Only for those who don't know everything about gravity !!! :)
Re: Only for those who don't know everything about gravity !!! :)
Last edited by eccentrically1 on Sun Jul 17, 2022 12:16 pm, edited 1 time in total.
There was a time on this forum when i reported about the strange results i got from a simple mechanism that i could not figure out how the input and output ratios were different from what i expected , and how the thing worked with 1 mass as the falling but stopped working if i increased the falling mass..
Until today i have never shown it ,i did not know it had a name nor did i understand why it happenend , i do now .
these were my experiments , im sure the similarities are obvious , my first one was just 3 roundbars , 1 roundbar was wound with string around the center of another in one direction , then the two ends of that bar that was wound in the center were wound counter direction with string that was tied to another grounded bar , and so as one fell and unraveled the other wound up as it was raised.
Then i was going to play with these other 2 versions in the pictures with different ratios and balanced masses , but i left the idea and determined why it behaved strange to me was that it was a mixture of mainly tension force ,pulley speed ratios and friction that made it difficult for me to work out exactly why it was strange.
But now i see the unraveling and winding also had a acceleration factor which contributed to the tension too , quite interesting though.
Hi johannesbender
If you done those images in blender then you are really proficient.
Gravity Alteration
The device presentation start 3:00 minutes in to the video.
https://www.youtube.com/watch?v=U70nrM_E2T8
Enjoy
This is an effect i can actually say i have seen before , https://youtu.be/sENgdSF8ppA heres a nice video of it
Last edited by johannesbender on Mon Jul 18, 2022 1:52 pm, edited 1 time in total.
Interesting Vid Agor. Having experimented a lot with magnets and electricity, I was very skeptical on everything this guy said, especially as he got unqualified, uneducated people to qualify his tests.
The UFO device they show is not anti-gravity, you can see the hippie avoids underneath the engine. When he does get too close, his shirt flaps in the wind. It does have gyroscopic stabilisation, from spinning mass.
You have a fair observation.
Why overlap other video into your own?
I have seen others spinning a disc of alternating magnets over a copper sheet. So the induction would create repulsion.
However as seen in the next post this normally causes a dampening effect. That maybe happening but the clip does not allow us too see the slow down.
The drop test of two magnets compressed together.
Well the description of the test was of an inferior type.
The drops were done by himself and no video of the falling objects.
Not really a double blind test with a validated significant number of tests.
The test needs to be validated with an improved protocol.
Also done by other testing teams.
The device that we are shown being built and tested.
Then shown tested in a field with a windy environment.
Like the trees in the background.
Also we do not see it take off. So it looks staged unfortunately.
So another clip with takeoff on a windless day is in order.
This also needs other team testing validation.
Consider a superconductor traveling around a track.
There is a wind as it moves around but it does not slow down.
Saying that the voltage must not be height for he is touching
the device when it's live. We are not talking 30,000 volts.
This is an enjoyable demo. Which needs replication.
Spinning mercury and electricity has been talked about for decades.
Keep and open mind.
No, you can see when he touches the very thick wires onto the large copper pads they are using high current low voltage. I would suspect a large car or truck battery.
OK I did notice a DIY tesla coil in the field section.
Ha ha, yes, there were two. And a magic box with lots of wires coming out.
My open mindedness no longer extends to idiots. (The guy in the vid)
Sssh its a secret ufo project
Last edited by johannesbender on Tue Jul 19, 2022 7:36 am, edited 1 time in total.
Wondering what the effects of mercury poisoning were and one of them was idiocy (reduced mental faculties).
The liquid form appears to be less toxic than some of it's compounds.
Like all heavy metals they accumulate in the food chain.
Saying that the open case mining of uranium ore in Africa resulting in radioactive wind blown dust appears to be the bigger problem. Being toxic on two levels.
It all appears like Hypocrisy to me.
'Fools go were angles fear to tread'.
So he maybe a fool or an idiot, but he is researching an area few admit involvement.
So he who has not shown idiocy throw the first stone.
Halbach Effect
From the video there was the compressed magnets test.
I wounder what happens with a Halbach array in a loop.
One that keeps the field within the loop and another loop with the magnetic field on the outside.
Therefore if inertia is a magnetic field lens law effect then the outside version should have more inertia?
Then there is the Halbach loop with an axial twist.
That interacting with a opposing loop with a slightly different loop size and axial twist rate.
P.S. Of cause I have nothing to do with magnets :)
spinner361
Post by spinner361 »
So the bottom is being pulled up at the speed of gravity because the top is releasing it's pressure at the speed of gravity? I mean, it's a pretty week spring, but it has a buildup of force, initially matching the force of gravity? It looks pretty cool.
