Design Status Update
Andyb
re: Design Status Update
Post by Andyb »
Retire ha.
AB Hammer
Post by AB Hammer »
Retire? Whats that? I don't think there is anybody here who will ever be able to truly retire. Just take more breaks. LOL
Silvertiger
Post by Silvertiger »
I need a damn good engineer. I have the working model in sim, but the arrangement of interfering parts and interfering frames severely tests my limits. >.< Brick wall...where's my sledge? O.o
Does your sim work with only one set of weights (and balancing weight if you need)?
Silvertiger
Of course. :)
Understand what makes the principle work. Reduce to simplest design. Build.
Silvertiger
Believe it when I say there is nothing simpler; nothing more reduced. That's not the problem I'm having lol. Even though it's not Bessler's design, I understand what he meant that by showing it, it would be so simple and laughable that people may not think it to be worth anything. I showed it to a buddy of mine who summed it up..."REALLY? That's it?"
justsomeone
Post by justsomeone »
An extremely simple design yet you need a damn good engineer? Would a carpenters apprentice do? :)
Silvertiger
Nope, not in this case...an engineer. Even though the layout is simple, the interaction of the parts requires the engineering of two separate frames, yet intertwined. And that's for my standard design. However, I do have two backup work-around designs, also working in simulation, just in case; possibly a third that also works in sim. Only ONE of the backups uses one frame.
AB Hammer
Post by AB Hammer »
Silvertiger
Flip you lever over and examine the effects from the other direction, then do side to side.
Silvertiger
Interesting. Would you flip a car on its back and then try to drive it? lol :P Side to side doesn't matter, since it's driven by gravity. However, it's interesting to note that a 90 degree orientation works since gravity still has an effective influence, but it requires more parts and fine-tuning and a redesign of parts orientation, so why bother?
justsomeone
Could you explain what you mean by separate frames. Thanks
Silvertiger
Re: re: Design Status Update
Silvertiger wrote:The bad news is that the arrangement of the parts is such that designing and fabricating it would be the best engineer's nightmare on structural reinforcement alone, since they interact in such a way that two frames must be built, since it is two intertwined and interdependent mechanical systems.
Best I can do. :)
http://www.besslerwheel.com/forum/viewt ... ht=#131236
One more thing. Did you build the simulation to an appropriate size and weight? Wm2d can have problems with huge or extremely heavy objects.
You have sparked my interest on this one. Let me guess: you are using a spring in place of the weight. The spring pulls your two frames together causing them to rotate.
justsomeone
Thanks Silver.
I am sure you are accounting for the weight of the mechanism itself and its position. It it balanced?
