MT 24 and MT 25
Nobody
re: MT 24 and MT 25
Post by Nobody »
Many Thanks @ all and for your answers!
Ed wrote:
Nobody wrote:
Anyway coming back to that invention it seems no member in this forum has made a practical test experience with a model?
Why do you say this? Have you not done a forum search?
@Ed
guess the question has already become settled, but I like to point out that this sentence was meant
as a question and definitely no reproach to someone.
It was more repeating the question for any practical experience with MT 40 model from last Friday:
I like that invention and hopefully there is no hoax or even better a clue in it, but before making model and
spending time and money I would appreciate any comment / experience from your side? A forum search did
not exactly indicate if someone has practically build a model of that machine.
Best regards,
Nobody
Mark
Re: re: MT 24 and MT 25
Post by Mark »
Nobody wrote:At the beginning I have searched for MT 24 and MT 25 and unfortunately nothing showed up.
IIRC, the forum search engine requires a minimum of three consecutive characters.
A space doesn't count as a character.
It doesn't recognize numbers / numerals when written as separate terms, even when included within quotation marks as a "search phrase".
For example; neither MT 24 nor "MT 24" will show results, but MT24 will work fine.
This obviously limits the effectiveness of the search, but at least it will show some of what you're looking for.
Nobody
re: MT 24 and MT 25
Post by Nobody »
Thanks @ Mark for your search function help and @ MrVibrating for pointing out that scissor-jack acceleration phenomena:
Mr Vibrating wrote:
Final thought on scissorjacks - the only significant aspect i've found concerns the relative input-to-output
accelerations - as more scissor pairs are added to the jack's length, the relative I/O accelerations increase
linearly. This is why a long jack seems to open and close surprisingly rapidly when the handles are
pumped (like a linear whiplash effect). However i doubt this is the useful property Bessler hints at, and the
power requirements remain a straightforward function of mass, distance and time.
Maybe the different and rapid acceleration/movement on one side, resulting also high forces of inertia shouldn't
be ignored, or can be used in a sensible way?
Bessler AP part 1 page 82:
Und wenn ein Pfund ein Viertel fällt /
Es vier Pfund hoch vier Viertel schnellt.
There is no better German word than the word "schnellt" that would describe that rapid movement/acceleration
on one side of a scissor-jack or stork´s bill.
For instance you could say:
A fish "schnellt" out of the water or an arrow "schnellt" through the air.
Best regards,
Nobody
Mark
re: MT 24 and MT 25
Post by Mark »
Nobody, in particular, you're welcome. I've always liked the search tool, but it seems that I'm almost always using the Advanced mode.
When you mentioned "rapid acceleration/movement on one side" I couldn't help but think of Jonathan's curved jack animation. Likely not what you meant, but I figured it wouldn't hurt to point it out to you.
http://www.besslerwheel.com/forum/download.php?id=313
[click on the image to go to the associated posting]
The file that I have stashed away was labeled "crayfish tail". The search for it led me to this post [for what it's worth]:
http://www.besslerwheel.com/forum/viewt ... =6436#6436
Nobody wrote:Thanks @ Mark for your search function help and @ MrVibrating for pointing out that scissor-jack acceleration phenomena:
Best regards,
Nobody
Interesting thoughts, i'd noticed one or two clues perhaps hinting at speed but hadn't given the matter too much thought...
Still, just to clarify the jack's speed dynamic, it works like this:
- suppose we have a single scissor 'X'; it only has angular speed, not linear
- however for a double scissor 'XX', both have the same angular speed, but the 2nd also has some linear acceleration
- for N scissors, all have the same angular speed but the terminal scissor has linear speed roughly equal to N times the radius of one scissor times the angular speed (ie. how quickly the handles are operated)
This assumes each scissor is identical and there's no play in the bearings.
As i say though, it seems all that really matters is the conventional mass displacements. As beguiling as the speed issue is.. ie. if inertia was no issue a scissorjack would be an easy way to exceed lightspeed...
However, as a thought experiment, suppose we had a scissorjack with so many sections that if the handles are closed in 1 second, the terminal end will reach lightspeed. The jack itself can be notionally massless, however suppose there is a small mass at the terminal end, that's going to be accelerated.
What would happen when we try to operate the handles? Even if we had infinte energy to pump the handles with, we'd never be able to open or close the jack in 1 second.
To take it a step further, suppose our jack had infinitely many sections... thus, any motion at all, however slight, applied to the handles will inevitably result in a superluminal acceleration at some point further along the jack, hence the handles would be inoperable, even with infinite input energy.
This illustrates that with regards to speed, at least, the snappiness of a scissorjack is a red herring... we might as well remove it from the thought experiment entirely, leaving only the prospective masses to be accelerated, since this is really what defines the possibilites, not the jack mechanism. It might as well be replaced with pulleys and tackle or any analogous mechanism... it's just linear leverage.
However in light of your point i intend to revisit this when i get time, perhaps i've overlooked something after all..
ETA: was playing with 'inertial pumping' last year, the attached sim uses a scissor section to try to coordinate an effective pump, but to no avail.. it just conserves input RKE. However it didn't occur to me to try multiple sections, ie. with longer jacks.. something else to try when i get the chance...
up'ndown.wm2d
(28.71 KiB) Downloaded 196 times
Nobody
re: MT 24 and MT 25
Post by Nobody »
Hello Mark and MrVibrating,
thanks a lot for providing those links and sharing your experience........I´m not too fast in writing, therefore it sometimes
takes a bit of time until reply is written.
During the last few days I did a bit of investigation by using the search tool only and was quite impressed about many
good topics, works and/or results showing up.
Coming back to the scissor-jack or stork´s bill I like to mention something in regard to the following Bessler MT 41 comment:
Whoever knows how to construct them will note that the figures sketched here are not exactly the correct artistic application.
Guess most of you (especially the veteran scientists and members) know this already, but I thought it is no mistake
to write down this opinion / experience about that comment.
Due to the clearance in the pivot points or bearings (connection points) and to ensure proper and fully opening and
closing of the scissor-jack it is (to my test experience) necessary, to shorten the distance between holes and therefore
also length with each additional scissor pair added.
In many MT drawings stork´s bill are presented that way......I thought it might be worth in that coherence
to write down this opinion about that Bessler comment with the "correct artistic application".
Best regards,
Nobody
Nobody
re: MT 24 and MT 25
Post by Nobody »
Dear all,
there are a couple of topics where this part of Apologia Poetica has/is being discussed and I was not sure where
to post this so I simply put it here.
I also know that forum members like Stewart as well as many others already showed their very good translation on this.
It is part of AP chapter 43 page 82. This seems to be one of the most important clues and there is (to my personal opinion)
no doubt that this is not meant serious. I´m also quite sure that this part is addressed to all of us (the perpetual motion
searchers) and not to Wagner.
Der wird ein grosser Künstler heissen /
Wer ein schwer Ding leicht hoch kan schmeissen /
Und wenn ein Pfund ein Viertel fällt.
Wer dieses auß kan speculiren /
Wird bald den Lauff perpetuiren /
Wer aber dieses noch nicht weis /
Da ist vergebens aller Fleiß /
Translation:
He will be called a great artist (craftsman),
Here very important the word will be, Bessler does not say shall be, might be, could be or would be, he clearly says will be.
who can easily throw a heavy thing high,
and when one pound falls a quarter,
it shoots four pounds four quarters high.
Who on this can speculate
(or maybe more easy who can find out about this),
Will soon the motion perpetuate (or maybe more easy will soon find perpetual motion),
Also here very important the word will, Bessler does not say shall, might, could or would, he clearly says will.
Who however does not know this yet,
all the hard work is in vain (or maybe more easy all the hard work is (will be) fruitless),
I have build a few "useless" models, this part of AP seems to be some sort of prophecy for that;-).
With best regards,
Nobody
Art
re: MT 24 and MT 25
Post by Art »
I have trouble making sense of what he means by "a quarter".
Does he mean a quarter rotation -( ie 90 Degrees )
or a quarter of a distance , say of the rim to axle , - or rim to rim or something similar ?
Does anybody know if he or Wagner talks about quarters anywhere else .
Nobody
re: MT 24 and MT 25
Post by Nobody »
Dear all,
I need (forgot) to add something to that translation above. Except for some very small differences I refered a
lot and used major parts of a translation from the topic "making weights rise" done by Stewart since I thought
it is in very good harmony with the original German words.
I´m very sorry for not mentioning that explicitly in above (last) post.
With best regards,
Nobody
cheors
re: MT 24 and MT 25
Post by cheors »
Did you see that MT24, 25 26 and 27 represent a group ?
Mt 28 is an other story.
The same for MT40, 41 and 42.
I think MT 27 and 42 could be the good designs, but taking all the remarks of the group into account.
Nobody
re: MT 24 and MT 25
Post by Nobody »
Hello Art,
guess with a quarter he means a quarter of distance and the relation among them, but have no idea
what the exact distance could be.
Hello cheors,
thanks for your group hint, I have not realized that so far, but believe you are very right about that.
Dear all,
while looking at Apologia Poetica high regarded clues in the Besslerwheel-Wiki-Forum I have realized
that clue in AP part II page 42 is to my opinion in very important relation to AP part I page 82.
Weil ich nun in dem ersten Theile
Gesetzet mehr als eine Zeile /
Auf was für Art die Überwucht
In meinen Künsten sey gesucht;
So wil ich jenen Ort anpreisen /
Den werthsten Leser dahin weisen;
Auch Wagner hört / (wo er noch lebt /)
Wie ein Pfund mehr als eines heb´t. NB.
Translation:
Because I now in the first part
seeded more than one line /
In what manner the overbalance
in my skills should be sought;
So I will extol that location (position of text) /
(For) the worthiest reader thither point out
Also Wagner listen / (wherever he is now /)
How one pound lift´s more than one pound. NB.
To my personal opinion this passage clearly underlines NotaBen in AP part I page 82. My English is not
that good and sometimes it is not that easy to translate Besslers writing.
Maybe for comparison it would be good if someone could post the well-established translation for above part?
Also of course I would appreciate any other opinion and further posts to this topic.
With best regards,
Nobody
Stewart
Post by Stewart »
Hi Nobody
I've posted about this before and agree that it refers back to chapter 43 in part 1. I'll repost my translations and discussion of this in my forum later today. In the meantime see this previous post: http://www.besslerwheel.com/forum/viewt ... 8841#88841
All the best
Stewart
cheors
re: MT 24 and MT 25
Post by cheors »
Why MT27 is the only drawing with heart-weights ?
Because he likes it, he loves it !!
This a clue.
AB Hammer
re: MT 24 and MT 25
Post by AB Hammer »
Greetings cheors
MT130 also has hart shaped weights/plugs in the drawing. It could simply be the direction the weights are expected to go. Artistic license, so to speak. A clue is always possible but could be a red haring for misdirection as well. That is what makes this game interesting.
cheors
re: MT 24 and MT 25
Post by cheors »
Ok but Bessler says :
"This view shows what the thing might do if several things of this sort were placed next to one another along an axle-shaft"
Second clue for MT27.
