eccentrically1 wrote:Fletcher wrote:
My template ..
"When you have eliminated the impossible, whatever remains, however improbable, must be the truth."
"When you hear hooves think horses, not zebras."
"Follow the energy/fuel"
The basic premise is that to output work a runner needs a fuel/energy input. Gravity is a force and not an energy. Therefore to have an 'impossible' runner (based on OOB principles) then it must have an 'improbable' fuel/energy source. We know that environmental forces are far too weak to replicate B's. work tests at his scale. And we can only use technology of his time. Our sources and choices of fuel/energy are ridiculously limited.
** In my case I eventually worked up a simple Prime Mover mech design from an amalgam of the Toy's Page figures, with respect to certain well known MT's. And also keeping cognizant of the constraints of fundamental Physics and Mechanics Conservation Laws and Symmetries. Since traditional OOB wheels are 'torque conservative' then the Prime Mover needed to induce some superior directional force internally within the wheel to create a Net Positive Torque condition, and at the same time not violate Newton's Laws etc. Once I had a bead on what those fundamental mechanics could be, while still being ostensibly an OOB wheel format, then I could begin to deduce and look for a real source of energy that hypothetically caused it to be a self-moving runner. Momentum/RKE appropriation seemed a likely candidate regardless of there being no recognised examples existing in nature at the earths surface (altho known in satellite sling-shot maneuvers to gain KE and speed).
^^ Yes I know - mech before fuel is an arse about face approach - So far I am quite happy with the potential Prime Movers' progress and resilience (as determined by me). No show stopper has been found as yet. It will need a real-world build to fully test its functionality and whether it is fit for purpose as imagined. Imagination is notoriously unreliable and a poor substitute for empirical evidence as we all know only too well in this quest to solve the mechanical conundrum of B's. PM Principle of "excess weight".
ECC1 wrote .. Our choices are limited to an energy form that can be taken from a wheel environment since we can’t consider a stand alone onboard energy ‘tank’ (that would need at least 54 days or more of stored energy — which would disqualify it [Karl]).
Unless it could somehow refill its own tank through some natural process
we can’t fathom yet.
If we saw it as Karl might have would we understand it? If we could fathom it, it’s back on the table, yes?
In a sense it is figuratively refilling its onboard usable 'energy' tank .. what it is not is a traditional or classical source of energy that is stored as Potential Energy to be turned into mechanical energy. It was not a carbon based fuel, it wasn't any chemical energy, or fermentation energy, heat engine, etc etc. - Horses not Zebras ! -
And Karl did understand it very clearly .. he says so many times either directly or in reported conversations with credible people who wrote about what Karl had said to them.
In JC's DT .. Karl says in his written testimonial 27 May 1718 ..
"so-called Perpetual Motion is a revolving wheel,
which is able to run, by means of its own innate momentum."
"His Highness, who has a perfect understanding of mathematics, assured me that the machine
is so simple that a carpenter's boy could understand and make it after having seen the inside of this wheel, and that he would not risk his name in giving these attestations, if he did not have knowledge of the machine...' - letter from Joseph Fischer to J.T. Desaguliers, 1721"
... "which His Serene Highness assured me to the contrary, and
that the machine was very simple ...' - letter from Willem Jacob 'sGravesande to Sir Isaac Newton, 1721"
From : JC’s PMAAMS? (pg 143) .. Jean Bernoulli (1667-1748) responded to 'sGravesande's publication. He was a member of a famous family of Swiss mathematicians and was, himself, a major contributor to mathematics. He was a firm supporter of Leibniz in the controversy with Newton over who first discovered the calculus. During his final years he worked mainly in the field of mechanics. In a letter to 'sGravesande he wrote, 'I move on now to your comments on the possibility of perpetual motion, which were written on the occasion of your examination of the effects of the machine at Kassel. Several years ago, marvelous things were written to me from Germany about this machine, and even a view of the exterior was sent to me. Now, I have been assured that the secret was communicated to His Serene Highness, the Landgrave of Hesse, under an oath of silence, and
he was allowed to examine the internal structure of the wheel.
Afterwards, his Serene Highness was quoted as saying to his ministers, that he believed the machine to be a true perpetual motion machine, and in addition, it was so simple and easy to construct that he was amazed that no one had managed to invent a similar machine before Herr Orffyreus.
Earth’s motion is part of a wheel’s environment, or is it?
It’s my understanding that motion is relative to two objects if you are considering them interacting. iow, two objects can exchange motions as separate object with two speeds (the slingshot). So relative to the wheel, the earth doesn’t have any motion to interact with. Relative to the earth the wheel doesn’t have any motion. Imo.
The wheel has a rotational when operational - the internal parts are revolving around an axle position (center of rotation) and relative to the center of the earth beneath the wheel stand. All physical objects have a mass and inertia. And this is the commonality with the sling-shot analogy and not mutual gravitational attraction per se.
Good luck, though. I agree temperature swings are weak. But they’re all that’s left for a wheel environment imo. What else from there is a candidate? I can’t think of anything else.
Thanks .. it was not harnessing a temperature or pressure gradient for a couple of reasons .. B. in AP and DT calls it "True Perpetual Motion". In DT he again calls it "True Mechanical Perpetual Motion".
Drebbel is written about in B's. DT, who lived 100 years before B. Clearly Drebbel's P.M. device using pressure and temperature differential was well know in scientific circles discussing the possibility of P.M. and would have been compared to B. and his claims. That's why imo he added the "true" disclaimer amongst other reasons.
FWIW .. next week I will probably start a new topic and rehash some old threads contents and posts that I have on file about B's. "excess weight" principle, and the various translation sources that are often quoted but sometimes give different impressions of meaning.
