Non, mais quelqu'un pourrait peut-être vous indiquer où sortir la tête.Quelqu'un peu faire quelque chose pour le taré de service ?
Perhaps we could have a civil conversation, and you could explain why you think this isn't a dead duck.
Le problème c'est que tu dis tout et son contraire en moins d'une heure, ferme-la, merci
The drawing is not for an engineer, it’s for the patent examiner - it’s showing the principle of the invention.Roxaway59 wrote: ↑Tue Nov 26, 2024 2:51 pm Hi Frog, firstly can I congratulate you on coming up with a design of wheel that is using concepts like those of the Bessler drawing. That drawing has puzzled me for over 20 years and I have often thought about how it might be used on a wheel.
I do have a fairly good imagination but I learnt a long time ago not to fully depend on my reasoning when it comes to the positive and negative forces on a wheel design especially when those forces reach a certain amount of complexity.
If I take your drawing at face value the very first thing that strikes me is that what ever this mechanism does it has to move the weights quickly into position and this has to happen naturally since any force used will likely tear it apart and impart a negative bias on it.
I'm guessing that you don't have a working machine at the moment.
Have you simulated this in WM2D or Algodoo?
Is your design purely theoretical?
Video?Frog wrote: ↑Tue Nov 26, 2024 6:24 pm
This is the bidirectional wheel - it’s more difficult than the one that only goes one way, if you want I can send you that one.
And. - no it’s not just theoretical.
I personally thought it was just an idea. Waiting for proof now loljohannesbender wrote: ↑Tue Nov 26, 2024 6:57 pm An observation i made is the drawing shows weights distributed unevenly , how many weights are there actually and are they distributed like in the drawing because it shows non symmetrical distribution , or symmetrical distributed ?
But not sharing my opinion on it , since the title reads "The Wheel is solved in a New Norwegian Patent" , i would advise you approach such claims with proof too.
The wheel is working asymmetrical - one half works as a pendulum, the other half is a flywheel.Roxaway59 wrote: ↑Tue Nov 26, 2024 6:38 pm Hi Frog, yes the more information you can post the better because it helps to build a better understanding of how this works.
At the moment the only way I can see the one you have posted working is dynamically with certain forces kicking in once it is turning. So I take it the one way wheel is perhaps easier to understand?
Cheers
The symmetry makes more sense now that you mention its only 3 weights , i thought it was about 10 weights , which seemed odd the way it was drawn in odd positions .Frog wrote: ↑Tue Nov 26, 2024 8:56 pmThe wheel is working asymmetrical - one half works as a pendulum, the other half is a flywheel.Roxaway59 wrote: ↑Tue Nov 26, 2024 6:38 pm Hi Frog, yes the more information you can post the better because it helps to build a better understanding of how this works.
Cheers
This is only possible with three pendulums because it’s the only configuration that always is in equilibrium.
It’s only B-N-O pendulums - only three.
You activate the wheel when you add Kinetic energy to rotate the wheel with a lock pendulum at the top from B to A
- Now the flywheel has potential energy to the top of the flywheel-
Now the locked pendulum has potential energy (from the added kinetic energy) to swing from A to R2
The pendulum is hanging in a one way bearings - so it will lock and not swing from position R2
- Now the potential energy change direction towards the bottom of the flywheel -
NOW - the - FLYWHEEL - starts a pendulum movement.
When the pendulum moves to the bottom - (D) the pendulum movement ends because the one way bearings in the pendulum
All the kinetic energy that is generated by the pendulum movement of the flywheel is then transferred to the flywheel.
The potential energy is different.
This is just math now.
Did you create a physical wheel? (Pretty sure we won't have an answer to that)
I don't think I have contradicted myself. Perhaps there is something lost in translation.The problem is that you say everything and its opposite in less than an hour, shut up, thank you.
Im pretty sure we do have the answer to that. It looks like you might be the closest to building it though.Did you create a physical wheel? (Pretty sure we won't have an answer to that)
Again, not the way I see it. 1 mechanism with a counter weight , 3,4, 5, 8 or 360 will not change how each pendulum functions. Obviously there are other things at play.... Position and angle of action vs wheel inertia...etc.This is only possible with three pendulums because it’s the only configuration that always is in equilibrium.
