Absolutely, the likeliest answer is that i'm having a mini-breakdown, an if so apologies for cracking up in such an undignified mess..Fletcher wrote:Hey .. grab some much deserved sleep - you've earned it. And you've shared freely and openly all the way along your journey which speaks volumes to your character. Whether you are ultimately right or wrong.
FWIW .. when you are fully rested it might be a good idea to start from scratch again and test each component proposition a second or nth time, that builds to the inevitable outcome you see.
Just to be sure something ain't 'off' in the hypothesis. It's always possible something critical has been missed in the adrenaline rush - besides, often things can be simplified a second time around, or tested in an alternative way, if that's possible.
We'd all like to at the very least see a unicorn, but you can't catch one till you know in which forest to look.
Still can't find a weakness, only seeing further benefits..
Things seem simpler now, though - when the pirouetting ballerina pulls her limbs in and accelerates, their momentum has been conserved, but because that involved acceleration of the rest of her body, that hasn't altered its MoI, the rest of her body has gained momentum.
Now, the energy value of that momentum has been paid - she performed work against CF, spending equal energy to her total gain in RKE.
However that KE was distributed amongst all parts of the rotating system, not just her limbs. And while her limbs didn't change their momentum while gaining that energy (rather, they just changed up their existing momentum for a higher-energy distribution of inertia and velocity), that portion of the KE now manifested in non-radially translated mass has accelerated it, raising its momentum and thus that of the net system.
When she lets her limbs back out, that gained momentum is lost again, and everything balances out.
But where was it 'borrowed' from in the first place, from within that closed system? The question we should ask is not why she couldn't keep hold of it, but simply where the hell this reservoir is, if momentum is so fundamentally conserved? Sure, her system might not be "thermodynamically open" in terms of being able to keep the excess momentum, yet the fact that it's open enough to be interacting with the reservoir in the first place should intrigue us..
Besides, what if she decelerated due to friction instead - in which case the borrowed momentum is just dissipated along with its KE..? Does that likewise return it to its source?
The only way the skater could keep her net momentum truly constant despite the acceleration would be by reducing the rest mass of the rest of her body - if it hasn't changed radius, but its speed has risen, then variable rest-mass is the only safety valve for strict CoM. Which of course is a daft proposition, albeit the only possible get-out clause on the table.
If "first base" is simply keeping or discarding the 'borrowed' momentum, then it would seem we're dipping in and out of 2nd base all the time - a universal lending library we all take completely for granted. When we say "momentum is conserved", what we really mean is that it's ultimately conserved, when all is done and dusted. We mean the debt always has to be repaid.
Suffice to say, if we're about to invoke a get-out clause on the repayments, it might be a good idea to start asking just who or what this mysterious benefactor is.. underwriting the physical yet conserved momentum we lose and gain every time we change radius while changing angle...
I mean, you could do a little dance that creates and destroys momentum, in equal quantities, and not even know you were doing it. In fact i'd go further and point out that almost any form of dancing that involves rotations likely involves the spontaneous sourcing and sinking of momentum from and to 'nowhere'.
If this is a solution we have here, the question it highlights is one that should trouble us more since it applies equally to common every-day motions - the only difference here is that we get to keep the gains, or else destroy the losses without trace.. but simply gaining and losing instantaneous momentum itself is trivial, and something we do all the time quite obliviously. Momentum's conserved... at the end of the day. Ie. in the first instance it isn't... until it is. So its ultimate conservation is simply something that must usually be resolved owing only to practical constraints.. we pay it back just as inadvertently as we borrowed it.
Just seems surprising that we don't seem to question how we were able to borrow it in the first place - that we're not even aware we're doing so.. that we're contented enough by its ultimate conservation to never even notice its instantaneous inherent variability.
The reality seems to be that very often, momentum isn't conserved... until it is... So behind this question of what it means to be able keep (or permanently discard) gains or losses of momentum, is this more general elephant in the custard, of where all this momentum's coming from and going to all the time everywhere..
I mean, when you spin round 180° and do the James Bond pistol pose (just to check you're not being followed by squirrels, or something) - that basic everyday action destroys momentum! Spinning around while moving your arms out destroys angular momentum in your brain, and groin , depending on their relative rest masses and angular viscosity etc.
How about a celebrity workout video, certified by CERN as inducing N-kg-m/s of invigorating vital vis viva per 20 minute session, or your money back!?
If this is it, then it's not so much an innovation, as a slight twist on something already remarkable.. the instantaneous, transient momentum of any rotating body having any radially-translating mass is already non-constant... It seems strange that i'm only realising this now..!?
