I think i should show you just how much you are off track here , on a tangent which had nothing to do with you in any way.
johannesbender wrote: ↑Fri Jun 23, 2023 2:35 pm
As the bible saying goes , separate the wheat from the chaff , so you better thresh to separate the good from the bad.
WaltzCee wrote: ↑Fri Jun 23, 2023 2:45 pm
I'm no scholar, yet I've read it a few times.
Since you brought up the point, I'd like to read it.
Do yo have a link, johannesbender?
WaltzCee wrote: ↑Fri Jun 23, 2023 6:47 pm
Luke wrote:His winnowing fan is in His hand, and He will thoroughly clean out His threshing floor, and gather the wheat into His barn; but the chaff He will burn with unquenchable fire.”
contrasted with:
Good! I'm very relieved. I thought you were speaking to everyone generally yet it's obvious you were only talking about those whose pronouns are capitalized! That sure excludes me.
Well, back to the real topic.
If one can mechanically model hyperbolic space, they can warp time. That was the principle of one of my failed efforts.
I'm watching intently.
Maybe you'll touch on something I missed.
You don't need to travel when your already there.
I think that would be enough touching for now.
And again , talking about the concepts i like about my design , that being bringing two points together instead of traveling from one to the other , the same theory is proposed to the effect that instead of traveling across vast distances in space that the points be brought together , the mass does not need to traverse when its already there .
Yet you :
WaltzCee wrote: ↑Fri Jun 23, 2023 9:10 pm
johannesbender wrote: ↑Fri Jun 23, 2023 8:57 pm
That was a very profound proverb. Here's one you might like.
Proverbs 30:6 wrote:Do not add to His words Or He will reprove you, and you will be proved a liar.
You can search my posts and see where I speculated PM needs a different math than euclidean geometry.
If you suppose there's something in it and would like to share, then you might consider getting off this tangent and get back to the matter.
ETA
Wed Feb 20, 2019 12:31 am
'till it breaks. Maybe a new geometry will emerge.
Look closely to the second link i provided you with , did i make up words or did i just say what they said , you have a problem with those words they put together to explain a meaning in their opinion go and take it up with them , if i want to quote a bible verse i would have done so.
I am talking about me taking the things i consider good and getting rid of what i think is bad about my design and theory , eg "with a discerning mind".
Yet you respond , calling me a liar , saying i twist words from the bible and i should go and search your posts ?
You butted in here and made the subject about yourself out of thin air , and after i explain to you i did not talk about you , i did not mention you , did not say you said things nor did i say you did not not say certain things .
WaltzCee wrote: ↑Sat Jun 24, 2023 4:30 pm
I just did , i took a nice big slice of cake and ate it.
This is going to be quite the magic act. I 'spect you will need to invoke the Orwellian spirit of double-speak.
Everyone is patiently waiting for your 'cake' to circle back around so we can watch you eat it the second time. You might want to call it 'cake' yet I'm more inclined to call it the stuff agor's brain is made of.
I don't honestly believe you can eat your cake & have it too, yet I'm sure you might eat someone else's cake and still have your cake.
That's what Bessler did. He ate Pythagoras' cake & still had his! Magic. Then he said it came from God. Then he said he figured it all by himself.
Bam! Magic squared.
- Intrinsic to the fabric of johannesbender's
hyperbolic 4-d time/space model is the stuff agor's brain is made of
Yet , instead of saying "hey im sorry its a misunderstanding " you keep throwing your "cake" around the room , hope you clean up when your done with whatever this is.
Well , nice knowing you and good luck , "mute".
