Decoupling RKE from GPE, for fun and profit
re: Decoupling RKE from GPE, for fun and profit
Mr V .. going back to your post 7 back.
Here's the rub that continually raises its ugly head for me.
Many off us started out looking for Gravity Only scenario's for Bessler's wheel, with zero success. Physics just doesn't allow it.
A few of us decided that Motion Wheels were the way forward and looked to inertia for an answer.
BUT .. John Collins was always adamant that JB's wheels were Gravity Only. He has never wavered.
Then along came Oystein (one of the demonstrably smarter ones here) after abandoning his personal search who put his energy and intellect into deciphering Bessler's codes as did JC. He also said that it was a Gravity Only solution.
I went back and pulled these quotes from him on JC's blog. [Bolding mine]
Oystein wrote:
Øystein 6 September 2015 at 16:19
I understand what you say. I believe the math is the hardest part. Because you are in unknown territory. I have tried to identify the "loophole" by math. I have an idea, but no finished formula yet. I have spent many years calculating mechanical forces, and even Relativity for a while. I have found only 1 single possible loophole through these years! So far it seems like this kind of mechanism could be used to exploit such a loophole. The possible loophole for a gravity-driven vertical machine has to do with the following:
For a system to have any chance of OU, the masses have to fall from a greater height than it is being lifted by the wheel (the wheels torque). Something else other than the wheels counter-torque has to lift them. And it has to do this without springs or stationary objects. It can`t exploit springs, CF nor "swing". So we are left with very few alternatives. The remaining alternatives are in great detail discussed in Machinen Tractate. Where Bessler shows how he tries to make the weights fall from a higher place. This means that it isn`t really the distance from the center that is the goal, but the falling height vs. lifted height. Thus Bessler’s comments about this distance from center. But when I say that a weight has to fall from a greater height than it is being lifted, you can`t accept it as a practical possibility.
It is not that I am confident in what I have found. It is exceptional, solid and true. But, the deeper you get into the matter, his methods and papers you can see that the question of one additional joint appears at the end of the lever-system; this will double or triple the "controlling" force. Think of a scissor jack, but you don`t know if it has 2 or 3 joints. So we have to experiment with the end of the mechanisms. One or two joints? Then, the length/placement/adjustment of the "interconnecting principle" is also unspecified, still it is repeatedly described what it does and what it is. So I am 100% sure of the basics that appears, and why. It uses a method, and a proven system but how to be sure that there isn't one more level, or one more drawing/page that shows one more addition to the system. I have worked on it for several years, and it is hard to say that TODAY I am all finished. That is why I keep working still. I want to be sure that I have investigated down to the last bit.
Øystein 7 September 2015 at 15:01
Sorry that I don`t share your belief. I trust in my investigation into the matter. I found that springs only fool you to believe that you can raise the weights cheaper, while collecting energy in the springs. Though if you add the weight + spring energy it turns out you are even. I believe Bessler’s principle had a root in an overlooked but provable mechanical principle, where both falling, rising and "resting" weights are constantly affecting each other. Not a tiny variable in some refined adjustment. Bessler said that he used principles that can be scientifically proven as PM principles, in the 1700s. To me it tells me that the principle was not of the kind that doesn't work if you use wrong materials or adjust a spring just a tiny amount. It should use principles that can be proven by analyzing it mathematically and "visually", by simple drawings on paper. I don`t say springs could not be used, but not in that way, not as THE reason. This is just my opinion.
So the dichotomy of thought is still there, all with impeachable and generally reliable sources.
I favour the line that it was a motion wheel that had an appearance to an observer of being a series of interconnected mechs that had the outward appearance of being a Gravity Only Wheel but in fact was driven by something else, that likely being inertia leveraging in one way or another.
Pity my mechanical aptitude and experience isn't as good as some here !
jim_mich wrote:Thanks, Fletcher.
Apologies, i should define my terms every post, my bad. But this was the minor epiphany that lead me to the same conclusions as yourself.. only i began by wondering why KE squares with velocity (having previously taken it for granted). The answer is that the net displacement over which a given force must be applied to achieve a given amount of acceleration is velocity-dependent - and the increasing displacement is equal to half the square of velocity; but it is also virtually enforced, albeit indirectly, by Newton's 3rd - if we wanted to continually accelerate a 1kg mass by 1 meter / sec using just half a Joule (because KE=1/2mV^2, 1kg at 1m/s has .5J) - such that each additional half Joule causes another meter per second of acceleration, we'd need to somehow chop out that increasing displacement - half the square of it, to be exact.
At which point, we'd come up against Newton's 3rd law - dragging your reaction mass with you costs everything gained from the reduced impulse energy.
Initially i considered modulating the force with the distance, aiming for equal input / output integrals across a climbing speed range, using fusees. But then it finally clicked that relative motion already modifies effective displacements - a small acceleration in a moving frame is equal in energy to a more protracted one in a stationary frame. Basically, KE is relative along with velocity.
But an input / output asymmetry exploiting this is only really on the table if Newton's 3rd law can be circumvented. We either need an action without reaction, or the same end result by other means. Self-cancellation of counter-forces is a personal fave, and not too controversial either. But evidently, vertical rotation also warrants careful consideration here - if gravity merely provided a cyclic but symmetrical load, it could've been replace by springs in a horizontal wheel. Ergo, vertical rotation very likely plays some role in outfoxing N3..
jim_mich wrote:But if you still don't know (that one pound will only lift one pound) then all your work seeking PM is in vain.
Bessler meant:
But if you still don't know (how one pound can lift more than one pound) then all your work seeking PM is in vain.
Bessler's device was a powered weight driven lever. Wagner couldn't figure out what powered it and Bessler was taunting him. Simple.
jim_mich wrote:So, justsomeone, you have a choice. Stick you fingers in your ears and close your eyes. Or read Bessler's writings with an open mind.
If N3 can’t be outfoxed then read Bessler’s writings with a really open mind. Or you could just close your ears and stick your fingers in your eyes.
@Fletch - there's some room for ambiguity; weights may provide torque, but the distinction between the two types of wheel is simply that of the asymmetry - is it a gravitational asymmetry, or something else..?
As i say, clearly gravity wasn't incidental, even if the GPE workload was energy neutral. If gravity causes an effective N3 violation, many would still call it a gravitational exploit. The only correct interpretation is that given by the dimensions and units of the asymmetry itself...
JC has also spoken of a potential N3 break - one dependent upon an odd number of mechanisms. This is especialy interesting in its implications, if correct... because, if 3 would work, but 5 is optimal, then we can conclude that the asymmetry applies to each individual interaction performed by each mechanism per rotation (each one is a little bit OU), but that the other mechanisms - due to their odd grouping - remain involved in each interaction per mechanism per cycle. Hence 3 is good, but 5 is better. If, on the other hand, it was an asymmetry only manifest by an odd number of mechanisms per cycle (so each interaction is conservative, but their net result is not), then 3 mechanisms would be preferrable to 5 since the extra two strokes would be redundant - it's still only one power pulse per cycle.
Hence if JC has what he currently thinks, it produces many N3 breaks per cycle, rather than one per cycle, and the obvious implication is that it's either rectifying counter-forces, or self-cancelling them (ie. actions and reactions come in pairs so divide unequally between an odd number of mechs)...
So, if he's doing something like this then although the exploit may depend upon gravity, its gravitational interactions remain symmetrical and the actual form of the energy source is inertial.
ETA: as for Oystein's work, like everyone else i guess, i only wish i had anything so concrete to weigh up.. vague descriptions of levers seem to indicate little of the potential asymmetry. I always assumed, when considering gravitational interactions, that d was a closed loop therefore F must be modified. But either way, if the input gravitational F*d integral is smaller the output one then it's a gravitational asymmetry. If they're a zero sum then it ain't.
Re: re: Decoupling RKE from GPE, for fun and profit
ME wrote:Somehow reminds me of this video visualizing the swim stroke of little shrimps.
them shrimp look like they're taken a stroke or 2 forward, then a stroke backward.
hummmm.
Bessler meant:
I knew when I wrote that post I should've included a powered lever option that you promote Bill. One where the lifting is done by replenishable fuel (e.g. alcohol). And of course deception for EC1. These are sort of implied as alternatives until exactly how his wheels turned is proven.
It is interesting that Oytsein also said IIRC that he looked into codes in AP etc with an open mind looking for any confirmation such as Alcohol etc, but didn't find any, FWIW.
Newton's 3rd law is readily disproved.
Suppose you're berry picking with your significant other (and you've taken out a good insurance policy on them). Now you and them are on a high ridge and you ever so slightly bump your butt into theirs and send them head long down into the ravine.
Are you trying to say that that action of bumping them is equal to the reaction of them plummeting to their demise? Not to mention collecting all that insurance?
You're joking.
MrVibrating wrote:@Fletch - there's some room for ambiguity; weights may provide torque, but the distinction between the two types of wheel is simply that of the asymmetry - is it a gravitational asymmetry, or something else..?
... snip ...
I simply pick the middle ground between the two main theories. That it looked like a Gravity Only wheel (which explains Oystein's and JC's beliefs, but not the known physics) but that the real reason for the asymmetric torque was probably inertial thru a force generated somehow.
I don't try too hard to quantify it anymore because I ran out of good ideas long ago. I'm hoping one of you will connect the dots where I couldn't.
FWIW ... jim_mich's Motion Wheel can work in the horizontal plane he says. And that Gravity was not necessary. This seems to indicate to me that his wheel theory is not Bessler's Wheel, on balance, given others thoughts into the matter that I mentioned earlier. I am not a believer in anyone 'improving' on Bessler's wheel to the point that gravity is not required.
cloud camper
Post by cloud camper »
jim_mich wrote:
cloud camper wrote:All proven rubbish many times over as this is just a variation of multiple riders on a carousel trying to coordinate their motion to accelerate the wheel.
Multiple riders on a carousel is indeed a rubbish concept. Such is your concept, cloud camper. It is NOT my concept. Again you are posting lies about me. What is it with you people?
On July 22, 2015, in post #134749, Jim_Mich wrote:If you have a simple flat playground carousel, and you place four riders on the carousel, and nothing else, and let them move as they wish without interconnection to ground, they will NOT be able to produce perpetual motion. I guarantee it won't happen. If such was the case then men would have found perpetual motion long ago.
Take note, these four riders on a carousel do not constitute my motion-wheel.
Shame on you, cloud camper. Stop posting lies. Stop twisting my words.
More rubbish. The Fluid Driven wheel that was promoted as JM's motion principle employed in fluid form was nothing but a one piece carousel with
billions of riders aboard in the form of water molecules.
This is of course an exact representation of a carousel with multiple riders trying to coordinate their motion to accelerate the wheel.
It doesn't work, neither will it work in mechanical form for the same reasons.
The specific physics reasons are perfect symmetry maintained as all height for width exchanges are balanced and no squaring function employed that would allow the wheel to gain energy.
http://www.besslerwheel.com/forum/viewt ... l+jim+mich
Fletcher:
Interesting fletcher because that is where I have been for a few years. I believe it is inertial through a force generated by time differential and CF actually limits it.
Fletcher: I don't try too hard to quantify it anymore because I ran out of good ideas long ago. I'm hoping one of you will connect the dots where I couldn't.
Yet you come up with the most mind provoking potential candidates.
Fletcher:
But has he ever said it can work in the vertical plane?
Cloud:
I don’t understand your argument, help me with it please, is not the acceleration a squared function? Or “Unlike the other two fictitious forces, the centrifugal force always points radially outward from the axis of rotation of the rotating frame, with magnitude mω2r,â€�
daxwc wrote:But has he ever said it can work in the vertical plane?
Yes, the orientation of the wheel makes no difference.
And cloud camper is an idiot. He claims, without knowing the details of my wheel, that it is can't work.
So it begs to ask I guess, Jim can your wheel square its potential energy output?
KE squares by default.. The challenge is to let it rise, from only a linearly accumulating input.. An input discount, not an output bonus.
Oystein wrote: I believe Bessler’s principle had a root in an overlooked but provable mechanical principle, where both falling, rising and "resting" weights are constantly affecting each other. Not a tiny variable in some refined adjustment. Bessler said that he used principles that can be scientifically proven as PM principles, in the 1700s. To me it tells me that the principle was not of the kind that doesn't work if you use wrong materials or adjust a spring just a tiny amount. It should use principles that can be proven by analyzing it mathematically and "visually", by simple drawings on paper. I don`t say springs could not be used, but not in that way, not as THE reason. This is just my opinion.
This is what I've been saying. The principle is simple enough that any experienced engineer will, after studying it long enough to understand it, will be as obvious as dropping a 12 foot board across a 10 foot river so as to get to the other side.
One point though, the principle does not need gravity. Obviously weights riding in a wheel will rise and fall with the wheel rotation. It is obvious that Bessler paired the two weights of one mechanism to two weight of a diametrically opposite second mechanism. Thus the wheel became balanced all the time. When rotated in reverse, such balanced mechanisms loose energy and their weights stop moving and simply ride the rotation. Thus there is no back-torque when rotated in reverse. Add reversed mechanisms and the wheel works either direction
MrVibrating:
Yes, but in Jim’s wheel does the power square as in Bessler’s wheel?
I am just trying to figure out if Jim’s wheel has the same attributes as Bessler’s.
Jim:
It is not obvious to me, that assumption revolves around one ambiguous quote doesn’t it?
