again we see JM resorting to silly name calling in an effort to avoid rational discussion about his wrong belief.
Well, let the excrement and DNA to continue to fly.
re: Polymath
Spoken like a client's monkey :DWaltzCee wrote:I think some monkies need to be spanked.
re: Polymath
Aside from the usual compensation, I'm hoping for a bonus. I want a bit of song and dance from my client.Spoken like a client's monkey :D
Here's to mud in your eye.
https://www.youtube.com/watch?v=ZyFT_oo42iw
re: Polymath
I know the answer Jim; the perfect plan. Start your own forum and leave this one. I will even join, just so you can get the satisfaction of kicking me out. This place is just full of idiots anyway. They are not worthy. Probably others would join to be kicked out also.I fear Fletcher is gone from the forum, most likely fed up of the trolls. As are a number of other forum members. Harassment of forum members is uncalled for. Scott attempted to provide a means for keeping the trolls out, but what this forum really needs, is like other forum have, which is moderators, who can warn trolls when they break the Terms of Use
Oh, by the way over the years I have seen you relentlessly rack people over the coals for exactly the same actions as you’re doing now. I know your special…with that special feature.
re: Polymath
Since it seems all are in agreement to focusing on the blue,
I thought I'd share a PM. Although I'm a solicitor, I'm not soliciting any.
I'll paraphrase the idea. It isn't original because I've had it for some time now. The author suggested we could find an exploit in the difference between competing forces.
aside from a few monkey butt smelling dung and DNA flingers hanging out at Kitty Hawk seeing if it will flyone must find a concept
re: Polymath
Obvious we are all not in agreement and neither does Jim want to discuss it although he probably will solicit it. There is a big difference between having a concept and having a finished product. The Wright brothers were not proclaiming they had a flying airplane after the first time it crashed and that it just needed a special feature and quit.Since it seems all are in agreement to focusing on the blue,
Anyway Walt the thread is on whether Jim is a polymath if you want to pay that much attention.
cloud camper wrote:Well don't punish the rest of us because of one lying, lazy self absorbed narcissistic polymath!
So you think I'm lazy and that I just quit?daxwc wrote:The Wright brothers were not proclaiming they had a flying airplane after the first time it crashed and that it just needed a special feature and quit.
A lazy person does not build a whole house by himself. A lazy person does not work 50 hours a week for twenty year so that his family can have a good life. A lazy person does not quit after building a dozen of failed wheels. A lazy person does not quit after finding a true principle, a true PM solution, which simply needs verification. A lazy person does not stop building, even when he has a broken left arm that takes 6 month to heal rather than the normal one or two months, then a broken right arm that take 9 months to heal. Why is did his arm become brittle and slow to heal? And why was this so-called lazy person so dead-ass tired all the time?
But when a wheel builder can no longer walk 20 feet without stopping to rest, with his heart beating at maximum, and gasping for air, THEN I suppose he suddenly became LAZY ???
Sure, my weekly blood transfusions are building up my strength. And if all goes well, I'm sure my lack of so-called laziness will cause my PM wheel to get finished. Or I'll contract an infection and be unable to fight it off, or develop an allergy to other people’s blood, and then die a slow agonizing death. My lack of physical stamina was developed over a period of about fifteen years, caused by DNA mutation as a result of breathing toxic industrial cleaning solvents while working my ass off. It will take time to grow stronger again. My bone marrow no longer makes enough red blood cells or blood platelets. Each week, as my red blood cell levels drop, I have trouble getting enough oxygen which limit physical activity. And as my platelet counts drop, my gums start bleeding, and I pee blood, and any little scratch stops healing. Each week I get transfusions. This is to be my life, for as long as I live.
But obviously, according to you a-hole trolls, I'm lazy. I don't like baring my personal troubles here on the forum. But your ugly troll lies that continually claim I'm LAZY really bloody pisses me off.
Yesterday, I literally and figuratively bit my tongue. My tongue will heal slowly. But you trolls calling me lazy is an out-right lie. Temporarily incapacitated would be more truthful. Down but not out maybe. But LAZY. No way. No how. Never have I been LAZY.
PS. I've found the part in blue, the concept, a principle, the something that works, so as to cause perpetual forceful rotation of a rotating wheel. I simply need to keep gaining bodily strength until strong enough to resume building and finish that which I've started. Contrary to those claiming otherwise, I'm not lazy. And I'm not about to just give away something that should be worth millions of dollars.
PS. What good is being a polymath if you can't help people, like MrVibrating, who was having trouble getting his pictures to show, over in the Poss. Symmetry Break thread?
- cloud camper
re: Polymath
One would expect an actual polymath to have some familiarity with the Scientific Method, which requires EXPERIMENTAL EVIDENCE to confirm a hypothesis.
But since our polymath seems completely unaware of the process we will have to educate him on how the Scientific Method actually works.
Per the Scientific Method one is not allowed to make conclusions and claims in advance of procuring experimental evidence.
This is LAZINESS and DISINGENOUS BEHAVIOR in any form of science.
If one cannot produce experimental evidence, the hypothesis remains pure CONJECTURE and has no scientific value whatsoever.
Our polymath has had 10 years to produce experimental evidence to support his hypothesis but chosen not to and in fact made completely false claims regarding his testing suggesting he had the expeimental evidence when in fact he had nothing.
When our polymath was then caught lying about his results, he immediately started backpedalling to twist the story so that he was only claiming a “workable concept�.
But a “workable concept� is not known to be “workable� until it actually “works�.
So our polymath is still being LAZY and DISINGENOUS claiming a “workable concept� with no experimental evidence.
It's very sad our polymath has health problems but if he had been working on wheels instead of making false claims for the last ten years, the story might have been different.
https://en.m.wikipedia.org/wiki/Scientific_method
Last edited by cloud camper on Sun Jun 19, 2016 5:58 pm, edited 12 times in total.
