Gravity motor motto...
re: Gravity motor motto...
.....can be expressed as a "pulsating mass " due to gravity fall and inertia.
To pulsate is to expand and contract rhythmically,as the heart.
A simple image needs :
-a fulcrum,support,pivot
-a stick ,bar,first class lever
If the stick has an end rhythmically expanding (top position) ,then contracting (bottom position) ,theoretically we can hope for "self" motion...
Maybe,the swinging sticks movies on youtube can help you to perceive a possible simplicity ,so to test if this mental image is "fancy" or reality...
We can see it ,inside the actual theory ,as a pulsating physical (counterweight) pendulum,also...
All the best! / Alex
but anything rhythmical or expanding or pulsating requires that energy which causes it to do such things
where does THAT energy come from?
Hi D. !
I have no answer about your question : "...where does THAT energy come from?" . It's a difficult philosophical "WHY?" type one...a "deep" thinking in the future ,will tell us more...maybe.
There are,for the moment some "surface" questions,without any convincing explanation...
For instance,the full up -down inverted pendulum fall in gravity,or the motion of a trebuchet during launch can become fairly complicated,and cannot be fully understood using intuition,only...or mathematics.
But you see,so many times,we can play simple games , without any prior perceiving of their full meanings...let's say the trebushet throwing.
My proposal was to replace the "throw" with the " commutation " in the top point...a kind of "move inside" of the variable arm.
All the best ! / Alex
.....you can find on net (Gravity_Motors domain),more precisely at:
http://peswiki.com/index.php/Directory:Gravity_Motors
..sounds as a challenge , a call to engage in a new contest ,regarding a possible mechanical self-running device ,due to gravity fal /"flow":
"For a rotary device to <work> ,it has to achieve a full 360 rotation,with acceleration between each complete turn".
Sometimes,the truth is stranger than our fiction...because all things are difficult before they are easy.
.....can be,simply :a counter weight simple machine, a weight-counterweight play ("game") with gravity and inertia.
We know a lot of machines,that use counterweights to raise a load...but our aim is a mechanical advantage "free of charge".
.....can be,simply :"gravity fall into spiral motion".
This happens in a counterweight variable lever/trebuchet.
A spiral motion of a small mass,due to gravity fall of a large mass,is a momentum increasing process,that can give us that "impetus difference" to spring again and again ,the "starting torque".
Who "pays"? Apparently,maybe,the jerk/yank acceleration...as a "deep",nonlinear "trait" of inertia ?!
.....can be the continuous "unbalance" fall.
So,we need to imagine and test :
-an (elementary) unbalance
-to introduce this unbalance in a closed loop
Try to make a simple transfer of thinking :the mass fall into the torque
fall ,inside
the same natural (momemtum) accelerator.
Let it fall...the unbalance...
fall ,inside
....this time a "sans paroles" one , when a visual perception can tell us more than a lot of words , at : www.youtube.com/watch?v=tt1S8P2dJcY
Nik plays torque difference due to gravity,alike a "falling mass" and inertia as an in-out storage(push-pull).
It we replace Nik with "something" astonishingly simple...we must remind Bessler's "heritage":
-"the greed is an evil root"
-"...the machine is so simple that a carpenter's boy could understand and MAKE IT..."
-"...one pound can cause the raising of more than one pound..."
Nik's performance is a concise expression ('minimum minimorum") of a possible gravity motor : fulcrum,lever and a single unbalancing mass..."non multum,sed multa ".
.....can be : "drow out gravity unbalance", in a semicircular free fall ,so to "amass" more and more potential energy into kinetic energy.
Everything we do is in relation with gravity , this everlasting "pressure" that we play moving as a continuous balance - unbalance switch.
Our purpose is not to create power (it's a misunderstanding...) ,but to liberate it...all that we can do , is to set it free,or to put mass(es) in such a condition.
Living inside a natural accelerator ,we can play a diversity of motions...including a continuous "tumbling" of two masses pair (let's call it a rotating seesaw)..."self" motion becomes a problem of comprehension and "inspiration".
There are a lot of possible designs , to be transposed into reality ,if you "libarate" this "impetuous" gravity...
Al_ex
Al_ex
.....as a "flip-flop" ,or a continuous leverage , between gravity and (rotational ) inertia ..or,if you like , a "seesaw" game connecting these two phenomena.
Al_ex
Al_ex
.....can be expressed as an "embodiment" , inclusion , addition in an single "shape" , of two performing levers :
-the lift of "M" ,with a common lever ("m"<<"M" and "m" plays on a long arm).
-the fall of "M" , simultaneously with the throw , of "m" from a short , into a longer arm ,with an "uncommon" (variable) lever (see trebuchet).
If we can set ,adjust this "embodiment" as a "self" running one ,due to gravity fall and inertia ....we can show , prove the principle of a gravity motor.
Can it be so difficult?
Al_ex
Al_ex
My friend Al_ex,
you are getting too much subjective - for my mind, sure.
Best!
M
Best!
M
.....can be , in a very short expression "a compound ( unbalance and counterweight ) machine " or a "gravity-inertial motor ".
In this manner , we can take into consideration :
http://www.tasigh.org/ingenium/physics.html
... M ! ...as you see , I try to be even more subjective...
Al_ex
Al_ex
howbout:
turgid throbbing flibbertigibbet widget flipper
Re: re: Gravity motor motto...
Yep...iacob alex wrote:.....can be , in a very short expression "a compound ( unbalance and counterweight ) machine " or a "gravity-inertial motor ".
Al_ex
You make me feel myself much stupid than I used to be! 8\
