Forget it
eccentrically1 wrote: they didn't go 10 rpm, back to 5, up to 15, back to 10, etc.,or whatever details.
Why in the world would you think the speed would bounce around as you describe? That type of thinking doesn't make any sense to me. The weights act like an internal combustion engine, pulsing the wheel about eight times each rotation. This is about 2.7 pulses per second at 20 RPM, or about 3.5 pulses per second at 26 RPM. So with these steady pulses, the wheel rotated a steady speed, and like an IC engine, the wheel slows down with a heavy load, and can be stopped by excessive load. And it runs a steady speed when running without load.
eccentrically1 wrote: and it wasn't weights pumping in and out like a child on a swing.
And how can you be so sure?
that's what you implied in your post about the rpm's of the skater
"Thus the final RPM verses initial RPM would be 10 ÷ 12.5 = 0.80 (80%), a difference of 20%. This would be noticeable. "
versus.
anyway, i'm sure because weights don't change their moment of inertia by themselves. Children do every day, but no, not weights.
re: Forget it
If one fully understands Physics 101, then you understand why motion cannot be the source of the rotating force.
The last page and a half of this topic is quite interesting, I do not believe I have ever saw so much negative criticism and words of 'impossibilities concentrated in such a small number of posts.
cloud camper and Jim_Mich, neither one of you seem innovative enough to get past the ice skater, Physics 101 and your two dimensional thinking. There are times when I can agree with the two of you and times I wish you would move on.
Have either of you thought about Physics 101.2 or jumping up to Physics 103.5?
I beg of both of you, get your head out of your you know what, forget about the two dimensional skater and move on to something more in depth! You talk of what gravity can and cannot do, and of weights changing positions and the effects thereof, what is a weight worth without gravity? How do you achieve displacement to create motion without gravity? Without gravity boats would not displace any water and the water would not seek its own level. Your wheel that does not seek equilibrium will not seek anything, like a herd of lazy fat horses they will just float going nowhere.
How about thinking "one side is full the other empty, as it should be". Does this thinking surpass the abilities of Physics 101 and require a Doctorate to comprehend? If so, should I dig out my sheepskin diplomas or will you let me pursue the course undaunted.
Your continuous and repetitive criticism is to some an inhibiting factor, members stay silent for fear of getting involved in your one sided rebuking.
Ralph, you need to go back to physic 101.
You have some misconceptions about "weight". I've touched on it lightly in the past. You confuse gravity-weight with weight-mass. The two are related but they are different.
Let’s see if I can explain the difference and why your statements are not correct.
An object that we label as a weight causes a force when on Earth. We call this force gravity. When on the Moon, this force is different.
An object that we label as a weight resists being moved. We call this resistance inertia.
An object that we label as a weight resists being stopped. We call this resistance momentum.
Inertial resistance to motion and momentum resistance to stopping is the same on Earth as on the moon. These two forces are related to the weight-mass of the object. We use a short-cut on Earth to determine weight-mass by measuring an objects weight-force.
Mass and weight are NOT the same. On Earth, we use units of measurement that equate weight and mass as being equal. This is done to make calculation easier here on Earth. It is a short-cut. But if you have a weight on the moon it no longer weighs the same weight-force. If you try to move a weight-object on the moon, it takes the same force to accelerate it as on the Earth. And it produces the same force when decelerated on the Moon and on the Earth. Inertia and momentum depend upon weight-mass.
So, Ralph, you ask,
Ralph wrote: what is a weight worth without gravity?
As I've been explaining, a weight without gravity still has inertial resistance to motion and it still has momentum resistance to stopping. These characteristics of mass do not change when within the presence of gravity, of lack of gravity.
Ralph wrote:How do you achieve displacement to create motion without gravity?
You seem totally ignorant of inertia and momentum. These are the forces that cause turbine rotation and rocket propulsion. Gravity is not required to create motion. All that is required is an imbalance of force.
Ralph wrote:Your wheel that does not seek equilibrium will not seek anything, like a herd of lazy fat horses they will just float going nowhere.
Once again you are hung up on gravity. Floating is a gravity terminology. Floating is a fluid terminology. Forget gravity. Forget fluids seeking their own level. Gravity is not a requirement for rotation. Bessler's "herd of lazy fat horses" was in reference to Wagner's refusal to harness his fat horses and bring his lazy butt to look at and to test Bessler's wheel. Wagner was a typical skeptic. He was of the belief that PM was impossible, and therefore Bessler's wheel must be a fraud.
Ralph wrote:How about thinking "one side is full the other empty, as it should be".
But Ralph, that is not what Bessler said. Bessler's statement was a comparison of how his wheel worked, on the one hand lifting a heavy and full load, as on the other hand empty and light. (As shown during the demonstrations that had just been completed.) It is not my fault that the words were not translated correctly. Go back and read the original German text. Run it, word-for-word through any of the numerous on line German translation engines. Or have someone knowledgeable translate it. You have heard people compare two things, such as: On the one side are the Republicans, and on the other the Democrats. This is the same as saying, On the one hand are the Republicans, and on the other the Democrats. The German text equates to the same meaning: On the one side it is heavy and full, on the other empty and light. Then in parenthesis it says "(wies sol.)" "weis" means to point out or to show. "sol." is an abbreviated word in order for the poem to rhyme. It is most likely the abbreviation of "solch", which means so or such. Thus the words in parenthesis say "point so" or "shown such". Bessler was saying that during the demonstration of lifting heavy or light, he pointed out or showed as such (how his wheel worked equally well loaded or empty).
Ralph wrote:Does this thinking surpass the abilities of Physics 101 and require a Doctorate to comprehend?
Physics 101 says you cannot make a perpetually out-of-balance wheel. Physics says you cannot raise 4 pound by the falling of 1 pound a same distance. Wagner knew this 300 years ago. Bessler confirmed that Wagner was right. But Bessler was also right – he claimed his wheel was perpetual motion – and he never claimed it was rotated by gravity acting on out-of-balance weights.
Ralph wrote:Your continuous and repetitive criticism is to some an inhibiting factor, members stay silent for fear of getting involved in your one sided rebuking.
I assume this is directed at me, though "one sided rebuking" sounds more like clod camper.
Truth is truth. You cannot lift a 4 pound weight using a 1 pound weight. Such is impossible. Truth is truth. The translations being used to support lifting 4 pounds with 1 pound do not translate as people think. These words of Bessler were sarcasm. Bessler was making fun of Wagner's thinking that a light weight might lift a heavier weight. One pound lifting four pounds is not the source of rotation of Bessler's wheel. It is impossible for one pound to lift more than one pound a same distance. There is no mechanism that can cause this to happen.
People are free to search for any method of PM they desire. But when these wrongly translated words are used as an excuse for searching for out-of-balance PM wheels, I simply point out the error in the translations. If you believe, as I do, that Bessler invented a working PM wheel, then why use wrongly interpreted words in the search? And if you think I’m wrong about Bessler’s writings, show what you think his words say, using the original German as your source. Or just ignore me, as many do, and keep searching for some way to make 1 pound lift 4 pounds.
My opinion, based upon scientifically known facts, is that a gravity rotated PM wheel is impossible.
My opinion, based upon historically known facts, is that Bessler made self-rotating PM wheels, contrary to popular thinking that PM is impossible, which is most often based on the fact that gravity PM wheels are impossible.
My opinion, based upon logic, is that if Bessler wrote that his wheel was rotated by force gained from the motions of its weights, then that is where to look for a solution.
re: Forget it
Jim:
Can you give me an internet reference to this? Seems not right to me, it is like saying steel going perpendicular through a magnetic field and the steels inertia is not effected by field strength. The gravitational pull has to increase inertial resistance on earth compared to the moon.
Why did the astronaut’s steps increase in length on the moon?
re: Forget it
Say True or False; An object on the Moon weights 1/6 of what it weights on the Earth. Therefore, the object has less inertia on the Moon.( Justify your answer)
Answer: The statement is false.
Inertia depends on mass and not on weight. The weight on moon is less not because of a decrease in mass, but due to the decrease in the acceleration due to gravity on the surface of moon.
Inertia depends on mass and there is no change in mass when a body is taken to moon. Therefore the inertia of a body is same on moon as that on earth or anywhere else in the universe, even in a gravity free space.
Hmmm.... don't you love it when you answer your own questions.
PS Still doesn't make sense to me at right angle to the force when the mass is rolling.
cloud camper
re: Forget it
Post by cloud camper »
What we have here is just the "Elephant in the Room" phenomena continually observed by mental health professionals.
An agitated citizen calls the police to report there is an elephant in his room. Police rush out to check it out and find no elephant.
The next day, the same citizen calls the police to report there is an elephant in the room. Now the police come out once again to investigate. No elephant in sight.
Third day, the citizen calls the police yet again. "There's an elephant in the room". Now the police are getting very bored and send the ambulance with the two burly attendants to remove the citizen from society as he cannot cope with reality and is a danger to himself and others.
So we have Mr Randall continually reporting at great length as how this elephant is in his room and we should do something about it and everyone else is insane for not seeing it.
Of course the elephant here is Randall endlessly originating that "weight motion" causes unpowered wheels to speed up.
All right Mr Randall, do you have such a wheel? Well, no but I know just how to do it. OK, do you plan to construct such a wheel and demonstrate this knowledge? Well, no - too busy for that, but I just really want people to believe me. OK - do you have any technical reason for believing this might work? Well no, but it is just totally obvious to me.
All right, do you have any physics experience or any new principles that might support your statements? Well, no, but it is just self evident and it should be to you too.
OK, have you studied Physics 101 and do you understand that spinning ice skaters do not speed up when they extend their arms? Well no, that's just silly, the laws must be wrong.
OK Mr Randall, no further questions. We have a new home for you. You will have lots of new friendly faces and plenty of time to discuss your ideas.
re: Forget it
Moment of inertia is defined by the following equation
I = m x square(r)....
where m = mass, and r = the shortest distance from the axis of rotation...it has no relation to gravity (acceleration)... and therefore, should be the same on earth and moon.
However, if we talk about Force of inertia, F= Ia (derived trom Newton's F=ma), then yes... moon will definitely has less force of inertia...
I am getting forms of inertia such as “Moment of Inertia� blurred in my simplistic view of reality.
resistance to acceleration m I = ∑ ri2mi = ∫ r2 dm I
Re: re: Forget it
How much longer are you guys going to put up with this foolish clod camper troll before you boot him off?
cloud camper
re: Forget it
How much longer are you going to promote this insane nonsense without a shred of evidence?
justsomeone
re: Forget it
Post by justsomeone »
The force required to move an object is equal to the force required to stop the same object? Inertia = Momentum?
Jim, in your design, if you're using the weight movements to turn the axle (from your newly discovered gain) , could you not use that advantage to shift weights to an OOB position?
re: Forget it
Jim-Mich,
Sorry but I read the first four sentences of you above post directed to me.
When I got to:
When I got to this sentence, I lost all interest and quit reading. I cannot count the times I have stated: keep your response "earth Bound", I could care less about what happens on the moon or in space. Bessler allegedly found the answer here on earth, I do not believe he was interested on what happens elsewhere.
Using the moon or space to compare what happens on earth is no different than your own statement of comparing equations using apples and oranges.
Mass is mass, mass takes up space, with the exception of lighter than air elements in gaseous form it has weight, weight is a property of mass density and gravity. It only changes when you change ambient environments. I work and do research in the ambient environment of earth not on the moon!
Re: re: Forget it
justsomeone wrote:The force required to move an object is equal to the force required to stop the same object? Inertia = Momentum?
Jim cannot be using weight movements to turn the axle or use as an advantage to make OOB positions as that would require gravity.
Ralph, so you stick you fingers in you ears and say, "No, no, no!"
By stopping your reading you missed the whole point, which is that momentum and inertia are constants, and are not effected by gravity.
You missed the point the gravity is not a requirement for causing wheel rotation.
And you missed the point that the "herd of lazy fat horses" is not an analogy for making an OOB wheel, but is instead Bessler telling Wagner to harness his herd of lazy fat horses and get his buttocks over to Karl's castle and observe the wheel first hand as it runs on the one hand heavy and full, and the other empty and light, as was demonstrated/shown.
But you, like other, prefer to close your eyes and ears and say "No, no, no!"
Ralph, open your eyes. Open your mind. You cannot make a PM wheel by causing weight to rise and fall. As I wrote earlier, and you failed to read, Wagner knew this 300 years ago. And Bessler agreed with Wagner when Wagner said PM is impossible by rising and falling of weights, but Bessler was also right when he proclaimed a Perpetuum Mobile that was also a Mobile per se.
justsomeone, any force capable of rotating a wheel is also capable of lifting weights, which can then fall and rotate the wheel. Just physics 101.
re: Forget it
You both reflect the same indignity: I make a motion that you either cease and desist until one of you have objective back up, or request for a mandatory vote by the consensus to pass judgement.
IMO it is up to Jim to supply the proof, cloud camper is only quoting from the teachings that we all have been influenced with. How he ever believes he will contribute to a self-sustaining machine with his "Stuck in the box" reality is beyond my comprehension.
To all who have stated that something is impossible or an impossibility, I question: What the hell are you doing on this forum?
