Not persé. A wheel with an unequal mass distribution will just have an acceleration which is a factor of gravity determined by this mass distribution and wheel inertia. Perhaps static/dynamic friction and weight/leverage juggling will cause some rate-change and will have its 3rd (4th,5th..) derivative effects. But the primary source will simply be gravity...Fcdriver wrote:So the changing from a direct downward force against the wheel to a indirect force lifting causing a slower rate or acceleration, is not a third?
Or, an unbalanced lever system will start to find balance at a certain speed accelerating at a maximum of 9.81m/s^2. Around balance it could slow down due to whatever mechanism, giving rise to all kinds of derivatives. As I see it: still gravity at work.
As I currently understand Grimer's use of the 3rd: is to single out this 3rd and use it as a cause to be applied on some weight or wheel where it has an effect on wheel acceleration and velocity etc...
Perhaps simply a semantic-problem or distinction: or, as long as a wheel rotates by itself then in the end nobody would care if a 3rd is either cause or effect (they'll just happen at the same time).
Besides that, thinking in 3rd's might very well overcome some cognitive obstacle :-)
* How's your rebuild going ?
Perhaps you noticed: I'm already in dissonance just by "attempting to do things which are not generally looked at as being possible", One never knows what's needed to get cognitive resonance.Grimer wrote:You should read the papers on my web site. You are one person who should be capable of understanding them, albeit not agreeing with them since the cognitive dissonance will be too great
Which paper do you recommend?
I believe the whole universe would be just a quick blip, perhaps even non-existent, when it could be observed from the outside - and yet, here we are! Hi all !!unless you believe in all that general relativity bollocks.
