the clues give it away
re: the clues give it away
It is good to have differing opinions. Something new may emerge. As long as discussions remain cordial.
Right ON! I have always thought that is the foundation for this forum or any like it Discuss, debate, refute, learn, offer your opinion. question input etc.
Just click the button on the top menu bar that says "Chat."
Not too difficult. :-)
The trick is getting others to join you there.
Rather keep it out in the open for all to ponder. Chat room is handy for a one -on-one, but that is not what open discussion is about.
Does that mean you both agree? And as long as we live on this earth, you kiss and make up?
Its a gentlemanly, debate regarding physics for me and is not a lovers quarrel. please leave the personal references out of it.
While the chat room certainly has it's place, it leaves behind no record of discussion. I would like to see Jim and Ralph hash it out here were the record might prove useful to others.
My sentiments exactly I joined this forum for member participation regarding a device allegedly powered by gravity with no perception of it operating outside the gravitational pull of earth.
Open for debating thoughts from all who contribute. How else can we reduce the number of people repeating the same old designs or chasing the unknowingly already known by others.
Ralph.
evgwheel
Post by evgwheel »
opinionated....?
OK. I'm not sure how to proceed here with Ralph. How can I have a serious conversation when Ralph doesn't listen to what I say and he uses waffle words and weird sentence structures? But hey, none are perfect!
I'll back way up and start with a definition.
Moving Weight - A weight that is in motion. It could be a block of steel with wheel rolling across the floor. It could be a swinging pendulum.
Swinging Weight - A Moving Weight on the end of a lever that is moving in any curved path.
Pendulum Weight - A weight that hangs on the end of a rod and swings back and forth due to gravity.
Bessler says that his wheel gains energy from swinging/moving weights. This is the best and only wordings (English or German) that describes what (I think) he meant. The weights are not pendulums because they are not completely free to swing by gravity. Their swinging is complex. There are more forces causing the weights to swing than just gravity pulling downward like with a pendulum. I feel very stongly that a certain combination of 'pairs of pairs of interconnected weights' can gain energy from their swinging/motion. As such the inertia of the moving weights does not come from gravity, though gravity does play a role in powering the wheel.
So, that being said I'll look at what Ralph says.
Ralph wrote:The inertia of the moving weight was applied by gravity.
If a weight gains speed (and therefore gains momentum) due to inertial forces of other weights rather than due to gravity then the inertia of the moving weight in question was applied/supplied by inertial momentum, and Ralph's statement that it is from gravity is wrong.
Ralph wrote:A gravity operated machine cannot function and should not be compared to an object in outer space. You are trying to make a comparison using two different physical properties, gravity and no gravity. True it is the momentum inertia and or kinetic force that makes a weight swing,
If springs are used in place of gravity in an outer space environment and if the wheel gains its energy from swinging/motion then the wheel would still work. Ralph is using tunnel vision. He doesn't see that gravity cannot power a wheel, it must have some other force to supply the energy/power, inertial momentum is the only choice available, and as such the wheel would be powered by "the weight's swinging/motion" as Bessler said, and NOT by gravity.
Ralph wrote:True it is the momentum inertia and or kinetic force that makes a weight swing, But neither of these can produce the swing or cause a set amplitude without gravity. It is gravity that provides the to and fro which creates the inertia.
No, it is inertia working to and fro with any force, be it gravity or springs or even leveraging against other weights that can cause a weight to move to and fro.
Ralph wrote:I do not consider gravity as a secondary force as it is the root of all that procedes it, not precede it.
I guess this is a matter of opinion. But if gravity is a secondary force with a water powered wheel then it would be a secondary force with an inertia powered gravity wheel. Both would be powered by the out of balance weight which is secondary after the weight is first lifted up higher.
Ralph wrote:We are talking different creatures in the eye of the beholder. I consider any weight that swings no matter the physical connection that is activated/controlled by gravity will meet and comply with the known physics of a pendulum. I agree that it need not be called a pendulum. But if it swings like one reacts like one then by any other name it is a pendulum.
If it swings freely like a pendulum then it is a pendulum. But if it swings/moves like a swinging/moving weight interconnected to other weights, well... it can no longer can be called a simple pendulum, though you might call it a compound pendulum. It certainly doesn't swing and react like a simple pendulum. I find the best way to describe it is as Bessler described it: a swinging/moving weight.
Ralph wrote:True a swinging weight can be swung by many different forces, wind, muscle, etc. As for a weight swinging using CF, I am afraid that I would have to see some tangible evidence. True it will cause a weight to swing out but not in, and without in-out there is no swinging.
All I can do is laugh. Making two weights swing, one in and the other out is very simple. And each time they swing the CF is strongest in the direction that they swing, so they gain energy by swinging. But now is not yet the time for me to reveal how it might be done.
Ralph wrote:Please define/describe how a swinging weight differs in its swing from a swinging pendulum which is a swinging weight?
I think I answered this. A pendulum swings back and forth, to and fro in a simple balancing between gravty force and momentum force. A swinging weight is swinging on a rotating wheel and swings in a very complex path and is driven and pushed/pulled by many forces, and at times is prevented from moving by being latched to the wheel. A swinging weight may resemble a simple pendulum, but it doesn't act like a simple pendulum.
Jim_Mich wrote:I take it to mean that you think the pivot point(s) must change their locations in order for a wheel to work.
Ralph wrote:But yes you have explained my opinion very well. I believe that if the pivot point is attached (fixed) and the weights latch at a different orientation, then that different orientation will probably be symmetrical orientated to the disk all is mounted upon.
Huh? Ralph, did you by any chance work for a government agency in the past? Your words sound like government double speak. If weights swing between point A and point B then they will be unsymetrical (and thus out of balance) at one or the other (probably both) points. So how can you say that they will probably be symmetrical orientated?
Ralph wrote:There are how ever ways (In my thinking) to negate this problem and that is if the vortex of the weight/s is allowed to change its axis, or the pivot point comes from, physically in, on, or around the axis of the wheel axle.
Golly Ralph, I don't think there is any problem, all you need do is let the weights change their locations on the wheel! And the very easiest way is to let them swing from one location to another location. Trying to move the vortex/pivot point is doing things the hard way.
I don't wish to be intrusive, however...
Jim wrote:Bessler says that his wheel gains energy from swinging/moving weights.
Didn't Bessler state that the weights gain force from their own swinging/motion? A wing moving through the air gains force from it's own movement, but would you say that it gains energy?
Jim wrote:...gravity cannot power a wheel, it must have some other force to supply the energy/power, inertial momentum is the only choice available, and as such the wheel would be powered by "the weight's swinging/motion" as Bessler said, and NOT by gravity.
Jim, without proof how you can be certain that you're correct. Your unproven theory surely can't be used to rule out all other possible means of driving a wheel. Also, Bessler never directly stated that his wheel was powered by "the weight's swinging/motion" or that it was not powered by gravity. He never explicitly stated what powered his wheel - that was obviously his secret.
arthur
Post by arthur »
if the wheel does not work in outer space then gravity is the power
A water wheel does not work in space where there's no gravity (even if you have lots of available water). But a water wheel obviously does work on Earth even though it's not powered by gravity, it's powered by lifted water. Hopefully that doesn't sound too conclusive or absolute to anyone :P
arthur
Post by arthur »
i would say a water wheel is powered by water and gravity
arthur
Post by arthur »
why does a river flow
DrWhat
Post by DrWhat »
A river must have gravity AND a path to follow which is down hill (unless it's a waterfall) but it still needs a path. You can have a river and no path, but that is called a dam or lake or pond...
We too need to use gravity to solve the Bessler wheel, but we need to find the path along which the movement progresses
arthur
Post by arthur »
oh yes of course
Oh boy! this is going to be a long one so make sure your comfortable and maybe have some popcorn!
I listen to what you have to say, otherwise I would not be here to debate what you say. I am sorry if you find my sentence structuring not to your liking, but in the past I have made it clear that my clerical aptitude leaves something to be desired. I am a hands on show and tell type person.
"Waffle" to speak or write evasively, do you really think I do that on purpose? I do not, and I find the use of the word not only abusive but a premise or proposition which an argument is based on, or are you already drawing a conclusion to this debate.
No problem: moving, motion, the act or process of changing position or place.
To move or cause to move back and forth (to and fro, to turn in place as on a hinge or pivot.
Same definition as swinging, to maintain the swinging one must augment it with an occasional pulse (see swinging: to move or cause to be moved). This pulse in Bessler's day was provided by gravity. This was achieved with a mechanism called a pawl which could relate to paw in parable context.
The summation of this is that it is what you think. Fortunately each member has the ability to do this also and the difference of thinking is what brings debate.
Have you watched a novelty called Newtons gravity machine and seen the transference of a falling weight or weights cause other weights to swing upward. I call that transference of motion from one mass to another.
To my knowledge I have never made a firm statement that pendulums by themselves are responsible for creating a self sustaining rotating motion. I do not believe they can. I do believe however they do have there place. Not unlike Newtons gravity machine a pendulum could provide the kinetic energy to put mass in motion or move creating a force that in turn pulses the pendulum and drives the machine. look at it like an electrical capacitor it will build and store energy in the form of kinetic and or inertia with each swing.
Did I not question you when you let your pair of pairs thread die out?
I agree with the first half of this, but I lose it at "as such the inertia of the moving weights does not come from gravity. What do you base this statement on? Can you produce a sample showing how this inertia is produced? I believe gravity plays a major role in powering the machine. It is the foundation of and key force that powers the machine.
You can call this a summation of what I think!
I must admit, I have read this over and over and it makes me think of that word "waffle".
I have never stated that a weight gains speed due to inertial forces of other weights. What supplied the inertial momentum if not from gravity. The wording of this hypothesis is such that I cannot see a tentative explanation of facts that can be tested by farther investigation.
When a weight falls it gains inertia, it falls in response of gravity. I do not believe that weights gain speed due to inertial forces from other weights. once again I refer to Newtons gravity machine. when impact is made the motion is carried to the opposing weights. They do not gain any more acceleration than what was transmitted.
If springs are used and if the wheel gains its energy.........
I reiterate that I am not interested in comparing a theoretic gravity engine in a non-gravity environment, to many ifs.
You claim I have tunnel vision for believing that gravity can power a wheel and you have tunnel vision claiming it cannot. I agree that to my knowledge no one has come forward to substantiate your claim or mine.
We cannot refer to Bessler as that is what this is all about.
Therefore this part of the debate should be considered on hold until material evidence can be submitted.
To be continued>>>>
evgwheel
Post by evgwheel »
I apologize in advance for my silly question.
A weight will fall at an increasing speed (within the practical distance for a wheel) gaining momentum. But only to the level where it reaches the lowest point, it does not matter if it is on the end of a rope, hits the ground or is the lowest point of a turning wheel, or a pendulum.
Is that right? And if so, is that only created by gravity?
arthur
Post by arthur »
gravity makes weights fall
bluesgtr44
Post by bluesgtr44 »
I agree, Drwhat....
And that is a reason I may have gotten a little carried away with the "...enclosed in a structure or framework." interpretation....Something like that would definitely maintain a path, would it not?
Another witness statement that I appreciate is the one from J. E. Fischer. It is where he talks about how the wheel accelerates from within and that convinces him more of the fact that it was a PM than if it had run a whole year....I'm at work so I can't provide an actual statement. He was so impressed that when he gave it just that little push to start, it grew in speed and force...and his inspection convinced him there was no outside trickery involved. I agree with his assessment of the higher proof of PM.
Steve
bluesgtr44
....And gravity would be the resultant of?????
Steve
