I'd love to do that...all of it! :-)I'll stop working on my wheel and start gardening as soon as I see you and your working wheel on TV.
Merseburg1, What I see..
re: Merseburg1, What I see..
I, too have viewed the clip. Here is what I see.
A fabricated support made of channel and angle iron with two "Dodge" type self aligning bearings attached to angle iron. If Darrell made this he is a proficient welder as the angle to channel shows.
The axle appears to be a drive section from a vertical turbine pump or something related. Such material is usually an alloy of nickel (Stainless steel)
The spokes appear to be of same material as axel, although I would imagine galvanized pipe lengths with a common "T" threaded to outer end. Two nipples are screwed into each "T", and dumbbell weights are slipped on with a common cap to hold them.
I am not saying "that is what it is" but rather my interpitation at this time.
Such a setup will have a considerable mass around the radius and with low friction bearings this thing could turn for a long time after a good push. As I have done he could even reduce the friction more by using an oversized I. D. bearing, where as only the bottom portion of axle is resting on bearing race. Bearing race and axle react as a hamster wheel, one turning inside the other.
I have built similar concepts to this and after giving it a good push, left my shop and went into the house poured a cup of coffee, went back to the shop and it was still turning. After the initial push to start, it appears to stabilize at a given rpm for a duration before slowing down to a stop.
For a flywheel, it can't be beat in a limited home shop. Everything can be found at your iron recycle yards and hardware store.
This fraudster must think we're as stupid as he is. Go here in the Fraud Forum, http://www.besslerwheel.com/forum/viewtopic.php?t=705 , and read his own description with my drawing to follow. It's that simple and it's that stupid.SSMITH & JONATHAN, HAS JUST COMPIMIZED OVER TWENTY YEARS OF WORK AND YOU WONDER WHY I WILL NOT SEND THE WHOLE VIDEO.
I HOPE WHAT THEY HAVE JUST DONE, WILL ANSWER THAT QUESTION.
Vandusen is just trying to distract us with this stupid rant and his dumb questions about Bessler's illustrations. He will never stop lying in an effort to hide his crimes.
Ovyyus,
As Darrell described his wheel in his post and you created an accurate drawing of it, its in the public domain and therefore cannot be patented.
This also means that the information considered confidential and covered by the non disclosure agreement is no longer confidential.
We call it an own goal in the UK.
Pete.
Pete.
Bill McMurty,
Do (YOU) think you have broke your non-discloser agreement and put my wheel in the public domain.
I have never given full discloser and never will!
If someone else thinks they have, that is their problem.
YOUR WORD IS STARTING TO LOOK WORTHLESS?
SO IS YOURS, PETER CLARKE.
VANDU
VANDU
Pete, I agree that Vandusen's scam wheel is fully described in that post of his. He disclosed it himself into the public domain and anyone could produce the same drawing I posted based on his own description.
Darrell, if my word was worthless then I'd have already posted all those photo's, video's and conversation logs I have. On the other hand if your word had any value at all then you wouldn't be called a lying fraud.
I had forgotten about that thread, that is the complete disclosure as I know of it.
"Darrell, if my word was worthless then I'd have already posted all those photo's, video's and conversation logs I have."
Same goes for me, all that I've shared is pre-nondisclosure. Though the nondiscloser is invalid, I intended not to share anyway when I signed it, and I'm going to stick with that.
Bill, I am sure your word is credible to everyone else and I am sure you think you are doing the correct thing. I just do not see the reasoning for what you are saying. I found you a good person during our conversations on the phone but I do not know what I did to you, that would make you do these things? As for Peter, I just do not know?
This forum is not being used, as it was intended. I try to keep my thoughts to myself, in regard to what I would like to say to some people but again, this is not the purpose for this forum.
It is past time, that the forum be used, for what it was intended and not for anything else.
Lets get back to what I have tried over and over again to discuss, Besslers wheel and other related topics.
With all the expertize on this forum, it would be nice if we could agree on an outcome and use the energy that has been wasted on ( bu.l-sh.t.) to find a way of putting something new, on the world market.
Mr Vandusen
Mr Vandusen
"Lets get back to what I have tried over and over again to discuss, Besslers wheel and other related topics."
If you have a working wheel then you'd have next to no incentive to discuss this.
Darrell, can you really be so stupid or are you pretending again? I think you're just continuing with your little scam and fi$hing around here waiting for another nibble. Generosity towards you has been consistently repaid with lies, deceipt and theft. You are a shining example of what not to be or do - congratulations! Go away.
Yeah! What is your purpose here, Darrell? Tell us why a person with a working wheel needs to do any more discussing, if not to give details of what he already has?
I would want to be the first one to be on your side and make sure you get credit for such a discovery IF you prove what you say. I would also want to be the first one to discredit you if you can't prove what you say.
So far, guess which side I'm leaning?
I agree, we've wasted enough time on your bogus BS wheel.With all the expertize on this forum, it would be nice if we could agree on an outcome and use the energy that has been wasted on ( bu.l-sh.t.) to find a way of putting something new, on the world market.
Darrell, Darrell, Darrell, Its all over, you can keep the money but please return my goods, my address is on the NDA.
Darrell,
Stating my name "AS FOR YOU PETER CLARKE" on this site does not cause me any discumfort what so ever, anyone with half a brain can work out a guy calling himselfe Pete with a log in name of Clarkie could be called Peter Clarke.
As I have already posted that I am an inventor working in the plastics industry and I'm based in Petworth England, I'm obviosly not bothered about anyone checking up on me.
Pete.
AKA Peter Reginald Clarke, Clarkie, Plastic Pete.
Pete.
