Heh "by any of the known means"... all that matters is that the beam or main wheel effectively acts as the stator for the flyweight to torque against, thereby imparting the requisite pure moment in the form of the corresponding counter-torque.ruggerodk wrote:How do you intend to apply torque or spin to the flywheel?MrVibrating wrote: ...if we apply a clockwise torque of precisely 14.8 N-m to the flywheel, it spins up...
However, again for clarity, an accelerating flywheel isn't required - that's not the only way to apply a pure moment. I just thought it would be an elegant convenience if the weight being counter-balanced by a pure moment produced its own counter-balancing pure moment, by way of being made to accelerate or decelerate.
But you could get the same effect by trying to unscrew a jammed bolt with a wrench, or screwdriver. The bolt doesn't need to rotate - rather, the pure moment is generated precisely because the bolt is stuck. So the PM is just a twisting force, here applied anywhere along the line horizontal to the applied load, and raised to sufficient magnitude to counter-balance it.
depends upon the resulting displacements - i'd intended to only cause an angular displacement of the flywheel, however it seems certain that the sim is also inadvertently applying an unequal opposite workload to the main wheel.How much energy do you need to accomplish exactly that?
If this leads anywhere, then for certain it won't be viable to maintain the PM for a full rotation - Bessler didn't even have roller bearings, and besides, there won't be enough time for any significant spin up. Therefore the PM will need to be applied somewhat more judiciously, at the opportune time and place, presumably...
I guess one would think that if flywheels are the best way to produce this pure moment (they might not be), then thanks to conservation of angular momentum the RKE could be stored on an axially-mounted flywheel (ie. centered on the main wheel's axle, via a seperate bearing). Then the RKE could be shuttled back and forth between opposing flyweights via the third flywheel on the main axle - only the losses would need topping up, but if the mechanism was notionally lossless then the input energy would only need inputting for the first cycle - from thereon it could be kept in play, yielding consecutive outputs for no further inputs.
That's little more than speculation of course though..
Yep a motor could test that the effect works, although i don't doubt this. Measuring the energies is the tricky part, and most types of motor would complicate this i think..A test rig could be to speed up a small motor which axle are pinned (fixed) to the main wheel.
Apart from that it's a very interesting subject ;-)
Though, two opposite and equal force - as mentioned in your linkpage - sounds much like Centrifugal opposing Centripetal forces.
And yes we have two equal opposite forces (at least in theory - WM2D may be doing it's own thang there). However the novelty is that this allows the point of application of a weight to be removed from the weight's actual location; even when it's suspended horizontally, orthogonal to the gravitational vector.
Good question! That's precisely what i'm struggling to understand...EDIT: Are the direction of rotation of the flywheel vs mainwheel significant?
If spinning the flywheel on a not-pinned main wheel are balanced (i.e. the gravity weight of the flywheel on the main wheel are cancelled out), then what makes the main wheel rotate?
regards
ruggero ;-)
But yes, the directions are significant insofar that if the weight's downforce is doubled at 3 o'clock, then it's negated at 9 o'clock, and vice versa, depending on the start position and torque direction.
