If I wanted to, I could take all of your statements, one by one, and refute every one of them. But it is not time yet for me to disclose all.
Identical is impossible because no one know exactly the internal construction.CC wrote:JM claims his device is identical to the original Bessler Wheel.
But yes, I feel very strongly that the principle of operation is the same as Bessler's. Bessler built a couple one-way wheels and he built a couple two-way wheels. Obviously they were not identical. And obviously my wheels are not identical to Bessler's. And if you go back thru all my posts, you will never find me saying my wheel is identical to Bessler's
What you are doing is reading words, and then prejudging what is said. For instance, if someone, say Bessler or anyone, writes about "weights" in a wheel, what comes to your mind? Most people will think of an out-of-balance wheel. But what if the wheel is always balanced and it is the inertia and momentum of moving weights that rotates the wheel?
What if someone writes that weights move in and out? You might misunderstand, thinking that this means the weights move inward on one side and outward on the other side, so as to cause gravitational unbalanced, even when the witness says the wheel was balanced. This is prejudging.
I could go on and on. Even the fine people who have translated Bessler's words can misunderstood and cause the translation to say things that was not said in the original.
I have looked at all known Bessler clues. I even posted a list of fifty clues. Back then, five yeas ago, I did not understand some of those clues. This was always a learning process. I now understand all of them.CC wrote:But Jim's device does not match Bessler's clues in any significant way.
Everyone knows that multiple copies of a single mechanism can be placed around a wheel.CC wrote:Jim says he only uses two weights.
There are a lot of things about my wheels that I have not described here on this publicly read forum.CC wrote:Jim does not describe use of impacts in his device.
What am I, the pet whipping boy for all the Bessler forum trolls? I'm done here for now. Time to hide under a rock again.
