PROCESS RESTART
Re: PROCESS RESTART
le système à moins de potentiel pour tourner si les bras sont plus longs!
Nous sommes confronté au phénomène du funambule.
Voir test équilibre.
the system has less potential to rotate if the arms are longer!
We are confronted with the phenomenon of the tightrope walker.
See balance test.
Planetaire 2.zip
(420.01 KiB) Downloaded 88 times
Planetaire 3.zip
(634.39 KiB) Downloaded 93 times
Essais D'équiilibre.zip
(24.63 KiB) Downloaded 98 times
Re: PROCESS RESTART
Dans la série équilibrage, une idée!
In the balancing series, an idea!
STORK BILLS a1.zip
(372.3 KiB) Downloaded 65 times
Re: PROCESS RESTART
Shadow I built these styles to nausea. I don’t know the answer. Other than a different approach. Maybe two balanced but highly unstable systems fighting for the same space. They can’t stay balanced because the other one comes and knocks it out of balance.
Keep up the good work. I don’t mean any criticism.
Things don’t actually need to go around the axle. If something just moved always 5 to 4 you would have continuous rotation. But a dropped mass means it has to be picked up. So move force into rotation?
It has to do work also; how do you do that in balanced around the axle situation??? It seems MT48 is a more logical way forward.
Re: PROCESS RESTART
Bonjour Daxwc,
toutes les critiques sont les bien venues si elles sont constructives, bien argumentées et allant dans le sens de résolution de l'énigme.
Je liquide toutes les idées qui me passent par la tête en attendant une inspiration concernant les jouets forgerons!!
Hello Daxwc,
all criticisms are welcome if they are constructive, well argued and going in the direction of solving the riddle.
I liquid all the ideas that pass through my head while waiting for an inspiration concerning blacksmith toys!
STORK BILLS b1.zip
(345.77 KiB) Downloaded 110 times
Re: PROCESS RESTART
Celle du jour!
The one of the day!
Extraction3.zip
(334.71 KiB) Downloaded 74 times
Re: PROCESS RESTART
Celle du jour!
pentographe double L4.zip
(339.65 KiB) Downloaded 75 times
Re: PROCESS RESTART
Elucubrations de ce début d'année.
Dans la facture d'orgue, nous avons des touches et des mécanismes de transfert à levier, nous avons des tiroir ou registres d'ouverture pour le passage de l'air, nous avons des tuyaux et nous avons un système de soufflage d'air.
Dans MT nous retrouvons se qui a été énuméré ci dessus.
Nous avons des illustrations qui abordent aussi le domaine de la distribution d'air et de l'hydraulique.
D'où ma dernière élucubration, qui pourrait signifier que Bessler par la progression de l'étude de ses MT nous invite à associer les domaines de la mécanique et de l'hydraulique.
Le domaine pneumatique de part la compression de l'air peut servir d'accumulateur et délivrer des impulsions.
Le domaine Hydraulique permet le transfert de mouvement direct et avoir dans le schéma présenté un différentiel de densité.
Qu'en pensez vous?
Elucubrations of this beginning of year.
In the organ bill, we have keys and lever transfer mechanisms, we have drawers or opening registers for the passage of air, we have pipes and we have an air blowing system.
In MT we find se which has been listed above.
We have illustrations that also cover the field of air distribution and hydraulics.
Hence my last elucubration, which could mean that Bessler by the progression of the study of its TM invites us to associate the fields of mechanics and hydraulics.
The pneumatic domain due to the air compression can serve as accumulator and deliver pulses.
The Hydraulic field allows the transfer of direct movement and have in the scheme presented a density differential.
What do you think?
Re: PROCESS RESTART
SHADOW wrote: Fri Feb 09, 2024 12:37 pm What do you think?
Hydraulique ou pneumatique est une possibilité. La simulation de tels dispositifs est un problème.
Je vous suggère d'utiliser la pression vers le bas sur une masse dans l'arc inférieur pour déplacer la masse opposée vers l'avant le long de l'arc supérieur.
Puis un ressort pour réinitialiser la masse de l'arc supérieur le long de l'arc supérieur.
Cordialement
Re: PROCESS RESTART
I think this design holds promise because it involves a working fluid which is sensitive to changes in temperature.
Re: PROCESS RESTART
eccentrically1 wrote: Fri Feb 09, 2024 1:53 pm I think this design holds promise because it involves a working fluid which is sensitive to changes in temperature.
Well I should have stated there is a spring on both the mass at the top and bottom.
This keeps the pressure going and address temperature changes.
Of cause the home will be lovely and warm due to the device working as part of the central heating ;)
So the temperature will be stabilised by thermodynamic inertia; Now there is irony.
Re: PROCESS RESTART
No, no, no, SHADOW! I'm sorry you have lost it. No way forget that idea------------Sam
Re: PROCESS RESTART
Sam Peppiatt wrote: Fri Feb 09, 2024 3:47 pm No, no, no, SHADOW! I'm sorry you have lost it. No way forget that idea------------Sam
Eh bien, on vous l'a dit. Mendier pour la merce ;)
Re: PROCESS RESTART
Bonsoir Agor,
Je n'ai pas compris votre poste!
Good evening Agor,
I didn’t understand your position!
Re: PROCESS RESTART
Bonsoir Sam,
L'hydraulique permet de simplifier les transferts et peut permettre de trouver une solution concernant les mouvements que doivent faires les poids et trouver les compensations à mettre en œuvre.
Ensuite on pourras transformer la solution en mouvement mécanique si nécessaire.
le mouvement des poids est insuffisant pour générer un déséquilibre à mon avis, et comme nous ne pouvons pas jouer sur la densité des poids je pense qu'il faut en créer une artificiellement.(soit de l'eau, soit du mercure).
mais tous cela est de la théorie!!!
Good evening Sam,
Hydraulics makes it possible to simplify transfers and can make it possible to find a solution concerning the movements that the weights must make and find the compensations to be implemented.
Then we can transform the solution into a mechanical movement if necessary.
The movement of the weights is insufficient to generate an imbalance in my opinion, and as we cannot play on the density of the weights I think it is necessary to create an artificial one (either water or mercury).
but all this is theory!!
Re: PROCESS RESTART
Sam, ou en êtes vous avec votre roue?
Sam, where are you with your wheel?
