Iris wheel
re: Iris wheel
I'm certain we're not done, I'm part way through another attempt that doesn't use K'nex for arms (they were too thick).
"What must the neighbors think?"? You can't even tell from the picture if it's 5 feet wide or 60. But many neighbors have pools, it's hot here.
re: Iris wheel
If I had a pool like that it would need to be empty five months each year, else it would freeze and crack and the water would leak into the ground. And I'd end up with drowned deer unless I put up an eight foot fence.
- or -
I could have a Bessler wheel driving a heater keeping it warm and toasty all winter long and chain a guard dog near the pool.
- or -
re: Iris wheel
LOL. We get drowned rabbits, mice, and bugs, and even the occational frog (though obviously they don't drown). They never see the pool coming, it is so unexpected, and possibly unheard of, to those critters.
re: Iris wheel
jonathan i have the same problems with my pool, if i can figure out how to post my own images i'll put up a picture of mine too so you wont have to take all the heat, (pun intended)!!!!!!!
re: Iris wheel
If you post your pool, you should have a wheel in it, or else it is just a waste of Scott's space.
re: Iris wheel
i'll get right on it, and i'm 100% sure the wheel will turn,and accerlerate!!! do you think it will matter if there's a racecar attached to it ? if i can crop the picture so the car isn't shown! it will give off one heck of a roostertail!!!!!
re: Iris wheel
If you think your pool is good, you should see mine: CLICK HERE
Can't say I have the same problem with rabbits etc, not sure why!
All the best
Stewart
All the best
Stewart
re: Iris wheel
Here's mine too!
Trev.
Trev.
re: Iris wheel
Guys no more joking around i have a new and improved virsion on how the wheel should operate/funtion. I've asked Scott to do a (cad) recreation of our newest design. refering to our design I will credit Jonathan for his help and let me bounce my ideas off of him. So, be patient, quoting Jonathan (a change is coming). Gordy
re: Iris wheel
I didn't mean what do the neighbours think of your pool, I meant what must the nosey neighbours think of your pool with an overbalanced KNEX gravity wheel thingy in it. Maybe I'm stereotyping my nosey neighbours and applying them to you.............maybe you have no neighbours. Anyway I'm sorry for starting all this crap.
Lets get back to business here, there's a change coming.............apparently.
re: Iris wheel
I see that Scott hasn't gotten around to posting the idea, Gordon sent it to me too, so I'll do it. I don't understand it, so it's up to Gordon to explain.
re: Iris wheel
Here is Gordon's explaination, clipped from an email:
" the 7 oclock wheel is on a bell crank via a spring on a reverse bell crank so theoretically what ever pressure is needed at the bottom can be reversed leveraged via the bell cranks to exhert the energy that is being used at the 8 (just don't lose the energy) to the 2 oclock position store it instantaneously as pressure against the throw, inside of the wheel. so the bottom wheel rides on the outside and the upper spring rides on the inside. each roller tip has to have the ability to sneakdeep enough into the next arm that the rotation will have a smooth transistion between arm to arm (where the 8 oclock wheel rides,smooth) now if you do the geometry it shouldn't be a dirrect drop in because it needs to roll out of it. now the crevice you have being beveled towards the inner side becomes a bump for the next rotating arm, the spring pressure thatt's holding the bottom arm in ends up being the same spring pressure that makes the upper wheel launch the arm when it comes to the crevice bump by it at approximately the 2 oclock position. the inside of the circle sees a spring loaded bump at 2 oclock and the 8 oclock spring is the pinch and essentially a torque governor."
re: Iris wheel
for those that dont get (IT) i will do a accurate draing, tomorrow .jonathan probably wrote exactly what i sent him and my description dident flow, (crossed spring working 90 degree bellcranks!!!!!!!) pich up at 8oc. / push out at 2oc.
re: Iris wheel
Yes, I copied and pasted from the email. Here is another picture from Gordon:
re: Iris wheel
thanks jonathan this took about 10min. to sketch, foever to desribe and sending it to you to get it posted . (10/4) gordy ps. the last one was a 2 min.theoretical concept doodle!! that probably lost everyone!!! tweak on this ,as far as rotating the spring loaded bar,to find the sweet spot maybe clockwise.ect. ...............................
