You continually assume things incorrectly. In the past I've only brought up the subject of radius of gyration because so often I've seen people make wrong calculations concerning wheel momentum. Many times they assume that all of the weight is at the edge of a wheel.Mr. Furcurequs wrote:Based upon what I've seen of jim_mich's calculations, though, and what I've seen him mention about radius of gyration, it is my own suspicion that he has simply somehow misused the formulas and gotten excited about bogus results while also somehow tying it in with his CF notions.
You will note that at the end of the aforementioned calculation I wrote: "Hopefully I've made no mistakes. I make no guarantee. I've checked and double checked and believe this is the correct answer." This was one of the few times I attempted to do a calculation in metric. I normally do all my calculation using English variables. I have a natural 'feel' for them. When working with metric values, they are just numbers in the calculator. But I know instinctively the length of a foot or inch, the volume of a US gallon, the weight of a pint of water, the height of a 6 foot wheel, etc. If I'm doing calculations and I screw something up, I quickly recognize it when working with English values.
But metric values are foreign to me. If I screw up and by mistake divide a number instead of multiplying, then the results are just numbers, and I might not catch the mistake. Which is why I wrote the disclaimer at the end of that posting: "Hopefully I've made no mistakes. I make no guarantee. I've checked and double checked and believe this is the correct answer." The calculations results might not be correct. But the method is correct. I was simply trying to be helpful. I'm done trying to be helpful. I'll never try helping anyone with anything ever again. Screw you guys.
The bottom line is that there is such a thing as Radius of Gyration. To refer to radius of gyration as being "so called" and thus insinuate that it is something I just made up, shows a lack of knowledge. Radius of gyration has been around long before I was born. And I was born a long time ago.
Radius of gyration is simply a mathematical tool to help calculate the rotation or swinging of wheels and pendulums. Nothing more. Nothing less. If you don't know the actual radius of gyration then the results of any calculation concerning swinging or rotating will be only approximate, because you are left with assuming the radius at which the mass is located rather than knowing it.
