.you wrote:Note the locations of the fulcrum and remove the wheel device in the back and count the weights and their location
There is no wheel at all in the back plane of the animation: the green circle is just fictious, showing the path of the free lozenge summits.
Instead there is only a cross (in yellow) which is essential and must NOT be removed.
Don't remove it: this is the most important part of the assembly, assuming the synchronization between the two centers (fulcrum and COG).
On a mechanical point of view we must attach only one arm of the yellow cross to the wheel and leave free the second one.
I apologize for the small size not really easy for an accurate observation, I will try to make a bigger one.
For the previous point, Richard answered perfectly above.
