Indeed. A twisting force.eccentrically1 wrote: ...
torque is a force.
- eccentrically1
Cloud's complete post can be found here.
I'm sorry but I find you pejorative expression about "jumping to conclusions" makes me feel this debate is becoming unproductive.eccentrically1 wrote:so then it isn't an energy that is generated by a force according to your post I quoted.
yes?
Boys, let's have on mind that they are mounting 18 partial sets!
This is a clue for the device family they are in search!
At least during a small angle each part will ask for a kick!
This is a KE device and this makes me skeptical on the question of energy surplus!
- eccentrically1
How do you know what the bearings are like?Grimer wrote:I'm sorry but I find you pejorative expression about "jumping to conclusions" makes me feel this debate is becoming unproductive.eccentrically1 wrote:so then it isn't an energy that is generated by a force according to your post I quoted.
yes?
How do you know how fast it ran?
How can anyone conclude why it ran down
without any information about the test ?
Re: re: Another claim to a working device...
I don't think it came to a 'screaming halt' [sudden halt], due bearing failure - I think it more likely that it slowed down over time & eventually stopped as the original comments suggested to me.Unbalanced wrote:
Although I like the idea that this monster came to a screaming halt due to bearing failure caused by an asymmetrical twisting force applied to the crank shaft, I fail to see where this force comes from.
It should be self evident [after reaching optimal rpm in a few minutes] that the rpm slows over time until it stops & that no excess torque or energy is accelerating the system, if this was the way it 'ground to a halt'.
We always look for a sure-fire indicator - can the system continue to accelerate without additional energy input & can it's rpm then be stabilized by introducing a load such as prony brake friction - if it can do these things then it is not coasting & is likely true PM.
I am not falling for this hoax. I think they are having a good laugh at our expense. Reports? ????? From who? From a reputable independent source? I think not.
- Unbalanced
Bula Fletcher,
I wish it were self evident to me...
As long as we've nothing to do with this other than speculate;
If the RAR Energia devise had the ability to accelerate from a standstill, why would it eventually grind to a halt, aside from mechanical failure?
I don't see a means of accelerating this thing other than possibly connecting a motor to the crankshaft.
So let's assume it just needs an impulse like jumping on one of the levers. If it accelerated to terminal velocity 9.8m/s/s then I could understand bearing failure.
I was thinking that those semicircular plates might be parts of a braking mech.
I can imagine tightening that last bolt, then running for my life as this thing takes off.
If they invented a perpetual motion device that is powered by gravity, why build it for their processing plant? Why not build it anywhere else. The money saved at their plants is peanuts compared to cheap energy for the world. I think they are just having a little fun.
Jmho. I think it is just part of their processing plant and nothing to do with free energy.
- eccentrically1
The original comment was:Fletcher wrote:I don't think it came to a 'screaming halt' [sudden halt], due bearing failure - I think it more likely that it slowed down over time & eventually stopped as the original comments suggested to me.Unbalanced wrote:
"Right now RAR looks good. In the last 24 hours we have had several positive reports that it has been running for hours on end, BUT finally ground to a stop. ... ."
That doesn't sound like coasting to a halt to me.
