Zeroing in on Bessler's wheel
Well I tried to get rid of him; but like every thing with computers, I don't know how to do it. Anyway, got the two drums on and the rollers. Gave it a try, not working. It's difficult to tell what it's doing, if any thing. If it's not a dead duck; it's on life support-------------------Sam
Wassup
Post by Wassup »
Sam Peppiatt wrote: Thu Dec 22, 2022 11:10 pm Well I tried to get rid of him; but like every thing with computers, I don't know how to do it. Anyway, got the two drums on and the rollers. Gave it a try, not working. It's difficult to tell what it's doing, if any thing. If it's not a dead duck; it's on life support-------------------Sam
I was trying to be nice. How can you be zeroing in on Besler's Wheel when I posted what he did?
You guys should consider my offer. After I finish my build which most likely will be in January, then you guys can show
you work together while actually doing some work. I do have other projects that I'll be moving on to. If I build it then
everything will be about me. AB Hammer said that shouldn't be allowed to happen. So now is his chance to lead you guys.
I've posted enough work in here and on YouTube. If not then someone in Germany will build it and this forum will be for
talking about Bessler's Wheel and not much else. With the 8 knocking sounds heard every rotation, the "drum" resetting itself
so it can lift the next set of weights.
This is my Christmas present to this forum. Some assembly required. Merry Christmas and Happy New Year's !
Wassup
Post by Wassup »
The "Peacock" and its tail is situated below the level of the axle. This means that the tail would be angle down
so its center aligns with the closest part of the outer part of the wheel when its tab that will lift is to the left of its
axis of rotation.
This way the peacock will not interfere with the assemblies that connect the top and bottom weights together. The 2nd
image shows how Bessler alluded to that in his drawings. That is what "D" does. When the levers move, they are both
connected to "D". When the peacock lifts "D", it is lifting both the top and bottom weights which are "A".
On the round part of the peacock, it can have tabs that go into the part(s) that are "D". There's more to his drawings, etc.
but I'll leave that for you guys to figure out. And trigonometry http://www.carbidedepot.com/formulas-trigright.asp ,
easy enough to do the math. If you know how to use a calculator, a cos angleº.
And as I mentioned, some assembly required. You've seen my builds.
p.s., the lowest feather on the peacock's tail would align with the arm at about 45º. Those 2 weights would be lifted 1/2 of
the way up if the center tab is 90º perpendicular to the "D" part it is lifting.
The bridge truss and Mt 138 (E) are the same. A wheel needs some type of frame, right? That helps to keep the wheel light
while it's still sturdy. Also Bessler said his weights were about 4lbs. each and his wheel was about 12 feet in diameter. That's
about all you need to know to build an authentic Bessler Wheel.
With Mt 138 (E), a block where there is a gap (every once in a while) would make it rigid as well if all of the links are of the same length.
Enjoy!!
p.s.s., you can find online how to consider an ellipse. The drum when it rotates and lifts "D" would work best if it were
elliptical. And maybe you can factor an exponential increase in radius. Then the average of the minor and major
(smaller and larger) radius would be 1/4 of the distance that is from the axis to the end of the peacock's tail. How leverage
would be calculated.
Mt 68 - D.png (41.45 KiB) Viewed 580 times
When you read a post in a thread (like mine here) the posters username appears at the top left of the post in blue, and also over to the right side. Move your mouse to either of these and click it. It brings up the user Viewing Profile. In the middle it gives a Location - and immediately beneath that it says "Add foe". Put your mouse on that and click it. Their posts will no longer show in any thread. Good luck.
Wassup
Post by Wassup »
Fletcher wrote: Fri Dec 23, 2022 3:48 am
When ab hammer openly posted that I am his wife and will have his children, why was that not a problem? This forum is about
realizing Bessler's Wheel, right? Yet when ab hammer posted that I as a disabled U.S. Veteran will work for him, not an issue. When
he said guys, I will show you how to get a wheel without working for it. Why was that not a problem?
You guys keep saying it looks like ab hammer's wheel. What he taught was how to getting a wheel without working for it.
And while I tried being nice and in the spirit of Christmas gifting you guys with Bessler's Wheel, it did snow last night so it could've been
like Christmas came early. Instead, it's we don't want to realize Bessler's Wheel, we want to believe. That's what Jesus is for. Jesus asked
you to believe in him and he who sent him. That's not what Bessler's Wheel is supposed to be about, we believe as ab hammer taught us
to believe. He is a devout Christian.
I am curious Fletcher, when I was dealing with severe complications from the treatment for cancer, did ab hammer send you this link?
https://www.presspubs.com/lindgaard-s-b ... ccca2.html
That is the only thing that makes any sense. You guys believed that when I got diagnosed with cancer in March, 2009 that I went out, got drunk
and killed someone. I live in Kentucky which ab hammer has known since 2006. He knows that wasn't me. AB Hammer did tell me that he'd ruin
my life if I didn't work for him. What he doesn't understand is that the only thing he did was to make Bessler's work an ugly thing.
With how severe my disabilities are and with what a challenge Bessler's Wheel is, it probably would've taken me just as long but without the
open animosity and hatred I've been shown. And because why? I want surgery so I can have a life? And Sam, I think my problems are more
serious than anyone in here and yet I talk about the work that I'm doing while you guys complain openly about what a problem I am.
Fletcher, I did that a couple of times, only to have him come back. I must have done some thing wrong. Will have another go at it------------Sam
Wassup
Post by Wassup »
Sam Peppiatt wrote: Fri Dec 23, 2022 12:38 pm Fletcher, I did that a couple of times, only to have him come back. I must have done some thing wrong. Will have another go at it------------Sam
Maybe one day you'll explain why you guys couldn't accept Bessler's Wheel as a gift? I think it's funny. Here it is, the season of giving and you guys are being hateful. Don't tell me the "some assembly required" part is a problem for you guys. You need to consider that the first Bessler Wheel might wind up
in a museum. And you guys are saying you wouldn't want to be remembered for building it? Mind if I ask what it is that you guys really want?
I think Bessler's legacy is more important than him being considered a fraud. Kind of why HIS wheel needs to be built. There are other perpetual
motion machines that can be built so people will still have a reason to consider perpetual motion.
Fletcher wrote: Fri Dec 23, 2022 3:48 am Put your mouse on that and click it. Their posts will no longer show in any thread. Good luck.
Note. You have to login as guests do not have the ignore option.
Also when an entity is delete from the forum.
They are also deleted from your profile friend & foe list.
Wassup
Post by Wassup »
agor95 wrote: Fri Dec 23, 2022 12:47 pm
You mean you guys can't do a little math to verify the design but will vilify me for trying to be nice?
All this does is to show why Bessler was hated. I guess you guys want to be known as Friend's of Wagner?
Is that right?
Although Bessler did say;
Bessler's Apologia Poetica
Should anyone wish to speculate about the truth,
let him ponder the rich pageant of words
which I now cause to shower down upon him!
https://besslerwheel.com/writings/apologia.html
OMG!! You guys want to speculate and that's what this forum is about, right? Speculation?
I guess I am in the wrong place after all. My bad.
I do find it disturbing that as ab hammer told me, he never said I killed anyone, at least that anyone is talking about.
Still, when you hate me because that is what he wanted, it does make you just like him. I also saved the last 2 pages.
It will show how being like Bessler causes people to treat someone the way Bessler was treated. And Bessler was arrested
for being a fraud but because he had friends he wasn't convicted. And Leibniz knew math. Kind of why I pursued Bessler's
Wheel. And yet I've been attacked for saying "math". I couldn't know what I know today without math. And Bessler most
likely knew math as well.
You guys will probably be known as being like Wagner. When ab hammer posted that perpetual motion was impossible,
that didn't hurt his credibility any. What I will do is have Bessler's Wheel built in Saxony, Germany by a German, a Pole and
others in that part of the world who like woodworking and that aspect of the Republic of Saxony's history. That'd be to honor
Johann Bessler. And I think with me, because I am 1/2 Norwegian and the Vikings are a part of my history, I wouldn't want
some people making that out to be a joke.
Wassup
Post by Wassup »
I put everything in the position where the 2 weights will start to be lifted. I'm not sure why you guys didn't think it could work.
What I do know is that there was Norway before there was England. And I've let Dr. Jaski know the new plan.
There were Vikings. They spoke Old Norse which is spoken in Iceland today. While the song is from a
video game it is hugely popularly. And even Led Zeppelin did a song called Immigrant Song (https://www.youtube.com/watch?v=RlNhD0oS5pk). That song said Valhalla I need you. With this song, it's calling me (https://www.youtube.com/watch?v=mQFPk8n97wk).
That's kind of my heritage. What's your heritage?
p.s., I left the support for the wheel off so it'll be easier to see the wheel.
Fletcher, See, he is back again. He has found a way to circumvent the friend or foe device. What the fuck!! Now he is gone again----------------------Sam
God help me----------------------------------------Sam Peppiatt
Wassup
Post by Wassup »
Sam Peppiatt wrote: Fri Dec 23, 2022 3:09 pm God help me----------------------------------------Sam Peppiatt
Maybe God is trying to help you? You don't seem to be concerned about Bessler's work but only about yourselves.
Anyway, What was I going to say. Agor95, Yes, I did log in. I just supposed that gravity was the only way, to achieve Bessler's wheel. I see now that the smart money is on other methods and, the not so smart money, (like me), is on gravity powered wheels. It really took me a long time to figure that out. And here's the reason:
I grow up on a dirt farm in Kansas and had to carry water in buckets at a very young age. It was like the buckets were about to pull my arms out of there sockets. I guess that fucked up my mind with the idea; that some how gravity could be used to do work----------------------Sam
If you're not logged in, his posts will show up.
Scott should get a court order banning him.
