Ralph,
U asked about the toothpick...
Tried breaking one tonight when my wife an I were eating out. I think a toothpick is actually a lot stronger than the force I hand apply to each weight.
The wheel is not perfectly balanced. The weights are never evenly spaced. Like I said, it takes a large force applied by hand to go over the hump so the first weight falls, then once it does, everything smooths out, and there are no humps as long as I continue to apply that slight force at each weight.
When I stop tapping at each weight, the wheel stops after the next three weights pass.
Robert (The Carpenter's Boy)
you mean like this?
JB Wheeler
it exists I think I found it.
What happen man?
Too much math?
.......... sadly i have to report that "jonathan" ,.....OVER dosed on math in his ivory tower today..........
the doctor recommends bed rest and some lite algebra ....lol
Too much math?
Iwill speak for myself. Ralph is a fine brother and I would not suppose to speak for him. i am having some difficulty just as Robert is. there is tuning needed to make the light weight unit run correctly. It is not the end of the world yet. with the correct tweaking ours should be running. iT IS NOT running yet. I am working on something different and of magnetic application right now. Robert is doing great to be where he is with his unit. GOD is so good to us. jim kelly
I think you'll find that I did spell "vengeance" correctly.Coylo Buddy,
Gotta aim a little higher with me...
"Vengence"--- I want to avenge Bessler for the shabby treatment he received.
It ended up everybody thinking he was a swindler, (and many still do),
Coylo, a working machine would fix that problem.
I think you should consider changing your avatar from "The Thinker" to a dunce cap maybe?
I don't have to "aim any higher" when you make a good job of making yourself look stupid for me...........cheers!
Man, your pulling on my heart-strings with your little avenger mission, well.......maybe not!
Amen!
To a Judeo-Christian God goes the glory.
Ovyyus. Are U "in"?
Amen!
Ovyyus. Are U "in"?
"Failure" always takes the easiest way!
Coylo,
I see by your posts that U are a living example of your line above...
Coylo,
I never failed in getting under your skin, like I said.....it's so easy when you do it for me.
Yeah, Bill just loves to hang out in Judeo-Christian groups!
Blah, Blah........Blah.Amen!
Ovyyus. Are U "in"?
Last time I heard anything, he said he "might" be back in. Did U check on that?Yeah, Bill just loves to hang out in Judeo-Christian groups!
And how about U? U seem hostile to the idea.
Coylo,
Have U been drinking?? U sound like a real two fisted drinking man.
I don't have anything against spirits, but I never buy.R U buying?
I will however, drink any given amount.
Wheeler, Robert and all,
James kelly wrote.
James has supplied me with the original drawings and tolerance must be exacting, right now I am showing to be 3/16" to 1/4" out from meeting specs at critical radius points. At present the rotor is being tested without adding the driver weights, when correct it should turn on its own.
The race is on as to see who will admit to win or defeat first. As of tonight using james's calculations we are showing [an advantage of .3550298lbs] calculated on rotor weight only.
This is not enough to overcome "start up" and friction loss requirements. If I were to fire it up with a drill motor the results may prove to be interesting. That is not my goal, I know I will not have achieved 100% of possible net gain until it's a self starter. I want to meet or beat Bessler's ability to simply untie it and let it go. It is a one-way wheel and therefore be self starting with maximum torque at zero rpm. I will settle for no less and will not claim that the fat lady sings until I do so.
Any farther posts regarding the James Kelly wheel will be on his thread. Please do not hold your breath in anticipation as It may be awhile yet, I am a busy man with to many irons in the fire.
Thank you and regards
James kelly wrote.
Yes I have finished the reconstruction of the James Kelly wheel two days ago. No it is not running but requires no more applied input than Roberts toothpick every 45 degrees of rotation.Iwill speak for myself. Ralph is a fine brother and I would not suppose to speak for him. i am having some difficulty just as Robert is. there is tuning needed to make the light weight unit run correctly. It is not the end of the world yet. with the correct tweaking ours should be running. iT IS NOT running yet. I am working on something different and of magnetic application right now. Robert is doing great to be where he is with his unit. GOD is so good to us. jim kelly
Well, I always get my round in when it's my turn.
Well I enjoyed this little exchange, good luck with that wheel of yours Robert!
Hey, I'm a Bessler slut - I'll sleep with the first person to demonstrate a working wheel! - LOLRobert wrote:Ovyyus. Are U "in"?
