WM2D hints, tips, tricks, etc..
AgingYoung
re: WM2D hints, tips, tricks, etc..
Post by AgingYoung »
Judd,
Thanks for passing on the image converter. This is a test. :)
[img]C:\this didn't work\twelve_thumb.gif[/img]
Gene
ps: but the file size is much smaller! Cool, Judd.
Working Model 2DImage
JuddBrooks
Post by JuddBrooks »
Wm2d defaults/customized settings like 'air' resistance, etc.
Have you been wondering about how to customize your settings and have software remember them?
Suppose for example, you want to have 'air' setting on 'low' on a regular basis. Or alot of different values from all the 'tab headings' across the top of wm2d front page. Just make all the updates to all the options you want, then go to 'world' / 'preferences' (bottom of list) and do a 'save current settings'.
Now wm2d will remember YOUR 'default' setting each time you create a new file. (does not apply to files you have downloaded from others!)
Looking for fellow inventors who want to share and go public (without patents/selling) to jointly develop a couple different bessler wheels :)
303.921.1554 cell anytime
JuddBrooks
Want to make the same change to alot of items/objects. Like making the weight of all your rollers the same. Or want width and length of spokes all the same.
1. click window, click properties, click geometry, click appearance to pull up the menus
2. Just hold down shift key, click on all the items/objects that should be the same to select them, release shift key, update appearance (color,etc), or properites (like mass weight), or geometry (like width/length).
wm2d will update all the highlighted/selected items/objects. A great time saver and way to have consistency. :)
amateur
Post by amateur »
amateur
Post by amateur »
On making (virtual) latches with wm2d...
http://www.besslerwheel.com/forum/viewt ... 7471#27471
