You're right, although it hadn't escaped me - if accounted for it'll actually add to the efficiency rather than detract from it, too. However it's more practical just to counterbalance this mass, such as by using a wheel instead of a half-beam like that.Fletcher wrote:V .. I think you are forgetting a couple of things.
1. The vertical attachment rod has mass so when it is in the up position [north] it has RKE aswell.
Yes - again, the GPE of the vertical beam represents more output work for the given input, and so the 550mj disunity is a conservative measure. However this additional load can be counterbalanced away, it's incidental to the main focus.2. the polygon rod & the attachment rod both have increased GPE, which should be factored.
Only looking at energies here! Specifically, the RKE of the flyweight vs that of the main wheel or beam (or in this case the raised flywheel's static GPE). Any attention i'm paying to forces is strictly in regards to the resulting I/O energies.3. Force [albeit torque] is not energy.
Yep right there with ya, and well done for tidying the polygon - couldn't suss how to do that myself... the 'snap to' function is a bit hit'n'miss...Just my prelim observations - sim attached where I remade the polygons more accurately.
P.S. you could extend the attachment shaft so that it was pivoted in the middle [counterbalanced] so that you could remove the GPE gain from this in the energy budget.
I came up with a simplified design at work earlier, gotta try simming it yet but it's basically a big Superman "S" for a one-peice flywheel, counter-balancing an off-center rectangle for the main rotor. Ugly but simple, easily adjustable and keeps the two RKE measures nice and neat. Will have at it later...
