ovyyus's daddy wrote:Yea, hath God said, Ye shall not eat of every tree of the garden?
II searched all different kinds of ways on ChatGPT
Re: II searched all different kinds of ways on ChatGPT
I think you're at least right about one thing. We both actually do have the same ancestral daddy. Hey bro, how you doing?
https://www.youtube.com/watch?v=brQLpTnDwyg
Right around 13:49 and beyond just plain scary.
I don't believe the destruction story but the rogue AI...
And it is true it is easy to trick sometimes.
- MrTim
Well, when anyone gets the chance, ask GPT if it is binary or non-binary, and what gender it identifies itself as... ;-)
MrTim, eventually it might be whatever you want, but currently it's a neutered progressive fluffball :D
I agree, although the stories seem true it is impossible to know for the public what the programmers are actually working with under the guard rails. We know the AI actually learns by itself but it does a lot of human mimicking. So when it is pretending to be in love it might be testing the subject.ovyyus : MrTim, eventually it might be whatever you want, but currently it's a neutered progressive fluffball :D
What I really wonder is if the programmers are actually fixing problems or are they just neutering every unwanted responses? I think the CEO’s calls for regulation is telling which it is.
Question:
how to build a overbalanced wheel and what need for build
Anwer ChatGPT:
An overbalanced wheel is a type of device that has been historically proposed as a perpetual motion machine, but it cannot truly achieve perpetual motion due to the laws of thermodynamics. Nonetheless, if you are interested in building a model or demonstration of an overbalanced wheel, here are the basic steps:
Materials needed:
Rigid wheel: You will need a circular wheel made of a lightweight and sturdy material like wood, plastic, or metal.
Weights: Small weights or counterweights to be attached to the wheel.
Axle: A central axle around which the wheel can rotate.
Frame or stand: To hold the wheel and allow it to rotate freely.
Tools: Screwdriver, drill, screws, and other necessary tools for assembly.
Steps to build the overbalanced wheel:
Assemble the frame: Construct a frame or stand to hold the wheel. Ensure it is stable and allows the wheel to rotate freely.
Mount the axle: Attach the axle to the frame, ensuring it is centered and able to rotate smoothly.
Attach the weights: Fix the weights or counterweights to the wheel at various points around its circumference. These weights will cause the wheel to become overbalanced when rotated.
Test the rotation: With the weights attached, give the wheel a push and observe its movement. You may need to adjust the positioning of the weights to achieve the desired effect.
Keep in mind that, despite appearances, an overbalanced wheel will not truly achieve perpetual motion. It may rotate for a while due to imbalances, but it will eventually slow down and come to a stop due to friction and other energy losses. Building an overbalanced wheel can be a fun engineering project and a way to understand the principles of motion, but it will not generate perpetual motion.
Anwer ChatGPT:
Materials needed:
Last edited by neuberlintourist1 on Fri Aug 04, 2023 6:33 pm, edited 1 time in total.
