Trevor Lyn Whatford wrote:
Hi kaine,
that is a bad example try Daxwc experiment and add a weight to the under side of the opposite side of the pan!
Regards Trevor
Tarsier .. I think Trevor's suggestion from dax's experiment is closer to the mark regarding my proposal.
In the double levered drawing [your interpretation of Chris's ideas] with a compressed weight bag between you have proven one of the tenets of the hydrostatic paradox - that the weight force on the scales equals the summed masses of the components - that is what I would expect.
However, I am proposing that the applied mass increases the energy density of a fluid [in my case a liquid because I can increase PSI easily without adding compressed air for example] in the form of pressure - the critical difference to your experiment is that the 'container/structure' doesn't change shape & therefore the continuous distribution of fluid mass remains constant [density is the same] & there is no lowering of the system CoM [of individual parts] as per your drawing - this energy density is evenly distributed thru the liquid therefore there is a virtual displacement of mass for want of a better description at this time.
I would like to build up a picture of understanding of the fundamental principle with your help & others if they wish to contribute, as some have done already - in this way the hole in my logic may be found, perhaps sooner than later.
I'd like to start by asking you to do a small experiment with your scales - place a beaker on them almost filled with water - take a reading on the scales - now slowly push your finger into the liquid & then stop [don't touch the beaker] - what does the scales read ?
It should read higher by 10-20 gms or so - this experiment is to prove two things.
1. Newton's Law of for every Action there is an equal & opposite reaction.
2. That the weight reading on the scales is dependent on the internal pressure [force] on the bottom of the beaker - clearly your finger supported by you did not add any mass to the system to record a higher weight - so your finger displaced a volume of water which raised the water level & this created a higher pressure inside the beaker on the bottom surface.
N.B. number 2 goes towards proving that buoyancy force is a pressure differential.
If you find the same results is that how you would interpret the results ?
