eccentrically1 wrote: That's one reason it doesn't work.
If "it" is one of my device designs which you surely have not yet seen, then you do not have enough information to make such a proclamation with any degree of authority.
I'm sure you believe you are right based upon what maybe you and I both have been spoonfed during a formal education and/or maybe based upon what those in mainstream science would currently proclaim (and/or maybe even what you yourself have yet seen and understand) - and surely based upon a history of perhaps similar pursuits your assertion would even be considered a rather safe bet - probably true - most likely true - almost certainly true.
...but it, of course, is not necessarily true.
eccentrically1 wrote:Any force (gravity in this case) is opposed (by the normal force from the earth).
...except for when and where it's not (in regards to the earth and its force of gravity on another mass).
...and some forces are also only opposed by the inertia of the accelerating masses that are gaining energy (considering ones reference frame).
Anyway, I apologize for having spoken of things I'm not yet prepared to fully share online. I try to avoid that as much as possible, but it seems to happen when I enter speculative conversations.
If you were a local friend or even acquaintance, I would be much more open in sharing both my ideas and actual designs. I'm just not ready to publish them online yet nor do I really want them floating out there in cyberspace somewhere beyond my control.
Thankfully, though, I plan to do good (mad and amateur) science! So, I also plan to eventually publish my hypotheses, device designs and experimental results - and regardless of their outcome.
eccentrically1 wrote:Good luck
Thanks. I'll still certainly take all that I can get.
Dwayne
