Oh well, you tried...Robinhood46 wrote:I have given up.
I've thrown in the towel.
I've stopped kidding myself i can do the impossible.
I tried for long enough, one must learn to accept things, irrespective if we like them or not.
I was a believer, i really thought i could do it.
Seeing that other people had maneged it, i thought i'd give it go.
It has been a complete waste of time. i could have been doing other things way more constructive.
I'm just fed up with going around in circles and not being able to understand what the hell should be happening.
I often thought i was making progress, only to learn it was just an illusion.
If i try this it may work if i try that it may work, fat chance, there is just no way it is going to happen.
The frustration of believing i had finally maneged to actually understand how to make it work and the deception of the bitter truth that i haven't.
I just can't take the psychological strain any more.
I've given up.
Note that it was already considered impossible before you tried.
Yet the question still remains: What did Bessler actually build and how did he manage to fool so many respectable scientists who's concepts are still valid these days and are by no means fools.
As we can't proof the negative then besides trickery there also might still be a chance Bessler found a very unusual mechanical principle.
At a slow pace I just keep investigating and looking for a principle that will match a reply that sounds like:
- "It shouldn't actually do that, yet because of [w] the mechanism has a high probability to do [x] so we can't calculate [y] as a definitive answer but it will still approach [z]."
For me Perpetual Motion is actually a vehicle to (also) learn other stuff: Who knows what comes out of it. As such,for me, a waste of time it is not.
Who isn't.I'm just fed up with going around in circles and not being able to understand what the hell should be happening.
The whole issue of a thing that should be happening but yet isn't is that you can't understand it until it's actually conceptualized (= collected, gathered, conceived, taken into the mind)
The very meaning of "understanding" is that you stand in the midst of it.
In Dutch there's this verb "begrijpen" which means to same thing: It's literally "to grasp". And you can't 'grasp' something that's not there until it is a concept.
Because of all the known/conceptualized Scientific principles it is taught that Perpetual Motion can't happen. Such implies that you can't understand the perpetual-motion concept from known Science, but can understand why it fails. So you can only understand that it can't happen even though you know it literally means: "Continuous motion".
So that's what you have to invent yourself: a mechanical concept that's never seen in public before and probably not done (often) before and which is a principle that's an outlier of Physics.
Creating something unique is never easy. I think that failing to do so is not the same as defeat. Some things are just unique or difficult for a reason.
Also, if you don't understand how your own inventions/concepts actually worked and failed to be perpetual every single time then how did you actually imagine to find a true working principle?
Or even better, how would you explain a working principle to the World (and yourself) other than: "batteries are not included!"?
