Lagrange Maths 101
re: Lagrange Maths 101
I did think of a little level platform and imagined the rods have a wheel on the end.
Then the Over-Balance and K.E. might put the rod back to its starting position.
Using your line as a guide it would help to follow the outer curve until the horizontal position. That will stop it sliding back.
What this topic is focused on is the slide, rotation rate and the return spring.
When I say spring I actually mean elastic rope. with K the elastic strength not being constant.
agor95:
Opps; sorry for un-focusing your thread. I guess you don’t think a multiplication of force is needed.
@daxwc
Thanks for the MT135 suggestion. Hopefully the maths will help prevent the need to the bounce.
Also ME the formula01 has been updated with an alternative notation and a proof of MOI of a rod rotating at the center to it rotating from an end.
This looks interesting for a composite MOI
https://skyciv.com/tutorials/calculatin ... f-inertia/
The formula01 page has been updated with something complex.
This complex formula and it's implementation is the direction I am on at this time.
This formula is presenting the effect of gravity, CF and inertial of one half of a two headed bar.
Still Studying.
Gregory
Post by Gregory »
Looks very complicated, above my level of understanding...
You want to construct a Lagrangian to include everything in one single formula, a kind of field equation which describes/governs the behaviour of the system?
Is there a benefit with this?
@Gregory
Thank you for checking out the formula01 page.
I can not agree with you more to both questions.
I think proving the device with equations, a web site and a real device
is required to turn around social inertia.
I have learned a lot while on 'The Quest'.
Maybe the journey is part of the benefits with this.
