PeterAX
Post by PeterAX »
To Robinhood46.
Hi Robinhood46,
Thank you for your nice comment!:) Well, in my poor opinion moderate doses of Russian vodka (the same for a high-quality whiskey) are able to generate miracles from time to time.:) Don't you think so?:)
PeterAX
Post by PeterAX »
Consider carefully and thoroughly again (and many times, if necessary!) the link https://www.youtube.com/watch?v=xX14NK8GrDY
A key component for a proper understanding of the zigzag mechanical concept is the SIMPLE OBVIOUS FACT, that the zigzags generate a mechanical effect, (a) which is absolutely identical and equivalent to friction and (b) which does not generate heat. And this SIMPLE OBVIOUS FACT is clearly explained and described in PART 1 and in PART 2.
And now focus on PART 3 where:
Ma = 1 kg
Mb = 4 kg. (The value of Mb can be either increased or decreased as many times as you want.)
V1 = 1m/s = const
Ffr. = force of friction inside the zigzag channels = 0.0000001 N. (The latter can be further decreased as many times as you want.)
N = number of zigzags = 10. (The value of N can be either increased or decreased as many times as you want.)
Shapes of the zigzags = sinusoids. (The latter can replaced by any other curve patterns.)
QUESTION 1: V2 = ? (How many meters per second is V2 equal to?)
QUESTION 2: V3 = ? (How many meters per second is V3 equal to?)
Simply answer the above two simple questions.
Looking forward to your two answers for the 6th time.
Robinhood46
Re: re: IS THIS A REACTIONLESS DRIVE OR A PERPETUAL MOTION M
Post by Robinhood46 »
PeterAX wrote:To Robinhood46.
Hi Robinhood46,
No, i don't think so.
Alcohol plays around with the oxidative process in the body at a cellular level. This can sometimes have serious effects on the inflammatory process. Inflammation is only a good thing when it is fully controlled.
Anyone who has an health issue which has an inflammatory aspect (most illnesses) should seriously consider staying away from alcohol.
https://pubmed.ncbi.nlm.nih.gov/17570440/
"Alcohol-induced oxidative stress is linked to the metabolism of ethanol involving both microsomal and mitochondrial systems. Ethanol metabolism is directly involved in the production of reactive oxygen species (ROS) and reactive nitrogen species (RNS). These form an environment favourable to oxidative stress. Ethanol treatment results in the depletion of GSH levels and decreases antioxidant activity. It elevates malondialdehyde (MDA), hydroxyethyl radical (HER), and hydroxynonenal (HNE) protein adducts. These cause the modification of all biological structures and consequently result in serious malfunction of cells and tissues."
RH. He needs you to be drunk. That is the only way he might convince you.
re: 💩
PeterAX wrote:To WaltzCee/MrTim/Tarsier79.
Try some Russian vodka!:) Because as if the whiskey therapy does not work!:) (But be careful -- don't drink too much in the beginning!:))
this is a test
PeterAX
Post by PeterAX »
To Robinhood46.
Hi there,
Thank you for your reply.
Well, I do not know how to cure the severe mental disorder, which WaltzCee/MrTim/Tarsier79 suffers from. Obviously alchohol small doses therapy does not work. Do you have some other suggestion?
PeterAX
Post by PeterAX »
Consider carefully and thoroughly (and many times, if necessary!) the link https://www.youtube.com/watch?v=xX14NK8GrDY
Answer the two simple questions below.
Looking forward to your two answers for the 7th time.
Ma = 1 kg
V1 = 1m/s = const
Answer the above two simple questions.
Robinhood46
PeterAX wrote: Well, I do not know how to cure the severe mental disorder, which WaltzCee/MrTim/Tarsier79 suffers from. Obviously alchohol small doses therapy does not work. Do you have some other suggestion?
The only thing i can think of, is that they should avoid "triggers". try to not expose themselves to the sort of thing that triggers this kind of behaviour.
That being said, i do think they have tried to do this.
Just as many others (myself included), they have probably contributed to you having the reputation of "disregarded by many".
With a bit of luck, many more will try to avoid triggers, by adding a few red dots to your profile. If only we could get you to being "actually banned", then they will no longer be in need of your treatment plans, that appear to be very ineffective.
If you are that concerned about their well-being, instead of giving crappy medical advice, you could just shut up, or go away.
I do hope this helps, i can't think of anything else you can do to help them with their mental disorders.
RH46
PeterAX
Post by PeterAX »
To Robinhood46.
Well, you (as well as Sam Peppiat) seem to be an honest and smart person and because of this I would not like to argue and quarrel with you. I am asking only two simple questions and I am looking forward to the related two simple answers. And nothing more.
Looking forward to the related two simple answers for the 8th time.
PeterAX
Post by PeterAX »
To Robinhood46.
Let me tell you a few words about this forum's phenomenon, which is called WaltzCee/MrTim/Tarsier79 (WMT).
A) Firstly, in my poor opinion, one and same person stands behind the three pseudonims WMT. And this person is most probably a man.
B) Secondly, WMT uses a few manipulation tricks, which are as follows.
B1) Constant distortion of the opponent's words.
B2) Imitation of pathological ignorance and/or pathological lack of understanding.
B3) Using of direct insults and/or mockeries.
B4) Talking about things, which have nothing to do with the topic discussed.
B5) Some combination of the above four.
In one word, it is more than evident that WMT is a professional (but clumsy and unskillful) manipulator, who is a paid agent of the official science mafia. WMT makes some money by trying to manipulate the audience in a clumsy and unskillful manner.
Don't you agree with me?
P.S. When I was a child one of my favourite heroes was (and still is!:)) Robin Hood, the protector of the oppressed.:)
PeterAX
Post by PeterAX »
Asking my two simple questions for the 9th time.
Looking forward to your two answers for the 9th time.
Robinhood46
PeterAX;
No, i don't agree with you. I think WMT is simply a figment of your imagination.
I also think that the reason you think WMT is a phenomenon, is because you are confusing your imaginary character with yourself.
Here are the first ten, of hundreds of reasons, i think you are the problem.
1 You keep repeating the same nonsense, irrespective of anyone's comments.
2 You keep repeating the same nonsense, irrespective of anyone's comments.
3 You keep repeating the same nonsense, irrespective of anyone's comments.
4 You keep repeating the same nonsense, irrespective of anyone's comments.
5 You keep repeating the same nonsense, irrespective of anyone's comments.
6 You keep repeating the same nonsense, irrespective of anyone's comments.
7 You keep repeating the same nonsense, irrespective of anyone's comments.
8 You keep repeating the same nonsense, irrespective of anyone's comments.
9 You keep repeating the same nonsense, irrespective of anyone's comments.
10 You keep repeating the same nonsense, irrespective of anyone's comments.
Please read, reread and then read a few more times, each of the above remarks.
I am looking forward to your thoughts on each of them.
RH46
PeterAX
Post by PeterAX »
To Robinhood46.
I am totally disappointed by you and by your hypocrisy and total lack of ethics and morality!
You try to hide your incompetence and/or your desire to manipulate the audience by using the same manipulation tricks B1 - B5. I am sure that you are a memer of the same manipulation team. How much do your masters pay you? Shame on you!
Robinhood46
I am still waiting for your thoughts on the ten points i posted above.
To make things easy for you i will only ask you to reply to the first three.
Looking forward to your three answers for the 2nd time.
Dear Peter AX,
This may seam like a strange question; but, are you a girl? I think you must be a girl, you're too nice to be a guy-----------------------------------Sam
PS You don't have to answer that.
